Radar detector picking up the MINI? WTF?
Old Aug 29, 2008 | 10:42 PM
Phantom's Avatar
Phantom
I have a Beltronics Rx55, I used to use it all the time, I had all alerts go off supraticly but thats due to some airport equipment that xmits on the same Freq no big deal.
So here is a head scratcher... Can anyone expain why my detector would go ape ship crasy, JUST LASER BAND! when I take my car to full trottle or almost full, I have a 03 mini cooper S if I recall right it did it with my 93 rx7 too.
Operating Bands
• X-band 10.525 GHz ± 25 MHz
• K-band 24.150 GHz ± 100 MHz
• Ka-band 34.700 GHz ± 1300 MHz
• Laser 904nm, 33 MHz bandwidth
Radar Receiver / Detector Type
• Superheterodyne
• Scanning Frequency Discriminator
• Digital Signal Processing (DSP)
Laser Detection
• Quantum Limited Video Receiver
• Multiple Laser Diodes
Old Aug 30, 2008 | 05:45 AM
Warped1966's Avatar
Warped1966
It's probably going nuts from the thrill of the acceleration!
Old Aug 30, 2008 | 05:47 AM
minikart4me's Avatar
minikart4me
i've heard of the same problem with an Escort8500 with an '05 GTO, when it's at full throttle. I don't know how to fix it, but at least you know you aren't alone.
Old Aug 30, 2008 | 08:29 AM
Phantom's Avatar
Phantom
yes it is nice to know im not alone..
Old Aug 30, 2008 | 09:03 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Thats weird, maybe its messing up, I have a Valentine one (way to go) and it doesnt do this, it does pick up laser from Infiniti SUV tailiglights....
Old Aug 30, 2008 | 11:27 AM
Ancient Mariner's Avatar
Ancient Mariner
Full throttle: Warp Factor 10? Might be the 'exceeding light speed' effect.
"More power, Scotty!"
Old Dec 5, 2008 | 03:43 PM
wzabrouski's Avatar
wzabrouski
My V-1 does the same thig? Where did you tap into for power? I thought it had to do with the Mini drive by wire.
Old Dec 5, 2008 | 04:40 PM
SoldierNurse's Avatar
SoldierNurse
I bought the Solo 2, which is powered by AA batteries, for my 09 MCS. I've had no problems.
Old Dec 5, 2008 | 04:51 PM
miniola's Avatar
miniola
Our "LASER" alert goes off when the sun is at a certain angle in the sky... but nothing at full throttle. I mean... you know... if I ever drove like that.
Old Dec 5, 2008 | 05:19 PM
Warped1966's Avatar
Warped1966
After re-reading this and thinking about it, it's probably going off because it's picking up some radio frequency or some other emission from the electronic gas pedal in your Mini. I would fathom a guess that the other cars mentioned that cause the same issue also have electronic gas pedals too.
Old Dec 5, 2008 | 06:54 PM
SoldierNurse
Electronic gas pedal?
Old Dec 5, 2008 | 07:44 PM
Mini S Pilot's Avatar
Mini S Pilot
I have the Belltronics STI and I've never had this problem. Call the company and discuss this with them. They were very helpful when the Hubby and I were researching which detector we thought would meet our needs.
Old Dec 5, 2008 | 07:50 PM
jeffm5150's Avatar
jeffm5150
Throttle by wire ... vs. a physical cable connected between the go pedal and the throttle plate in the throttle body. All MINIs have throttle by wire, where the position of the go pedal is converted to electronic data that is processed by the engine computer which moves the throttle plate (or the appropriate equipment) to the correct position. There are at least two sensors (redundancy).
Funny, I wouldn't think the sensors use lasers, but perhaps they do ???
I have a V1 on my 2007 MCS and have had it give a laser warning for both sun angle and taillights. Perhaps I need a software update
Cheers,
Jeff
Old Dec 5, 2008 | 07:57 PM
Ancient Mariner
No lasers in the throttle/throttle pedal posistion sensors, and the bus that the car uses to communicate is pretty well shielded. I would guess more a power supply issue rather than a spurious signal that only occurs at WOT.
Could be junk on the 12v input that triggers it.
Old Dec 6, 2008 | 04:16 AM
SoldierNurse
Cheers,
Jeff
Thanks, Jeff
iggi
18
Feb 9, 2026 01:00 AM
tr3y003
Oct 22, 2015 10:48 AM
phrza81
Oct 10, 2015 11:37 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
SDMini_me
Aug 7, 2015 08:10 AM
