F55/F56 Mini coding/programming
Old Dec 2, 2014 | 10:47 AM
  #51
DarkBlue15MCS's Avatar
DarkBlue15MCS
Originally Posted by MarcoPolo
psdzdata - if you go the mhhauto route you'll have 26 links to 26 rar files. OR - (if you're familiar with torrents)
For basic fdl coding you only need the PSdzData lite files Version 2.54.1 is the newest version
Old Dec 2, 2014 | 10:51 AM
  #52
DarkBlue15MCS
http://www.bmwesys.com/guides/ will show you all the known codes and what to set them to.
as for cryptic...once you get the hang of it, it's actually quite simple. keep in mind it's all LITERALLY in german, so the docx fill is really needed.
the codes are broken down into sections. in the .docx file you'll see that, for example,turning off seat belt reminder is:
ACSM
Turn Off Seat-Belt Reminder Chimes:
3000  SeatBeltReminder_Fahrer = nicht_aktiv
3000  SeatBeltReminder_Beifahrer = nicht_aktiv
so you go to ACSM, load up the CAFD file and edit it. when you open that up you'll see a list of numbers. look for 3000, open that up and you'll see a tons of more options. look for "SeatBeltReminder_Fahrer". open that up and you'll most likely see it set to "activ". edit and chose "nicht_aktiv" from the drop-down menu. save and apply and that's it.
Thats a great resource for the guides. I haven't seen that site yet. I filtered through all the bmw guides to see what worked and what didn't. Having a dedicated F56 great is great!
Old Dec 2, 2014 | 10:53 AM
  #53
DarkBlue15MCS
Originally Posted by hp79
I see. Thanks. I'm still waiting on my $4 ODB to Ethernet jack adapter shipped from China.
I wonder if I can disable AC automatically turning on when air is directed towards the windshield. (stupid lawmakers thinking everyone is an idiot in the U.S.) Is the coding mostly very cryptic and hard to recognize what does what?
Why would you want to turn the AC off when in defrost mode?
Old Dec 2, 2014 | 10:55 AM
  #54
hp79's Avatar
hp79
Does anyone know if Bluetooth audio streaming can be added for the basic radio models?
Not really related and this is probably a bug but every time I turn on my car, my phone is connected through Bluetooth and it starts showing "in call for x:xx" and keeps counting ini the center display. I can't play music through USB or radio or anything unless I make a call and hangup. Then the "in call" message stops and behaves normal. It's so annoying I unpaired my phone. I have a Note3 n900a by the way.
edit: This was caused by my ROM on the phone that got weird. It was fixed after re-flashing my phone.
  #55
r33's Avatar
r33
R33, i have a question. since i simply ordered the most basic radio, i have bluetooth phone only capabilities. this shows up as 6ND in my VO settings. the instructions specifically note that you can go from 6NH to 6NS to enable enhanced bluetooth. do you know if i can go from 6ND to 6NS? more importantly, any concern over doing this? i've confirmed this won't enable my voice activated module but it should enable A2DP audio over bluetooth.
I believe on Mini there is no 6NS. I just looked in the parts catalog, the only option is between 6ND and 6NE.
Not sure if that will work. I believe the wiring to the pin out different with a regular OBDII.
Old Dec 2, 2014 | 10:57 AM
  #56
hp79's Avatar
hp79
I don't want to turn AC off in defrost mode, I just want it to not turn on automatically when I direct air to the windshield. Most of the times for me, just blowing air to the windshield is enough to prevent fogging.
Old Dec 2, 2014 | 11:01 AM
  #57
MarcoPolo's Avatar
MarcoPolo
this is what i get for spending too much time in the bimmer forums. let's me re-ask then. do you see any VO change/addition i can do given i have 6ND only. my ultimate goal is to enable A2DP and it really seems doable, just figuring out the right option to add.
Old Dec 2, 2014 | 11:02 AM
  #58
hp79's Avatar
hp79
I think it'll work fine. It's a basic wiring harness with one 500 Ohm resistor in it. I thought of building it myself, but then I can't beat the $5 price. Oh, and the one I ordered is not a regular ODB2 reader, it's actually a ODB to ENET for use with e-sys.
