F55/F56 Coolant/antifreeze level
Old Jul 12, 2018 | 10:21 AM
spotted's Avatar
spotted
Know when you go to the dealer for maintenance and they put 'Topped at Fluids' should that include the coolant/antifreeze level?
So I opened up the coolant/antifreeze reservoir and it's not near the min/max line. In fact its much lower. I did check after at least a 8 hour cool down. I do have a tune and it was like this before the tune also. Couldn't get a great shot cause I would have to remove the intake to see the whole tank.
Do I need to add more or am I ok the way it is?
The level I see from the angle I'm in.
Without the red line.
With flash to see that its below the min.
Without a flash.
Old Jul 17, 2018 | 03:04 PM
barmybee's Avatar
barmybee
Hi Spotted
Hope this helps, sorry for a late post but only been on in a while.
Barmy Bee
File Type: pdf
File Type: pdf
Old Jul 17, 2018 | 03:08 PM
spotted's Avatar
spotted
Originally Posted by barmybee
Hi Spotted
Barmy Bee
Thanks. Was starting to think it was 'normal' since no one replied.
So then got to put some in there.
Old Jul 17, 2018 | 03:14 PM
barmybee's Avatar
barmybee
I would think sooner rather than later, Demin water if you have no proper coolant or antifreeze to hand.
Old Jul 17, 2018 | 03:37 PM
barmybee's Avatar
barmybee
Hope these help
File Type: pdf
Old Jul 25, 2018 | 05:46 AM
hp79's Avatar
hp79
Mine was like this too. Had 15k miles. I just topped it with distilled water. I don’t think the dealer can top this especially when engine is warm.
Old Jul 25, 2018 | 07:35 AM
iwashmycar's Avatar
iwashmycar
I am always adding a tiny bit to our R60. I think the crappy reservoir connection weeps some now and then. Not sure if the F series is similar
Old Jul 28, 2018 | 10:41 PM
hardy616's Avatar
hardy616
Mine was below min too even when it's still warm (the level is usually a bit higher when warm than when cold). Had dealer check and they replaced auxiliary water pump. Not sure if this fixed the problem since I haven't checked since then.
Old Jul 29, 2018 | 10:58 AM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
My 2005 R52S is running hotter this year and I don't know why. It could be because I am just paranoid. My normal around town, including stop and go, is IA=100-120 w188=215. Now, stop/go/town is up to IA 115=165 w190=224 max. I made a dipstick for my tank so the level stays the same. Does anyone have any tips for lowering the temps? It seems that the mini engine is very heat sensitive. I am going to get the coolant flushed in Aug. He is also adding something to lower coolant temps. I don't remember the name but I read about on the Detroit Tuned website.
Old Nov 11, 2018 | 10:26 AM
DudskieG's Avatar
DudskieG
Hello all, nor trying to hi jack the thread, but, is there a special coolant that we need to use in our car (mine is 2015 F55 s)? I saw a for European car 50/50 Anti freeze from Walmart made by Prestone. Is this safe to use it in our car? Thanks
Old Nov 11, 2018 | 10:45 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
From the description it sure looks like it would work with a MINI. I prefer to stick with OEM and not mix brands but it probably is the same chemical composition.
newminiowner123
Aug 6, 2021 06:52 AM
silvia
Jul 27, 2014 11:39 PM
Chitown_COOP
Jun 29, 2008 04:39 PM
nthwolf
MINI5280
Jul 30, 2006 02:31 PM
