F55/F56 Turbo Boost 3 cyl vs 4 cyl
Old Aug 13, 2016 | 12:11 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Anyone have a source of the different rpm values when the turbo kicks in in the two engine configurations. Standard and Sport mode perhaps. We can ignore the rarely used Green mode.
Wife has the 3 cyl and the rpm range in sport mode before the turbo kicks in is very similar to the N18 we have in regular mode. Not a fan of this and will guide my decision on the next car.
Old Aug 13, 2016 | 12:34 PM
mattkosem's Avatar
mattkosem
Not a fan in what way? The 3-cyl seems pretty lagless. N18 too. Are you looking for more lag?
--Matt
Old Aug 13, 2016 | 01:02 PM
siriuszero's Avatar
siriuszero
The turbo spools up as soon as 1250 RPM on both the B38/36 and the B46/48. The N18 I believe was at 1500 RPM.
Old Aug 13, 2016 | 01:14 PM
Minnie.the.Moocher
Originally Posted by mattkosem
Not a fan in what way? The 3-cyl seems pretty lagless. N18 too. Are you looking for more lag? --Matt
between 2 & 2.5k rpm the 3 cyl in Sport mode has a flat spot or lag, same in the Countryman without sport button. Will have to go test drive the 4 cylinder again.
Old Aug 13, 2016 | 01:16 PM
Minnie.the.Moocher
Why do the tuner dyno charts always start about 2500? The Dinan rep on the forum seemed to indicate that was were boost kicked in.
Old Aug 13, 2016 | 02:12 PM
Camyman's Avatar
Camyman
On these new motors boost comes on very early, that is what makes the autos short shift when they are in green mode. The 3 cyl revs more freely than the 4 from my experience, but the power on the 4 more than makes up for that.
Old Aug 15, 2016 | 12:43 PM
siriuszero's Avatar
siriuszero
I can't speak for tuner dyno charts, but it's a fact that the stock engine will put out maximum torque at 1250RPM - I can only assume this is because of the low-lag characteristics of the MINI turbo.
Old Aug 15, 2016 | 01:33 PM
Both MINI turbos are low lag dual scroll. They wind up pretty fast. After driving both, I did not feel much lag in either. The 2.0L did feel like it had more power, but the 1.5L felt like it could keep up. The charts start higher when you can actual see change in tunes or power upgrades. Lower in the chart you sometimes cant see them.
Old Aug 15, 2016 | 03:56 PM
siriuszero's Avatar
siriuszero
The 1.5L is a single scroll since it's a 3-cyl
That's true - I noticed all the charts I saw from dyno runs with tunes all started at around 2000 RPM. They're not even measuring as low as 1250 RPM.
renchjeep
Apr 28, 2026 08:55 PM
Bponce23
Mar 30, 2016 05:31 AM
Hoover23
Mar 22, 2016 07:59 AM
Terry@spool-turbo.com
Dec 20, 2002 10:14 AM
Agro
Dec 4, 2002 12:00 PM
