F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
2016 F55 S - A/C issues
Old May 22, 2022 | 11:20 AM
DeanoF55S's Avatar
DeanoF55S
Hello everyone. I have a 2016 Mini which I bought new and just looking for some help with my A/C issues. My wife and I love driving it but the A/C issue keeps us from driving it as much as we would like. When we initially start the car, the a/c is very cold and works as it should.
Once I drive it around an hour or so, the cabin will keep getting warmer and warmer as if the a/c is not working anymore. This happens when I use the hvac in manual or with the auto button. It's like when it needs to regulate the temperature inside, it doesn't start blowing cold air like it should. If I have the auto air temp set at the lowest possible, it seems to keep blowing cold air all the time. Of course it basically freezes you though. I can't tell if the a/c compressor is still running because it is impossible to see. Is there another way to tell if it is running even though its not blowing cold air?
We took it to the dealer several times during warranty but they could never replicate the issue. We figured when the a/c finally stopped working entirely, they could then find the issue. Here we are 5 years later and the problem still exists. I hate to take it in to the dealership and have them not find it again because I'm sure it will cost a fortune. To me it seems like a sensor or relay is not working like it should. I figured I would change out the interior temperature sensor since it is a pretty cheap part but I can't find anywhere that gives me the location of the sensor. No idea where it is located to change it. Anyone know where it is and how to get to it?
This is a frustrating issue that we have dealt with for way too long. I suppose even though the dealership has recorded the issue during warranty, we would still have to pay for the fix out of pocket, correct?
Any ideas? Thank you for your time.
Old May 22, 2022 | 01:15 PM
TVPostSound's Avatar
TVPostSound
As long as its documented that the problem existed under warranty, and was never fixed, you should push the issue.
Old May 23, 2022 | 06:18 AM
NBCGLX's Avatar
NBCGLX
Also, you should be able to tell if the A/C compressor is running, because the idle speed should be slightly higher than with the A/C off. If the A/C itself works, and it sounds like it does, then it’s likely a sensor or the HVAC controls that have gone bad.
Old May 24, 2022 | 09:13 AM
DeanoF55S's Avatar
DeanoF55S
There should definitely be documentation since an actual Mini dealership tried to do the diagnosis. I'll have to give them a call.
Old May 24, 2022 | 09:15 AM
DeanoF55S's Avatar
DeanoF55S
I'll give it a try tonight and see if it changes. I have a feeling its a sensor or relay somewhere or possible a loose connection. All I know its frustrating.
Old May 24, 2022 | 09:20 AM
DeanoF55S's Avatar
DeanoF55S
Also wanted to add that if I shut off the engine for a minute and restart, the a/c will work fine.
Old Jul 17, 2022 | 08:20 PM
cargusjoh's Avatar
cargusjoh
I hope you have resolution already. Curios what it turned out to be.
Old Jul 24, 2022 | 08:51 AM
Mr. Zenith's Avatar
Mr. Zenith
Hi Dean. A little late perhaps, but your symptoms sound exactly like those I experienced on my 2014 Toyota Tacoma. In my case the cause was exceedingly simple: the system was overcharged, showing approximately 40 psi on the low pressure side. We ultimately determined that the proper pressure was around 35 psi. Simply recovering that extra 5 psi did the trick.
Your mileage may vary (and the correct pressures for a MINI may be different), but it's worth checking as it's an extremely cheap fix.
Old Jul 27, 2022 | 12:44 PM
cjv2's Avatar
cjv2
I had the same thing happen with another not-MINI (a Subaru). Overcharge --> less cooling --> resolve overcharge --> cooling back to normal. Definitely worth asking someone at the shop to check, you never know.
elv
Mar 2, 2022 11:24 PM
Dae__
Jul 21, 2021 02:27 PM
Danscrazyhair
Jun 29, 2020 11:23 AM
Dr. Zoltar
Jan 22, 2012 06:45 AM
4GAZM
Jan 30, 2009 11:01 AM
