subframe stuck..WTH
Old Sep 28, 2015 | 04:19 PM
buggyeye401's Avatar
buggyeye401
subframe stuck..WTH
ok so im servicing a bad rack n pinion. heres what I did. i removed everything needed to get the subframe off...bolts holding the frame, wires connecting the psp, bolts from the strut holding, low engine mount. bolt connecting stairing rod to rack n pinion. when i lower the frame..everything is lose except the rack n pinion and the stairing road BUT theres no bolts there????? wth????? any idea what could be holding it?
Old Sep 28, 2015 | 05:11 PM
Nicefeet's Avatar
Nicefeet
Did you disconnect the power steering tank from the fire wall?
Old Sep 28, 2015 | 05:41 PM
Da_Ghost's Avatar
Da_Ghost
You can get the rack out without lowering the subframe. I know it's not really helping your situation, but if you ever have to mess with it again, you can wiggle it out from the side.
Old Sep 28, 2015 | 05:44 PM
buggyeye401
Yessir...the hose would've teared if anything. From what I can see it's stuck at the starting rod and rack n pinion..any clue on how to nudge it loose?
Old Sep 29, 2015 | 01:32 PM
Post up a pic if you can. Thanks
The P/S tank and hoses can get caught on the engine bay and hold the rack hung up on the frame.
Old Oct 1, 2015 | 11:34 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have a subframe DIY removal here. Review it and see if you may have missed something.
888.280.7799 | 6am - 5pm PST
Old Oct 1, 2015 | 01:22 PM
JAB 67's Avatar
JAB 67
May I respectfully suggest that you edit your post to make clear that you are referring to the 'steering rod' (which is what protrudes from the steering column and connects the steering wheel to the rack n pinion) rather than the 'stairing road.'
maestro39
Oct 27, 2015 02:38 PM
buggyeye401
Sep 28, 2015 04:09 PM
minimofo
Sep 9, 2015 10:29 AM
bobbiemartin
Sep 1, 2015 10:46 AM
minipopkart
Aug 13, 2015 05:22 AM
