F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Retrofitting New LCI UJ Tail Lights
Old Apr 16, 2026 | 11:30 AM
  #176
Aderan's Avatar
Aderan
New NAM member, can't PM :(
@maaii Just got a good deal on some used UJ taillights and want to do this as well. Can I get the harness and instructions, please and thanks
Originally Posted by ilyart
My experience. Clubman 2017 by default all headlights and tail lights are halogen. Retrofitting with new Union Jack lights – new connectors, much deeper programming. Need an adapter between the old connectors and the new light. A difficult question for the encoding - brake lights. By default, they are only in the bumper.
Around the world experience
UK
Japan
Germany
Originally Posted by maaii
Hello sir
Yes, please open your PM I will send purchase link to you.
Originally Posted by Folo
Hello @maaii i'm planning do do this retrofit aswell, is possible to do it coming from halogen lights ? could you please contact me in PM ? Thanks a lot.
Old Apr 16, 2026 | 05:43 PM
  #177
maaii's Avatar
maaii
@Aderan PM sent
Old Apr 17, 2026 | 07:39 AM
  #178
jcw paul's Avatar
jcw paul
@maaii hi, i was looking for you on another forum and your frend sb2002 advised me to find you here.
I have oem taillights and harness from eBay. But I am not enough experienced to do it by myself. Are you able to provide me some instructions that will help me? My email is stajniakotowo@icloud.com
Old Apr 17, 2026 | 07:52 AM
  #179
maaii's Avatar
maaii
ok, I sent mail to you.
Old Apr 21, 2026 | 06:19 AM
  #180
Derf's Avatar
Derf
@maaii hi, I have installed oem taillights and harness from Aliexpress.
I have coded them with Bimmercode like in the video below but they don't turns on…
Are you able to provide me some instructions to help me with coding please ?
My Clubman is a 2018 model.
Thanks !
Edit 23 April 2026 : Hi, after some visual researches I realized that the black connector (the small one) of my Aliexpress harness version was mounted up side down !
I have to unpinned it, turn it to 180 deg and then repinn. I hope it will help someone who is stuck like I was.
Old Apr 21, 2026 | 06:37 AM
  #181
maaii's Avatar
maaii
@Derf PM sent
Thanks !
DIY Car Upgrade Mini Clubman S F54 To LCI Union Jack Tail Lights
Old Apr 29, 2026 | 08:22 AM
  #182
RobH912's Avatar
RobH912
Hi I have a 2019 Pre-LCI Mini Clubman S All4 and interested in retrofitting with new LCI UJ Tail Lights.
This is a long thread, over many years, and it seems like the most people have gone with @maaii solution, buying his adapter cables then doing some programming using BimmerCode. I have reached out to maaii with some questions which he has very quickly replied to all. I am comfortable with BimmerCode.
Just still a little confused on which tail lights to buy to use with maaii's adapter cables. ??
I see that esctuning.com has these LCI UJ LCI tali lights for sale, you need both a left and right unit each costing $436.99
https://www.ecstuning.com/b-genuine-...t/63217487795/
But I also see offered on esctuning.com this tail light set (both right and left units) costing $478.79 and being sold for an upgraded for Pree-LCI cars. No mention of adapter cables or coding necessary.
https://www.ecstuning.com/b-ziza-par...1-f5417-rd-a~/
Seems like there must be some difference in functionality between the two UJ tail light product offerings, but I don't understand what that is and which ones should I get to use with maaii's adapter cable. Big price difference between the two tail light products.
Thanks in advance for any thoughts.
Rob
Old Apr 30, 2026 | 10:13 AM
  #183
Aderan's Avatar
Aderan
Rob
The adapter cables that Maaii sells are to retrofit Genuine Mini taillights whereas the cheaper ECS lights are a knockoff version. I personally went with the Genuine Mini lights bc in the past, I have found that there could be visibility issues with cheap LED's not getting bright enough in the daytime. As for some cost savings on Genuine Mini parts, I would recommend searching on eBay for used left and right taillights. Just make sure that when buying the lights separately, the specs match (make sure they both say SAE or ECE). Otherwise you will have different coloured turn signals (SAE = Red turn signals, ECE = Amber turn signals)
Old Apr 30, 2026 | 10:47 AM
  #184
RobH912's Avatar
RobH912
@Aderan - Thanks for the information clarifying maaii’s cable and I’ll look for a set of Genuine Mini Tail Lights.
Rob
Old May 2, 2026 | 03:54 AM
  #185
Derf's Avatar
Derf
Originally Posted by FRPhilippe
However, I had to forget something with bimmercode because the brake lights do not take the full width and simply the shape of the fog lights of the LCI versions.
Could someone please help me by sending me the exact Bimmercode instructions to correct this? That would be great🙂
Best regards✌️
Hi, I'm stuck at this step, did you fixed that ?
I'm very interested by the solution.
Old May 2, 2026 | 07:40 AM
  #186
F54visp's Avatar
F54visp
Hello everyone,
I was able to get a set of 2022 OEM UJ Tail lights for cheap. I see the adapters with the blue connectors are widely available on eBay. But there don't seem to be any clear instructions on how to do the cable swaps in the footwell. I understand I'll need a tool to remove the cables, but do I need any extra cable for the wiring? Are they available to purchase? Does anyone have any more detailed instructions?
Thanks! Pat
Old May 4, 2026 | 02:14 AM
  #187
Derf's Avatar
Derf
Hello,
Maybe this video could help you…
Old May 10, 2026 | 07:40 AM
  #188
Derf's Avatar
Derf
Originally Posted by F54visp
Hello everyone,
Thanks! Pat
Hello, Is that clearest for you ?
Old May 10, 2026 | 11:14 AM
  #189
F54visp's Avatar
F54visp
I was able to figure it out. I had to ChatGPT how to slide the connector out of the cover. But other than that it’s wasn’t bad.
Old May 10, 2026 | 12:35 PM
  #190
Derf's Avatar
Derf
When you brake, do the brake lights or the fog lights appears ?
Old May 11, 2026 | 07:23 AM
  #191
F54visp's Avatar
F54visp
Yes. I actually did have an issue with the brake lights, but it was because I had swapped the wrong pin 32 cable. But I did notice that the brake lights are now only on the UJ lights and not the bumper lights. I’m in the US and apparently we don’t have rear fog lights. Are the bumper lights useless now?
Old May 11, 2026 | 07:38 AM
  #192
maaii's Avatar
maaii
If you have the correct coding, the light on the bumper will illuminate when you open the tailgate.
Old May 11, 2026 | 07:57 AM
  #193
F54visp's Avatar
F54visp
Just tried it and they don’t light up. Do you have the coding required to do this? I’m using Bimmercode.
Old Yesterday | 03:55 AM
  #194
Derf's Avatar
Derf
Great ! Good job ! For my part I'm still stuck with my fog lights instead of the brake lights…
FRPhilippe, nosidept, pasaporte,anyone could help me please ? Should I contact Bimmercode ?
EDIT : I ended up swapping the wires for the rear fog lights (green) and the brake lights LEDs (black N/A) on the small black connector of my AliExpress adapter.
Hope that will help someone.
Sell224
Jul 25, 2021 01:06 PM
ca$per
May 23, 2007 02:12 AM
Sell224
16
Sep 4, 2006 10:39 AM
