F55/F56 Hill Hold??
Old Mar 25, 2014 | 10:22 AM
papawhiskey's Avatar
papawhiskey
Hill Hold??
I heard somewhere that the new Mini with manual transmission will have what was called a "hill hold" feature that would add a slight delay to the brake release when you were on an inclined surface. This would help alleviate the dreaded "roll backwards down the hill into the bay" syndrome Bill Cosby talked about once as you were trying let the clutch out. Actually I heard it would work in both directions (activating if you were trying to back up-hill as well).
Can anyone confirm this? I've never had a problem but the wife finds it difficult occasionally.
Paul_F
Old Mar 25, 2014 | 10:28 AM
two250's Avatar
two250
They all should have it standard. My 08 has it. Works forward and reverse. It's also smart enough that it won't hold you from rolling downhill if that's the direction you want to go. It only prevents you from going the direction you don't want to go.
Old Mar 25, 2014 | 11:05 AM
CobraBob's Avatar
CobraBob
All F56 manuals will have the hill-hold feature. It works very well. One of the '13 MINI hardtops I test drove had it.
Old Mar 25, 2014 | 11:08 AM
MarioKart's Avatar
MarioKart
Vendor
Works great, in both directions on my GP. It's subtle and not intrusive
Sent from my iPhone Office
Ian Landesman's Avatar
Ian Landesman
In my 09, it activates if I have my foot on the brake. I am use to putting on the parking brake and releasing once the clutch engages, so I forget it's there.
Old Mar 25, 2014 | 11:19 AM
bmwr606's Avatar
bmwr606
works both up and down hill on my 03/2012 all4
must have the foot brake engaged when shifting into gear for it to work
if you use the hand brake and keep your foot off the brakes, hillhold will not engage
Old Mar 25, 2014 | 12:06 PM
gerry2153's Avatar
gerry2153
works great on my 12 MCS
Old Mar 25, 2014 | 12:15 PM
Angib's Avatar
Angib
It worked great on my 2009 R57 - but on my 2012 R59, it holds for such a short time as to be nearly non-functional. So not all cars are the same, as my dealer has confirmed.
One thing that helps on the R59 is to really press the brake hard when stationary as the hill-holder maintains whatever is the maximum pressure it senses and the extra pressure seems to help. This also helps when you are first getting used to the hill-holder as once it is holding the higher pressure, the brake pedal becomes rock hard, confirming it is holding the car.
bctf1
Jan 2, 2016 04:02 PM
buggyeye401
Oct 1, 2015 01:22 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Emnotek
Sep 29, 2015 07:37 AM
buggyeye401
Sep 28, 2015 04:09 PM
