F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Retrofitting New LCI UJ Tail Lights
Old Mar 1, 2021 | 03:59 PM
  #101
Edward Jeong's Avatar
Edward Jeong
Originally Posted by Walt
Up near the top, on the right, you should see "Edward Jeong" with down arrow immediately after it. Click on the arrow, and select Private Messages.
Or, also up near the top, on the right, you should see "Welcome, Edward Jeong". Two lines below that, you should see the link Private Messages (in blue, underlined).
Dear Walt,
Thank you for your help.
Old Mar 2, 2021 | 12:16 PM
  #102
Edward Jeong
Need help guys,
Can you please help me if the UJ Taillight will fit on my 2017 F54 Clubman S? It is very basic trim, no LED taillight.
If yes, which part should I get? ECS Tuning says it doesn't fit on mine.
Old Mar 13, 2021 | 04:11 PM
  #103
Paddington_F54's Avatar
Paddington_F54
Originally Posted by maaii
Change Brake lights and fog lights on BDC_ECU side. The fog lights will on bumper.
@maaii
Just help me understand:
I need to swap the:
A258*2B (black/yellow) by the A258*5B (grey/yellow)
and
A258*5B (black/yellow) by the A2528*2B (grey/yellow)
How do I know which right black/yellow wire (see my picture below) and is just pull the wire and then push?
Old Mar 13, 2021 | 05:17 PM
  #104
maaii's Avatar
maaii
can you just check the “PIN number” In the plug ?
Originally Posted by Paddington_F54
@maaii
I need to swap the:
and
Old Apr 8, 2021 | 11:06 PM
  #105
iura1966's Avatar
iura1966
Hello dear.
Please help me to coding Mini F54 2016 US after installation UJ tail Lights. There were halogen lamps in the car.
I put the lights in the car. STOP connected in parallel STOP lamps in the bumper (STOP lamps in the bumper work together withUpper lights UJ) .
With E-sys, I removed the hot and cold checks lamp:
BL L / R
BFD L / R
FRA_H L / R
The lamps work, but an error appears on the instrument panel:
STOP lamps left and right are defective.
I read car ISTA+, 2 errors:
- 804883 Left split door tail light output faulty
- 804885 Right split door tail light output faulty
In E-Sys, I looked at the Mapping values ​​for the taillights:
MAPPING_BREMSL_1 = bl
MAPPING_BREMSL_2 = off
MAPPING_BREMSL_m = bl_m
MAPPING_BRAKEFORCED_1 = off
MAPPING_BRAKEFORCED_2 = bfd
MAPPING_BRAKEFORCED_m = bl_m
MAPPING_BLINKER_H = fra_h
MAPPING_BLINKER_2_H = bfd
MAPPING_PARKL_H = sl
MAPPING_PARKL_H_2 = bl
MAPPING_STANDL_H1 = sl
MAPPING_STANDL_H2 = bl
How can I remove the tail light error?
Understood ... The question is closed.
Old Aug 10, 2021 | 06:11 PM
  #106
Karsoon's Avatar
Karsoon
Coding for F54
hi Mai, I have just ordered the UK Tail Lights, just wonder if u can teach me which code I should do? If I got the harness do I still need to swap the pin for the brake light? Thank you
regards
Karskkn
QUOTE=maaii;4556159]Hello sir
Yes, You can use bimmercode to code it, but a lot of items you need to code it one bye one
please open your PM or leave email I will contact with you.
Thanks[/QUOTE]
Old Oct 14, 2021 | 04:23 AM
  #107
ongai hoa's Avatar
ongai hoa
Originally Posted by Luk84
my pm are opened
Thank you
Hello Ken
You can use bimmercode to code this UJ taillights.
But you need to code it one by one. Many items need to code.
hai ... freinds can u pm me bimmer code for coding f54 uj tail lamp
Old Oct 14, 2021 | 04:44 AM
  #108
ongai hoa's Avatar
ongai hoa
Need help .... have anyone know use bimmer code for coding mini clubman f54 union jack taillight
all wiring is done .... all light is working well , just flag light not working ......
Old Jan 5, 2022 | 10:50 AM
  #109
bigsteve1635's Avatar
bigsteve1635
Mini original instructions for fitting Union Jack rear lights https://www.minif56.com/attachments/...459-pdf.73703/ seem to be much more complicated than the simple loom on here.
Old Feb 27, 2022 | 06:15 PM
  #110
BendersMINI's Avatar
BendersMINI
Another success!
Many thanks to @maaii (via @rfuller26 ) for the harness and excellent instructions! Another successful update to the UJ lights!! I am so in love with this look.
