F55/F56 NM-ENG Power Module
NM-ENG Power Module
So NM Eng have come out with the version of the Power Module.
From the looks of it, it is very similar to the burgertuning.
NN is more expensive by about $20 Bucks.
http://www.nm-eng.com/338/0/0/3128/n...er-module.html
Definitely looks a lot cleaner than the the BT, though the BT is still technically beta...
Their dyno results say their test car had a NM exhaust and intake. I wonder what the numbers would be with a stock S...
I will start this by making it clear that I'm a mechanical moron :-)
With that said, a couple of observations and questions:
- The Burger tune plugs into both the MAP and TMAP sensors, while the NM tune seems to only plug into the TMAP sensor.
- Why the difference?
Also - in looking at the Burger tune, the cable has 4 sets of plugs yet the instructions seem to have you only using 2 of the 4 sets (MAP and TMAP). What are the extra sets of plugs used for?
BM has a version for the base and the S. NM doesn't specify, that I can tell, what version their tune is for.
The dyno chart for the NM one is for the F56S.
http://www.nm-eng.com/media/attachme...i_F56_Dyno.pdf
You can't lose either way. Some dude put a BT on an R56 JCW, put the dial on 30%, and he said the thing took off like a rocket lol. I'd be afraid to use one of those. I don't get that many opportunities to open my car up as it is.
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Sep 4, 2015 02:34 PM
