F55/F56 Standard radio
Old Apr 30, 2014 | 05:36 PM
Mrdi's Avatar
Mrdi
Standard radio
Will the I Pod charge when connected to the standard radio if the vehicle is running?
Would be very inconvenient to remove it to charge daily.
Old Apr 30, 2014 | 07:52 PM
champ198's Avatar
champ198
Here is what I learned from my MA today. I called and asked if my F56 was missing the special Y cable for the iPhone/iPod like I got with my Coupe and Countryman. He said that BMW has designed the USB connection to work just like on your computer, meaning it will charge and connect to the car computer/radio. I don't have first hand knowledge of this, just passing this on because I haven't tried it.
Old Apr 30, 2014 | 07:59 PM
dwdyer's Avatar
dwdyer
It should, I haven't checked yet. However I was told if need the Y cable for the full MINI Connected experience, but I haven't played with it yet. Will do so this weekend.
Old Apr 30, 2014 | 08:01 PM
helipadforme's Avatar
helipadforme
This is correct. Audio plays and charges through the USB port on my standard radio. The folders and file names show up on the radio's display. It also shows up on the computer screen in the gauge.
Old Apr 30, 2014 | 09:49 PM
junkart's Avatar
junkart
I tested both wife's iPhone 5S and my Android with the radio. They work perfectly well ONLY on the stored audio files because the radio sees the phones as 'storage' and not as smart phone. It won't play Pandora, Youtube, Netflix, or anything like that through the USB and, unfortunately, neither through it's bluetooth.
Also, the USB only puts out standard 1A juice so it'll be slow a slow charge for some large phones/tablets.
Old Apr 30, 2014 | 10:22 PM
helipadforme
It will play Pandora if it is initiated from the iPhone. It even displays "Pandora" on the radio screen. If you use iTunes Radio, it also works and will display the artist and song, as if it was an actual file on your iPhone.
Old Apr 30, 2014 | 10:29 PM
rkw's Avatar
rkw
Bluetooth streaming audio is only included if you have MINI Connected. There is a Pandora app on MINI Connected, but not YouTube or Netflix.
Old May 1, 2014 | 04:07 AM
CobraBob's Avatar
CobraBob
If you do play Pandora, be sure to plug in your iPhone (USB) because your battery will drain pretty fast.
Old May 1, 2014 | 09:44 AM
dwdyer's Avatar
dwdyer
I found I was able to use Connected (XL at least) with just a USB cable for my iPhone 5, but will also try it with a cable that has separate audio like the BMW Y cable to see if that's better. It doesn't stream when connected over USB.
Old May 1, 2014 | 09:48 AM
MarcoPolo's Avatar
MarcoPolo
post i put up a few weeks ago to solve the playing music portion while having the standard radio by using bluetooth while simultaneously using the phones bluetooth feature for phone calls.
https://www.northamericanmotoring.co...ng-add-on.html
dwdyer's Avatar
dwdyer
Note that even with the standard radio you could use youtube/Netflix as long as you're going through the aux port.
Alpha Motoring
Sep 7, 2020 07:34 PM
pglgp1292
Oct 5, 2015 06:47 PM
simo711
Oct 1, 2015 05:36 AM
Emnotek
Sep 29, 2015 07:37 AM
