F55/F56 Squeaky Clutch Pedal
Old Jun 19, 2017 | 07:15 PM
JonCanada's Avatar
JonCanada
Has anybody had intermittent squeaking occur when depressing the clutch pedal. At first i thought it was something on the sole of my shoe, but a closer look revealed that the pedal was rubbing against something in the foot-well. I stuck my hand around the pedal attachment, and there seems to be a rubber wire close by - but nothing really noticeable/obvious that would cause the squeaking. Was wondering if anybody has a similar issue - before I take it in.
Car is a 2014 F56 Justa
Old Jun 20, 2017 | 06:51 AM
Nuke-em's Avatar
Nuke-em
Yeah, but it it's super-intermittent. It has to be the right mix of temperature and humidity.
Old Jun 20, 2017 | 07:43 PM
mattkosem's Avatar
mattkosem
Sound anything like this? https://www.northamericanmotoring.co...ky-clutch.html
I still get that every now and then, thought it seems less and less frequent as time passes. It seems to surface mostly when the car is cold, particularly after using reverse. It seems to consistently be gone within 2 miles of driving these days, though, whereas it persisted before the new clutch fork and TOB.
--Matt
Old Jun 28, 2017 | 11:42 AM
JonCanada's Avatar
JonCanada
--Matt
nope definitely not a mechanical sound. I think it's more like Nuke-em's - where it's tied to humidity and temperature. It sounds like squeaky shoes over a freshly waxed floor - for the longest time i thought it was the sole of my shoes. It's been gone for the past week or so - will keep an ear out for it, and get a recording next time.
Old Jul 13, 2017 | 07:02 PM
JonCanada's Avatar
JonCanada
here's a video of the squeaky clutch - as Nuke-em mentioned, it seems to only kick-in on humid, high temp. days
Old Jul 14, 2017 | 05:59 AM
Nuke-em's Avatar
Nuke-em
Yep. That's the noise. When you combine that with my perpetually squeaking wiper arm swivel, it sounds like I'm driving something from ***** Wonka's chocolate factory.
Old Jul 25, 2017 | 07:17 AM
marcus_cwb's Avatar
marcus_cwb
Mine has the same noise and it is very annoying.
Has anybody found a solution?
Old Jul 25, 2017 | 06:33 PM
MarcoPolo's Avatar
MarcoPolo
i had this issue with my Maxima and my CRV. both were resolved with white lithium grease. i'm getting that noise as well. seems to be all too common. i'll try some of that next time i can.
Old Jul 29, 2017 | 09:24 PM
mattkosem's Avatar
mattkosem
I've had this happen on other cars too. On my 06 GTI grease kept it at bay for a while, but I eventually needed a new clutch master.
Old Aug 9, 2017 | 07:26 PM
JonCanada's Avatar
JonCanada
Update after bringing it into the shop: the tech wasn't able to re-produce the sound on an initial drive, but after he "moved some things around" the squeaking started again. He tried lubricating the joints, but squeaking still persisted, with the description: "both clutch buffer and pedal bushings squeaking"
So they've got the following parts on back-order to be replaced under warranty:
  • Clutch Pedal Pin
  • Pin. Master Cylinder
  • Bushing
  • Clutch Pedal Buffer
Old Oct 18, 2017 | 07:42 AM
JonCanada's Avatar
JonCanada
Originally Posted by JonCanada
....So they've got the following parts on back-order to be replaced under warranty:
  • Clutch Pedal Pin
  • Bushing
Update - Roger (my F56) is at the shop to replace the clutch pedal, etc... He had stay overnight, and I had a brief look at it when it was on the lift, it looks like a fairly complex job.
Old Oct 20, 2022 | 09:27 PM
lukemoredos's Avatar
lukemoredos
bushing problem
i found itz THE CLUTCH BUSHING(part number #35006873503)problem.
the oem bushing is plustic, it wont last long and cause noise again.
hoping someone can 3D print it and make Polyurethane bushing soon
Old Oct 25, 2022 | 10:00 AM
Nothing yet and it does not follow the design of the older MINIs that have the same problem.
https://www.ecstuning.com/b-genuine-...g/35006873503/
Old Oct 26, 2022 | 11:22 PM
strat61caster's Avatar
strat61caster
Oiling the clutch bushing (the top most pivot) seems to have kept ours quiet for a few weeks now, fingers crossed.
Old Nov 27, 2022 | 01:46 PM
ChrisHarris's Avatar
ChrisHarris
Not a Mini - it's an M3 - but skip to the 4:19 mark regarding the same exact sound...
Brayden Folcomer
R55 :: Clubman Talk (2008+)
Aug 9, 2019 12:54 PM
Conrad_Thomaier
Jul 1, 2018 11:09 AM
el_Zilcho
R60/R61 Stock Problems/Issues
21
Dec 19, 2014 05:57 AM
ASRman
Jul 12, 2014 02:35 PM
myzamboni
Jul 24, 2006 09:42 PM
