F55/F56 '15 F56 TPMS question
Old May 3, 2015 | 11:52 AM
minikun's Avatar
minikun
So with the 2015 F56 cooper s - do you need to reset or recalibrate the TPMS after a tire rotation (front to rear)? Does this system relearn the location of the wheels automatically? Since it shows the pressure of each tire on the dash I want to make sure the front isn't showing as the rear and vice versa. It's impossible to find a straight answer anywhere and Mini's manual doesn't explain anything either.
Old May 3, 2015 | 03:23 PM
anotherminiinthegarage's Avatar
I would do a reset, it only takes a moment.
Old Nov 10, 2015 | 05:34 AM
mcamp001's Avatar
mcamp001
I have the same issue with our 2015 F55. I rotated the tires, now the dash lights are on warning of low pressure. I assume this is because of the rotation as the tires are fine. What is the reset procedure? I saw a vid for the 2012 model, but are the 2015's different?
thanks
Old Nov 10, 2015 | 07:22 AM
Pedro99's Avatar
Pedro99
If you go to Mini USA owners manual..look under safety.
http://www.miniusa.com/content/miniu...r-manuals.html
Old Nov 10, 2015 | 09:06 AM
CooperB's Avatar
CooperB
Vehicle Info -> Vehicle Status -> Tire Pressure Monitor (TPM) -> Preform Reset
The system will reset next time you drive the car, it will show a % of completion if you stay on that TPM screen under Vehicle Status, usually takes 2-5 minutes of driving.
Old Nov 10, 2015 | 10:24 AM
mcamp001's Avatar
mcamp001
I missed the part in the manual, thanks all
Old Nov 11, 2015 | 12:31 PM
+1 reset , then drive down the road and then it will confirm ok.
Old Nov 13, 2015 | 04:53 PM
02fanatic's Avatar
02fanatic
The reset procedure is kinda quirky, but keep with it and it will work eventually. I had to try several times before the reset initiated.
Old Nov 16, 2015 | 01:02 PM
Yep, might take a time or two.
Dec 23, 2015 10:36 AM
hexproject
Sep 7, 2015 08:23 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
ki7hy
Aug 12, 2015 07:07 PM
Dashdog
Aug 10, 2015 06:17 AM
