F55/F56 Startup after Storage
Old 07-10-2018, 03:32 PM
rockhouse66's Avatar
rockhouse66
rockhouse66 is offline
My 2016 S is sitting in FL until probably December. Total of almost 9 months. Would you remove the fuel pump relay (if I can find it!) and crank for a while before starting or just start 'er up?
Old 07-11-2018, 05:47 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Moderator
Hit the ignition switch once to let everything cycle up then start it up.
Id be more concerned about your battery then the relay. Use a trickle charge for that
Old 07-11-2018, 06:04 AM
rockhouse66
Yes, I have the battery on a C-Tek charger.
Old 07-11-2018, 10:59 AM
Mini_Vinnie
Moderator
You should be fine then
Old 07-11-2018, 05:52 PM
peterpan101's Avatar
peterpan101
peterpan101 is offline
do an oil change also
Old 07-11-2018, 06:05 PM
rockhouse66
I got the car in January and parked it in March. I now wish I had gotten an oil change before I parked it, but I do plan to have the oil changed right away when I return and do the start up. Too bad you can't take a look at the oil appearance on the dipstick
Old 07-11-2018, 06:58 PM
peterpan101
Well guessing did minimal mileage so should be ok, but yeah still change before starting. Does suck not having dip stick. Also fuel stabilizer is a good idea next time
Old 07-13-2018, 02:15 PM
rockhouse66
I did fill up with ethanol free gas just before storage which I hope will help. I have heard that Sea Foam actually works so perhaps I should consider that in the future. Good suggestion.
Old 07-13-2018, 06:34 PM
Mini_Vinnie
Moderator
What trickle charger are you using? I need to get one this winter
Old 07-15-2018, 09:36 AM
rockhouse66
I am using the C-Tek 3300, which I purchased here;
https://www.ebay.com/itm/CTEK-3300-B...QAAOSw-zxWpovr
Old 07-16-2018, 06:26 AM
Mini_Vinnie
Moderator
Nice, thanks for the info. I will check it out
Heifzilla
07-26-2014 08:43 PM
jetmechinnc
05-26-2013 06:48 PM
tominizer
04-26-2012 05:31 AM
rcm3
12-04-2010 11:15 AM
wmba
12-18-2004 11:05 AM
Quick Reply: F55/F56 Startup after Storage
