F55/F56 Iphone's bluetooth connection lost
Old Oct 23, 2014 | 08:00 PM
Crimguy's Avatar
Crimguy
Happening intermittently. While speaking to someone the phone's bluetooth connection with the car is lost. Anyone else experiencing this?
iPhone 5s. ios 8.01
Old Oct 23, 2014 | 10:07 PM
bennetbecker's Avatar
bennetbecker
known issue
iOS 8 includes a new feature to disguise the physical MAC address of the device. This has been causing problems since iOS 8.01 was released. Luckily, they have released an update to correct this. Updating your phone to iOS 8.1 should correct this issue. Hope that helps!
Old Oct 25, 2014 | 09:28 AM
BRP27's Avatar
BRP27
I have an antique 4s iphone that cuts in and out on on Pandora on a 2015 MCS with the Mini Conneted. The software on the phone is iOS 7.1.2 and is listed as current in settings. Any ideas on why pandoora would cut in and out.
Old Oct 25, 2014 | 10:37 AM
bennetbecker
Hmmm you are using the USB to 30Pin Apple cable plugged directly into the car? Do you have to hit play again to start the music after it has stopped?
Old Oct 25, 2014 | 11:46 AM
BRP27's Avatar
BRP27
I am using bluetooth for the connection. The connection cuts out and then restarts after a moment of silence. No action required to reconnect
Old Oct 25, 2014 | 12:12 PM
BRP27's Avatar
BRP27
I hooked up the USB port to the same phone for the first time and pandora performed without interruption
Old Oct 25, 2014 | 12:32 PM
Crimguy's Avatar
Crimguy
Ok updated to iOS 8.1. So far so good.
Old Oct 25, 2014 | 11:16 PM
mikeymike1985's Avatar
mikeymike1985
So not having issues with maintaining a Bluetooth connection; however, is there any new input or feedback as far as getting the correct track and album artwork to show on the display? It would be a nice touch if it worked so I am using the split screen at all times with navigation on the left and minimalism on the right because it drives me nuts when it doesn't match up...
Filmy
15
Jun 6, 2023 06:27 AM
twriter
Oct 2, 2015 03:14 PM
minimofo
Sep 30, 2015 12:26 AM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
NHcountryman
Sep 6, 2015 11:01 PM
