F55/F56 Quaife vs Wavetrac LSD
Old Nov 7, 2019 | 12:25 PM
holyspiritf56's Avatar
holyspiritf56
I know there are a couple threads on this but most are older. For those out there who have experience with one or both please let me know your thoughts. I'm coming from an OS Giken limited slip diff in my other car.
Once the diff is installed what will the car do in dynamic traction mode? I have been driving mostly in this mode because I forget to hold the switch for 5 seconds. Am I correct that the only way to turn off the auto blip on downshifts in sport mode is to turn traction fully off? Or does it still auto blip downshifts with traction off? I've had cars where all TC is supposedly off but you still need to do something silly like a peddle dance to fully disable the nannies. Is that the case in the F56?
Old Nov 7, 2019 | 12:30 PM
El-Grunto's Avatar
El-Grunto
I can't help you with the LSD comparison but yes, the only way to turn off the auto rev-match is to hold the traction control toggle until you get the warning on-screen. It might be possible to code it to start the car with it disabled but I haven't seen anyone post that they've done it.
Old Nov 7, 2019 | 01:04 PM
strat61caster's Avatar
strat61caster
The car still tries to brake vector with the long button press traction control off but it sure as hell isn't going to save you if you **** it up, I haven't felt it intruding in unwanted ways on the long press, no experience in other modes except accidentally forgetting to turn it off on a run or two. The diff puts the power down, the car knows it's not slipping and therefore doesn't try to brake vector when the diff is doing it's job, if you overdrive or the diff doesn't do it's job and you do get some one tire fire going the brake vectoring will still kick in to try to help.
Old Nov 8, 2019 | 05:29 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
I AutoX'd with ELSD and with WaveTrac...completely different vehicle. I don't feel any interference from the stock ELSD because the WaveTrac is a Monster!!!
I picked the WaveTrac because it doesn't come with friction plates that can wear down AND it uses the same Differential Type Fluid (I went with Motul)
Old Jan 2, 2020 | 07:31 AM
MikeMJCW's Avatar
MikeMJCW
Someone posted here about coding out the "E"LSD https://www.northamericanmotoring.co...lsd-yet-3.html
I've been playing with the DSC/EDLC off, car's all over the place. I would try a LSD if it didn't involve tearing into the tranny i.e. if it were a rear axle.
So everyone loves their Quaife/Wavetrac's no regrets?
Old Jan 2, 2020 | 03:53 PM
cmt52663's Avatar
cmt52663
You keep mentioning these "friction plates"...
Ain' no sech thang in the Quaife neither.
Nuthin but pretty gears.
Je's sayin'
Cheers,
Charlie
Old Jan 3, 2020 | 05:42 AM
MikeMJCW's Avatar
MikeMJCW
Interesting that Wavetrac claims to be the only torque biasing diff for the cooper, Quaife is an ATB (auto torque biasing).
So far I got one quote of $2000 labor so this is probably a moot point for me, 3k on top of what I already spent is starting to approach C8 vette territory.
I like the look of the Wavetrac Cam.
Quaife site: https://quaifenorthamerica.com/colle...d-differential
"the Quaife ATB Helical LSD differential" "the Mini Cooper S F56 Quaife ATB Helical LSD differential relies on gears rather than clutch plates for its operation" "and a maintenance-free design which retains the standard oil lubrication"
Wavetrac site
"The F56 Wavetrac® Differential is the only torque biasing Mini Cooper differential on the market"
Old Jan 3, 2020 | 09:53 AM
Juice84's Avatar
Juice84
Je's sayin'
Cheers,
Charlie
I think he means clutch plates... but I don't think any of the options for F series minis are clutch types.
Old Jan 3, 2020 | 12:33 PM
J_L's Avatar
J_L
@MikeMJCW where are you located? I have 2 quotes for around $1,500 for clutch and LSD in the LA area.
Old Jan 3, 2020 | 01:04 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Originally Posted by MikeMJCW
Wavetrac site
Well we know that is 100% false as the Quaife is too.
https://www.waymotorworks.com/quaife...5-f56-f57.html
Old Jan 3, 2020 | 02:16 PM
MikeMJCW's Avatar
MikeMJCW
Massachusetts. These are the same places that wanted over $1000 to install coilovers. And in Cali you don't shovel snow.