I don't think there's a normal ODB2 reader with an Ethernet for reading ODB2 codes. I've seen bluetooth, wifi, serial ports, USB, but not Ethernet ones.
This is what I bought. It's actually $5 not $4. lol.
edit: Works fine!
Attached Thumbnails Mini coding/programming-screen-shot-2014-12-02-at-11.03.55-am.jpg
Old Dec 2, 2014 | 11:34 AM
  #59
r33's Avatar
r33
I believe 6NE is what you need to enable the A2DP. Give it a try, it just won't work at the worst case scenario and just revert it back to 6ND.
I wish I have the same option where I can try it for you.
That seems to be right.
Old Dec 2, 2014 | 12:01 PM
  #60
TheBigNewt's Avatar
TheBigNewt
Don't know about you, but when my windshield is frozen the letters AC don't jump into my mind. That's weird the car does that by default. There are some aspects of the F56 I'm glad I don't have.
Old Dec 2, 2014 | 12:19 PM
  #61
DarkBlue15MCS
Most cars do this
Old Dec 2, 2014 | 12:20 PM
  #62
hp79's Avatar
hp79
No, this is one of those stupid things that are done by law in U.S.. All cars built after some year have this. Even if the AC light is not on, it's actually running. You can look at the rpm gauge or load levels if you use a ODB reader. I don't like that because I always try to dry out the vents every time I use AC, another reason I rarely use AC.
Old Dec 2, 2014 | 12:48 PM
  #63
papawhiskey's Avatar
papawhiskey
What ticks me off even more with this set-up, is that the car will stay in the mode with the A/C engaged until the ignition is turned off. I was able to defeat this in my 04 Nissan PU but I've been unable to in my 09 Tacoma, but am looking forward to doing it in the Mini. Not only is just moving air sufficient 90% of the time to clear your windshield, the lack of power consumption in having the A/C compressor off, has got to contribute to improved gas mileage.
OK I'm off the soap box again
Old Dec 2, 2014 | 03:16 PM
  #64
VYPUR's Avatar
VYPUR
Originally Posted by papawhiskey
What ticks me off even more with this set-up, is that the car will stay in the mode with the A/C engaged until the ignition is turned off. I was able to defeat this in my 04 Nissan PU but I've been unable to in my 09 Tacoma, but am looking forward to doing it in the Mini. Not only is just moving air sufficient 90% of the time to clear your windshield, the lack of power consumption in having the A/C compressor off, has got to contribute to improved gas mileage. OK I'm off the soap box again
Hey if you figure all this out I'm gonna have to pay you a visit and play around with it.
Old Dec 2, 2014 | 03:42 PM
  #65
UticaProf's Avatar
UticaProf
I don't know the answer to that but I understand the need. I drug my desktop out closer to the garage, my laptop is on the fritz.
I did enable the lights on reverse, but really can't see that it matters much.
Old Dec 2, 2014 | 04:30 PM
  #66
papawhiskey
I'm gonna get it. There ain't been a "steenking computer" that's beat me yet. Question is whether the car is still around when I get it or has it rusted away. I'll keep you posted. You can stop by and have a cold one while we tweak our Minis brains out!
Old Dec 2, 2014 | 06:48 PM
  #67
VYPUR's Avatar
VYPUR
Sounds like a plan.
Old Dec 3, 2014 | 06:39 AM
  #68
CooperB's Avatar
CooperB
Agree, but it looks cool!
E-Sys is a little overwhelming at first but once your start playing around it becomes much easier. Now if only they would add a option to auto translate the German to English under the FA it would be awesome! Wonder if the U.S. dealers have a cheat sheet next to the computers when coding or if they have just been around it so much they know the translations.
Old Dec 3, 2014 | 07:15 AM
  #69
fatherfork's Avatar
fatherfork
Originally Posted by CooperB
...Wonder if the U.S. dealers have a cheat sheet next to the computers when coding or if they have just been around it so much they know the translations.
