F55/F56 2014 F56 Safety Recall
Old Jan 8, 2015 | 08:37 AM
JohnBLZ's Avatar
JohnBLZ
http://www.motoringfile.com/2015/01/...ts/#more-38442
I don't have warm and fuzzies over this considering I pick up my son and he rides in a car seat in the back.
Old Jan 8, 2015 | 09:07 AM
Crimguy's Avatar
Crimguy
Originally Posted by JohnBLZ
http://www.motoringfile.com/2015/01/...ts/#more-38442 I don't have warm and fuzzies over this considering I pick up my son and he rides in a car seat in the back.
I hear you. Mine was built in June. I can't imagine what changed between builds in May and June.
Old Jan 8, 2015 | 10:31 AM
Crimguy's Avatar
Crimguy
As per one of the posts at motoringfile:
"Called MINI USA, they're not giving much info but they did indicate the repair would take approximately an hour and is specific to the rear panels in the interior. They would not advise whether/not it was safe to have passengers in the rear seat at this time."
Old Jan 8, 2015 | 10:56 AM
spacecadet's Avatar
spacecadet
I would not get concerned about this. I'll try to explain why.
There is a lot of information about this on the nhtsa website so, seeing as its all in the public domain, I'm going to quote some of it.
First of all see Mini's communications to dealers on this:-
http://www-odi.nhtsa.dot.gov/acms/cs...4V815-6046.pdf
BMW is conducting a voluntary safety Recall involving the side impact performance on certain Model Year 2014
MINI Cooper (NOT Cooper S) 2-door Hardtop vehicles. Approximately 3,680 vehicles, produced from December
2013 through May 2014, are involved
The interesting thing here is that they explicitly state this does NOT apply to the Cooper S. Now this really sparked my interest, especially when you consider what the differences are between the two models and that the bodyshells are essentially the same.
Next, take a look at this document, which is the non-compliance report:-
http://www-odi.nhtsa.dot.gov/acms/cs...4V815-9329.PDF
On October 6, 2014, NHTSA conducted a FMVSS 214 compliance test of a Model Year 2014 MINI Hardtop 2
Door (Cooper trim level). A test result value exceeded the limit specified in FMVSS 214 Section 7.2.6(b) – the
specified maximum T12 acceleration value (82g) was exceeded by 0.17g. Although BMW believed that the
vehicles did comply with FMVSS 214, BMW was concerned about its margin of compliance.
Between mid-October and late-November, the engineering team evaluated the following that were thought to
affect vehicle and dummy response:
- Reviewed engineering drawings of various vehicle systems and components pertaining to side impact
performance
- Examined vehicle build configurations
- Evaluated vehicle weight specifications, power train and braking requirements relative to GVWR
- Performed side impact crash tests
- Conducted side impact computer simulations
- Analyzed preliminary test data supplied by NHTSA
On November 5, 2014, NHTSA sent an Information Request letter to BMW regarding FMVSS 214 certification
of the Model Year 2014 MINI Cooper.
As a result of the engineering team’s analyses, and during preparation of the response to the Information
Request, BMW realized that there could be a non-compliance issue on a limited number of MINI Cooper
vehicles, the primary factors related to side impact performance being effective use of available energy
absorbing structures and the vehicle weight.
On December 15, 2014, BMW met with NHTSA to discuss its upcoming response to the Information Request.
At the meeting, NHTSA strongly suggested that BMW submit a Part 573 report.
On December 18, 2014, after the engineering team completed its in-depth review of all of the available
information, it concluded that certain Model Year 2014 MINI Hardtop 2 Door (Cooper) vehicles do not fully
conform to FMVSS 214. As a result, BMW decided to conduct a voluntary recall.
BMW has not received any reports, nor is otherwise aware, of any accidents or injuries related to this issue.
Description of Remedy :
Description of Remedy Program : To be determined.
We are currently investigating adding a foam pad/patch to the affected
This refers to side impact test specification FMVSS 214 Section 7.2.6(b) limit of 82G being exceeded by 0.17g.
If you hold out your arm and then let it swing down, your hand is accelerating with 1g. Take 17% of that and that is the acceleration by which this test is failing. Or to put it another way its failing by 0.17/82*100 = 0.2% which in my opinion is well within the margin of error of such a test. However a margin of error is not allowed for in the spec, it either passes or fails, and therefore the car failed the test. In the real word I think this makes practically no difference to how you would fair in a real crash. There are so many other factors that come into play that I really would not worry about it.
The spec for the test can be found here :
http://www.gpo.gov/fdsys/pkg/CFR-200...sec571-214.pdf
Section 7.2.6 defines what this 82g limit refers to - it the lateral lower spine acceleration of a female adult dummy located in the rear seat.
So, I come back to why BMW thinks this does not apply to the Cooper S, the way the test is performed, and the particular test the car failed marginally -all these pieces of information gives us a clue what is going on here. It is not just about the car's structure having the ability to absorb the impact energy. It comes down to simple physics which also partially explains why its so hard for small cars to pass this test - and that is mass! The heavier the car the better it will both absorb the energy and lower the resulting accelerations will be experienced by the occupants. And - the Cooper S is heavier than the Cooper in standard trim - bigger engine - one extra cylinder - bigger wheels, higher equipment etc. The car is so marginal on the limit of the test, this difference appears enough to limit the failure to comply to the standard only to the Cooper.
In fact if you refer back to the chronology, BMW elude to this as they mention variations in equipment levels and vehicle GVWR (gross vehicle weight).