Old Jan 3, 2020 | 10:14 PM
strat61caster
It's the same tranny as the Focus ST so you can get an OS Giken clutch type LSD if so desired. Was listed on the USA distributor site but when they migrated to a new site it didn't make the cut because I think they only sold one, can probably special order it though, here it is listed on an Aussie site:
https://www.difflab.com.au/products/...iken-superlock
Old Jan 10, 2020 | 05:54 AM
MikeMJCW's Avatar
MikeMJCW
Just got another quote of $3,000 to install a LSD so no Quaife for me. WT...... Cali is cheaper than Mass, I could drive it to Cali, enjoy sunshine and still come out with spare change.
Old Jan 10, 2020 | 06:35 AM
Darbys2019MiniJCW
I got very lucky and paid $850.00 to get my Wavetrac installed...I helped so I could see the whole thing. I'm just lucky I have such a good mechanic who LOVES BMWs and their stepchildren.
Old Jan 10, 2020 | 12:06 PM
MikeMJCW's Avatar
MikeMJCW
WOW $850 is way better than 3K. I can't imagine seeing a return on investment (3K) for street use.
Old Jan 22, 2020 | 04:40 PM
u2asian's Avatar
u2asian
How much Motul went in? I have to assume you used 75W90?
https://www.amazon.com/Motul-75W90-Synthetic-Transmission-Differential/dp/B07GNT8WCV/ref=sr_1_6?keywords=75w90&qid=1579737484&sr=8-6 https://www.amazon.com/Motul-75W90-Synthetic-Transmission-Differential/dp/B07GNT8WCV/ref=sr_1_6?keywords=75w90&qid=1579737484&sr=8-6
Getting ready to install mine.
Old Jan 22, 2020 | 05:46 PM
holyspiritf56
That is a smoking deal! I'm not in Texas but you should share the name of the shop to help out others. My install will cost twice that.
Old Jan 28, 2020 | 05:53 PM
Darbys2019MiniJCW
https://www.amazon.com/Motul-75W90-S...9737484&sr=8-6
Used 2 Bottles of Motul 300 75W90 and a tad more of the 3rd Bottle.
Old Jan 28, 2020 | 05:58 PM
Darbys2019MiniJCW
Tony Rand in New Braunfels Texas... I was the first one he did and I tipped him $100 more.
I think he would now do one for about $1100 but that is still a great price and I have had NO ISSUES!
He is moving to his new shop this weekend so would be ready to start again around the 5th or so of February.
Total Automotive Repair
Tony A. Rand
210-504-6101
Old Mar 26, 2020 | 07:30 AM
MikeMJCW's Avatar
MikeMJCW
I thought I read somewhere that "engine braking" will be affected/altered with a LSD? What/or have you guys noticed with either the Wavetrac or Quaife?
Old Mar 26, 2020 | 08:39 AM
cristo's Avatar
cristo
Alliance Member
The electronic traction control will
apply braking to a spinning wheel.
If you overcome the capability of
the mechanical LSD, the ETC* will
kick in to brake the spinning wheel.
You’ll see less ETC action with a
real LSD IN PLACE, which is a good thing.
*ETC, DSC, ASC, ELDC, or whatever
Old Sep 22, 2024 | 06:56 AM
blue al's Avatar
blue al
Has anyone yet driven these pair of options back to back ?
is one more road or track biased?
im leaning towards the quaife solely on the basis I have one already in my R59 roadster, not very scientific I know. …
Old Sep 22, 2024 | 08:07 AM
cmt52663's Avatar
cmt52663
I run the Quaife. The WaveTrac is based on the Quaife, but allegedly adds a solution to the "lifted wheel" problem (normally encountered only when bounding off curbs on a race track).
Either is good, from all that I know.
Kind regards,
Charlie
Dr Obnxs
32
Jan 23, 2011 12:01 AM
--e
SCCA Solo and ProSolo
11
Sep 21, 2010 12:07 PM
iflyga
Factory JCW Talk (2009+)
Jul 10, 2009 03:07 PM
orangecrush
Apr 11, 2009 10:18 AM
TWON
Apr 7, 2007 04:17 PM
