F55/F56 Non-S Cooper: Rear fog light as additional brake light
Old May 20, 2020 | 09:27 AM
thunderball kaboom's Avatar
thunderball kaboom
I've searched the forum and see quite a lot of discussion about coding the Cooper S dual fog lights as additional brake lights. The coding that's been shared appears to activate the the left and right sides individually. Has anyone used Bimmercode to do the same with the single fog light on a Cooper?
Old May 20, 2020 | 04:20 PM
Imperial's Avatar
Imperial
Try asking Bimmercode support. Once I sent them an email and received response.
Old May 22, 2020 | 07:26 PM
Budshark's Avatar
Budshark
Curious about this too. Let me know if you find anything.
Old Oct 22, 2020 | 01:01 PM
Dasmurph85's Avatar
Dasmurph85
I JUST did this on my single fog light F56. Worked perfect. Make sure your ignition is on but engine off through the entire process. Here’s exactly what I saw as my options.
Go to Body Control Module and enter expert mode
LCE Master
NSL_Verbaut = Verbaut
LCELampMapping3
Mapping_Nebelschlussl_L_output = nsl_l
Mapping_Nebelschlussl_R_output = nsl_r
LCE Configuration
LCE_bel_lin_var
Bel_flc_nsw_nsl
go back to the main screen and hit ‘code’
the ecu will reset and I received a whole slough of light malfunctions. I turned the ignition off for five seconds then back on and everything works perfect. Hope this helps!
Old Oct 23, 2020 | 05:20 AM
NBCGLX's Avatar
NBCGLX
LCE Master
LCELampMapping3
LCE Configuration
LCE_bel_lin_var
Bel_flc_nsw_nsl
Interesting, so you’re still coding the left and right rear fogs, it just outputs in one place (obviously, since the Cooper only has one rear fog).
Old Oct 23, 2020 | 12:05 PM
Dasmurph85's Avatar
Dasmurph85
Yes and that’s what made me nervous! I did some ‘exploring’ and didn’t see the option for a single lamp activation so figured it’s all the same and luckily I was right! Still no errors or issues so seems to be the way to go!
Old Oct 23, 2020 | 01:52 PM
Walt's Avatar
Walt
LCE Master
LCELampMapping3
LCE Configuration
LCE_bel_lin_var
Bel_flc_nsw_nsl
Did you skip this one required step about cycling the ignition before continuing onto the LCELampMapping3 step ?
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, then cycle ignition, then restart Bimmercode
And yes, even though we have only one rear fog lamp, we have to activate both the left and the right in Bimmercode.
Old Oct 23, 2020 | 02:28 PM
thunderball kaboom
Walt:
Do you:
1) complete the activation step, then code and cycle the ignition, and the go back into Bimmercode to complete the rest of the steps and code/cycle a second time
or
2) Add your activation step as the new first step, complete all the other listed activation steps, and then code/cycle?
Old Oct 23, 2020 | 03:19 PM
Walt's Avatar
Walt
Walt:
Do you:
or
  1. Of course. I cycled between the first and second steps. I am not an expert so I followed the instructions exactly.
  2. Not too sure what you mean. I did the first step, cycled, then continued thru the remaining steps given in the Bimmercode thread here. I did turn my MINI back off at the end, since I was done.
Bruce/Fl
Oct 16, 2008 08:54 PM
elbee
Jul 2, 2004 06:04 AM
m3ster
11
Sep 28, 2003 10:35 AM
markvibari
South East - Florida
Jun 18, 2003 12:20 PM