BMW also elude to the fix - they will likely insert some energy absorbing foam behind the interior rear side panels. Such foam is already fitted in the doors and other places.
Old Jan 8, 2015 | 11:07 AM
aafflyer's Avatar
aafflyer
Fantastic explanation.
As an owner of a 2015 F56 Justa, I am not concerned.
However, I do have to wonder what changed in the June timeframe that they stopped there.
Thanks for all the time you spent to make your post.
Old Jan 8, 2015 | 11:14 AM
spacecadet's Avatar
spacecadet
I can think of a few possibilities, but it might just be that over the course of their own testing BMW knew the car was close to the limit and made some minor modifications in production to increase the margin. It could simply be a few extra spot welds, different steel composition/thickness for a few key components or similar. Equipment levels may have changed also as it was getting close to the 2015 changeover, was it not?
Old Jan 8, 2015 | 12:28 PM
Crimguy's Avatar
Crimguy
We're gonna keep you around for a bit cadet ;-) well done.
Originally Posted by spacecadet
I would not get concerned about this. I'll try to explain why. There is a lot of information about this on the nhtsa website so, seeing as its all in the public domain, I'm going to quote some of it. First of all see Mini's communications to dealers on this:- http://www-odi.nhtsa.dot.gov/acms/cs...4V815-6046.pdf The interesting thing here is that they explicitly state this does NOT apply to the Cooper S. Now this really sparked my interest, especially when you consider what the differences are between the two models and that the bodyshells are essentially the same. Next, take a look at this document, which is the non-compliance report:- http://www-odi.nhtsa.dot.gov/acms/cs...4V815-9329.PDF This refers to side impact test specification FMVSS 214 Section 7.2.6(b) limit of 82G being exceeded by 0.17g. If you hold out your arm and then let it swing down, your hand is accelerating with 1g. Take 17% of that and that is the acceleration by which this test is failing. Or to put it another way its failing by 0.17/82*100 = 0.2% which in my opinion is well within the margin of error of such a test. However a margin of error is not allowed for in the spec, it either passes or fails, and therefore the car failed the test. In the real word I think this makes practically no difference to how you would fair in a real crash. There are so many other factors that come into play that I really would not worry about it. The spec for the test can be found here : http://www.gpo.gov/fdsys/pkg/CFR-200...sec571-214.pdf Section 7.2.6 defines what this 82g limit refers to - it the lateral lower spine acceleration of a female adult dummy located in the rear seat. So, I come back to why BMW thinks this does not apply to the Cooper S, the way the test is performed, and the particular test the car failed marginally -all these pieces of information gives us a clue what is going on here. It is not just about the car's structure having the ability to absorb the impact energy. It comes down to simple physics which also partially explains why its so hard for small cars to pass this test - and that is mass! The heavier the car the better it will both absorb the energy and lower the resulting accelerations will be experienced by the occupants. And - the Cooper S is heavier than the Cooper in standard trim - bigger engine - one extra cylinder - bigger wheels, higher equipment etc. The car is so marginal on the limit of the test, this difference appears enough to limit the failure to comply to the standard only to the Cooper. In fact if you refer back to the chronology, BMW elude to this as they mention variations in equipment levels and vehicle GVWR (gross vehicle weight). BMW also elude to the fix - they will likely insert some energy absorbing foam behind the interior rear side panels. Such foam is already fitted in the doors and other places.
Old Jan 8, 2015 | 01:06 PM
spacecadet's Avatar
spacecadet
Have a look at the video of the side impact test
http://www.safercar.gov/Vehicle+Shop...vehicleId=8798
A few things are apparent from that if you look closely:-
1) Deformation of the side to the car does not look too bad and there will be minimal, if any intrusion of the cabin area occupied by the rear seat passenger. Lower deformation actually means the car is absorbing less energy and a higher proportion will get used to accelerate the car sideways. So ironically a stiffer structure can be worse for the occupants.
2) The car is literally launched sideways at high speed by the impact. The occupant is literally going to get a fair whack from the interior trim from that.
3) A fair few bits of trim have been removed to help with installing the test instrumentation in the car - making it lighter
It also occurs to me the type of surface on which the vehicle is standing, the size and type of tyre fitted and even the ambient/tyre temperature are going to have a huge effect on the co-efficient of friction between the vehicle and the ground, which will also have a huge effect on the rate with which the vehicle is accelerated sideways - even the number of wheels and for how long that stay in contact with the ground. In the video the surface appears to be concrete which is much slippier than tarmac.
Just goes to show the huge number of variables involved in this and the complexity of the testing. No wonder its not an exact science and mistakes are made.
Old Jan 8, 2015 | 01:12 PM
TheBigNewt's Avatar
TheBigNewt
SpaceCadet for President! I guess I'm OK I don't have a back seat lol.
Old Jan 8, 2015 | 02:48 PM
J_L's Avatar
J_L
Gold star for spacecadet.
Old Jan 9, 2015 | 10:31 AM
JohnBLZ's Avatar
JohnBLZ
Nice overview and analysis!
Old Jan 10, 2015 | 01:00 PM
shark715's Avatar
shark715
I've been a member of this forum for 6 years, and that has to be one of the best, if not the best, post I've seen! You are not an engineer type person, are you :-) Thank you!
Rohdeandschwarz
May 16, 2019 08:59 AM
ccham
Sep 20, 2015 07:08 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
torpeau
Sep 10, 2015 07:59 PM
dandw2
Sep 7, 2015 11:14 AM