Sharp new UJ lights!
Old Mar 12, 2022 | 04:31 PM
  #111
Mario91's Avatar
Mario91
hi,
@maaii do you ship also to Poland ? i have 2016 F54 with LED light 563 option. I assume some additional wiring will be needed to convert to UJ Tail Lights ?
Old Mar 14, 2022 | 11:45 AM
  #112
Samuelscholey's Avatar
Samuelscholey
Please help!
Problem solve. I made two adapter cables to retrofit UJ Tail Lights. It's so easy to do.
After coding, no error message pop up.
I have just purchased the Union jack tail lights and discovered that there is an issue with retrofitting. They haven't turned up yet but I'm sure I'll have the issue with the wrong connector. How has everybody overcome this?
Old Mar 16, 2022 | 08:31 AM
  #113
isthisjohn's Avatar
isthisjohn
Would like help finding the wiring adaptors too - please PM me with details
Old Mar 17, 2022 | 06:57 PM
  #114
maaii's Avatar
maaii
PM’d
Old Apr 20, 2022 | 03:04 AM
  #115
AnthoF54's Avatar
AnthoF54
Bonjour,
J'ai acheté le Kit de post-équipement de feux arrière Facelift 63 13 2 473 459 chez MINI en France, réalisé l'installion comme ils le préconisent, fait réalisé le codage transformations (chez Mini, 119€...)
Mais j'ai un PB, tout fonctionne sauf le UJ arrière gauche. Mini m'ont dit qu'il doit y avoir un problème dans mon cablage, mais non, tout est conforme.
En cherchant pourquoi cela ne fonctionne pas, je m'aperçois que sur la broche 54 du BDC A258*3B il n'y a pas de tensions, d'où le fait que le UJ ne s'allume pas !
Pouvez-vous m'aider ?
Merci par avance car Mini me dit que je dois payer s'ils doivent regarder alors que j'ai identifié le problème (pas de tension en sortie de broche 54...)
Est-ce un problème de codage Mini ? Un problème de cablage ?
Old Apr 22, 2022 | 12:55 AM
  #116
dannyvdm's Avatar
dannyvdm
nice
i have them too
Old Apr 22, 2022 | 02:15 AM
  #117
AnthoF54's Avatar
AnthoF54
did you do the assembly yourself or at Mini? and coding / programming at Mini?
Originally Posted by dannyvdm
i have them too
Old Apr 22, 2022 | 02:30 AM
  #118
dannyvdm's Avatar
dannyvdm
myself with NDH in netherlands...was nice job ...we did some cables...NDH some coding
working GREAT !!
(now we will do headlights led) in progress
Old Apr 22, 2022 | 03:09 AM
  #119
AnthoF54's Avatar
AnthoF54
I think Mini must have done bad coding or forgotten coding. I don't see anything else. it is not normal that there is voltage coming out of BDC 5 for the right UJ light and not from BDC 3 for the left UJ light... I would just like to be sure so as not to have to repay unnecessarily
working GREAT !!
Old Apr 22, 2022 | 03:26 AM
  #120
dannyvdm's Avatar
dannyvdm
ja alles goed nakijken ... ik zoek nog twee led headlights voor de F54
mag lci zijn of gewoon led
Old May 8, 2022 | 05:45 AM
  #121
Cx747oc's Avatar
Cx747oc
What about, when you open the doors, do the lights in the bumper then still go on? this is a safety feature so the car is still visible when the doors are open. Does it still work after this mod?
------> Yes, use fdl coding can solve this issue. Please check the pic as below.
All function works and without error. only fog light on bumper is different with LCI.
fog light
reveresing lights
Brake lights
Turn indicator
https://imgur.com/Km9ia9s
Hi, Maaii,
May I know how to code it? Does Bimmercode can do the same? Appreciated for your help.
Old May 14, 2022 | 07:59 AM
  #122
fritzwollmuetze's Avatar
fritzwollmuetze
Old May 15, 2022 | 03:11 AM
  #123
maaii's Avatar
maaii
PM’d
Old Jun 3, 2022 | 01:15 PM
  #124
Narfsmart's Avatar
Narfsmart
Hi maaii - please can you send me coding instructions? I've installed the lights and have bimmercode but not quite sure how to get them working.
Thank you so much.
Old Nov 22, 2022 | 03:53 PM
  #125
SavioDuarte's Avatar
SavioDuarte
Harness adapter for retrofit
Hello sir
Yes, please open your PM I will send purchase link to you.
Hi there, I turned a 2017 clubman into a pick up and bought union jack taillights. I need the adapter wires you make. Do you still have those? Please help. Thank you