My dealer doesn't have E-sys. I wanted them to make some changes and they said they could, but they hooked it up yesterday and didn't have any options to change. The software they have is just for diagnostics and updates. My dealer is only a couple months old, so perhaps they just haven't gotten around the tinkering with their system, but they definitely don't have E-sys-like capabilities.
So I ordered a cable and downloaded all the necessary files to do it myself. The cable should be here this week.
Old Dec 3, 2014 | 08:37 AM
  #70
DarkBlue15MCS
Even translated it doesn't make much sense.
Old Dec 3, 2014 | 04:00 PM
  #71
CooperB's Avatar
CooperB
I'm going to dump all the FDL coding to a word document and then run it though a translator at some point. There are thousands of lines of code... the handful of options that have been published only scratches the surface on what can be coded.
Old Dec 3, 2014 | 04:34 PM
  #72
hammerhands's Avatar
hammerhands
Could someone provide that text? I'm eager to look through it.
Old Dec 4, 2014 | 05:52 AM
  #73
CooperB's Avatar
CooperB
For anyone looking to code windows up, sunroof close, and mirrors fold in (if you have the power fold mirrors option) from the keyfob and/or comfort access button the guide published is not accurate. My working code is below.
Code:
BDC
3056 -> KOMFORTSCHLIESSUNG_FB  = Set Aktiv
3056 -> KOMFORT_SCHLIESSEN  = Set Aktiv
3110 -> ASP_BEIKLAPPEN = Set Aktiv
3110 -> ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = Set Aktiv
3110 -> ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = Set Aktiv
The guide tells you to adjust some WERTE values, this is NOT necessary. Do not change any of the WERTE values once you set the 5 options above as active (Aktiv). Save your coding, key cycle the vehicle and it should work. Of note, you press the lock button once on the keybob to lock the doors, press and hold again once locked until all your windows/sunroof close. You do not need comfort acces for this to work, however, if you have this option installed you can use the door button to accomplish what I am doing on my keybob. If you don't have power fold mirrors don't expect them to fold in on lock and out on unlock.
Hopefully this helps if your having issues getting this to work. I'm using E-Sys 2.26 and PSdZData 2.54.1 (lite). If you're only coding FDL (i.e. don't want to flash your ECU or adjust factory installed options from FA/VO) you don't need the full version of PSdZdata.
Old Dec 4, 2014 | 08:37 AM
  #74
DarkBlue15MCS
For anyone looking to code windows up, sunroof close, and mirrors fold in (if you have the power fold mirrors option) from the keyfob and/or comfort access button the guide published is not accurate. My working code is below. BDC 3056 -> KOMFORTSCHLIESSUNG_FB = Set Aktiv 3056 -> KOMFORT_SCHLIESSEN = Set Aktiv 3110 -> ASP_BEIKLAPPEN = Set Aktiv 3110 -> ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = Set Aktiv 3110 -> ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = Set Aktiv The guide tells you to adjust some WERTE values, this is NOT necessary. Do not change any of the WERTE values once you set the 5 options above as active (Aktiv). Save your coding, key cycle the vehicle and it should work. Of note, you press the lock button once on the keybob to lock the doors, press and hold again once locked until all your windows/sunroof close. You do not need comfort acces for this to work, however, if you have this option installed you can use the door button to accomplish what I am doing on my keybob. If you don't have power fold mirrors don't expect them to fold in on lock and out on unlock. Hopefully this helps if your having issues getting this to work. I'm using E-Sys 2.26 and PSdZData 2.54.1 (lite). If you're only coding FDL (i.e. don't want to flash your ECU or adjust factory installed options from FA/VO) you don't need the full version of PSdZdata. Video Link: http://youtu.be/mB-5wRTxG6Q
The werte value on one of those changes the delay after you press the button. I don't have my notes in front of me for which werte value to change
Old Dec 4, 2014 | 08:38 AM
  #75
DarkBlue15MCS
Are you talking about all the coding in the car or just confirmed working coding?
