F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Retrofitting New LCI UJ Tail Lights
Old Feb 12, 2020 | 07:18 AM
  #26
sambir's Avatar
sambir
Looks like a euro kit and not available in the USA yet
Looks like its the taillights and then wires/plugs for conversion. One of the wires is not available on its own yet. Not out yet.
it is yet a kit without cables. only lights and some sort of manual....
Old Feb 12, 2020 | 07:25 AM
  #27
All i can tell is its the lights and some sort of wire harness, much like that one above. I dont see a manual.
Old Feb 12, 2020 | 08:07 AM
  #28
sambir's Avatar
sambir
I ordered63132473459. I hope it includes some harness. If not i have to order a harness from Maaii.
Old Feb 16, 2020 | 02:34 PM
  #29
Poverty1's Avatar
Poverty1
Hi any updates on this retrofit in UK
I’ve ordered the lights but got nothing else 😳
Old Feb 16, 2020 | 03:17 PM
  #30
sambir's Avatar
sambir
63132473459 is unavailable until 2020-06. So i ordered 2 lights seperatly. With black trims 63217487793 and 63217487794
Old Feb 16, 2020 | 06:09 PM
  #31
maaii's Avatar
maaii
Hi Sir
I already sent the adapter cables to sambir. He will try to install it and report to all.
Old Feb 16, 2020 | 10:38 PM
  #32
Poverty1's Avatar
Poverty1
Originally Posted by maaii
Hi Sir
Standing by
thanks all 👍
Old Mar 1, 2020 | 06:06 AM
  #33
Poverty1's Avatar
Poverty1
Hi I got my Union Jack rear lights all fitted and working thanks to ‘maaii’
the loom adapters provided and wiring / coding instructions worked a treat
All working fine doors closed
a
All working fine doors open
Old Mar 2, 2020 | 10:59 PM
  #34
sambir's Avatar
sambir
Same here in NL. Lights installed and working fine.
initially had errors. I got strange warnings and sounds from te car after removing 258*5 bdc for shifting cables. But i should have unplugged the battery. It was all resolved after letting the car sleep.
EDIT: 1 month later. Notices still had errors on right tail light. Tested the light and it seems to be broken. Dealer wont exchange for a new one because my car "does not support the light" so they cannot confirm if the light is broken...
EDIT: installed new right light all works fine now. Also updated the coding according to original lci coding
Old Mar 14, 2020 | 01:53 PM
  #35
Jas31483's Avatar
Jas31483
Does anyone know to to enable rear fog lights on a 2020 LCI F54 with the factory UJ Taillights? I have the switch installed, activated the switch and changed mapping output and function via coding but every time I enable the rear fogs I get the yellow indicator on the speedo but no rear fog lights. I know the LCI has the rear fog in the actual brakelight vs the rear bumper but I cannot seem to get it to activate.
Old Mar 14, 2020 | 08:01 PM
  #36
Eric_Rowland's Avatar
Eric_Rowland
Is the coding the same as for the regular tail lights? Mine lit only the dash light with the first code (3068), then activated with the 3064 changes.
"From the Bimmercode App thread:
"Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, then cycle ignition, then restart Bimmercode for the below options
to show up
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht:""
Old Apr 1, 2020 | 04:56 AM
  #37
Dylan Vanspeybrouck's Avatar
Dylan Vanspeybrouck
Still have one of these?
Hi!
you still have one of these? Sending to Belgium? 😋
Hi Sir
I don't have part numbers from Mini, this is my handmade retrofit kit.
PM me if you like.
Old Apr 2, 2020 | 12:49 AM
  #38
maaii's Avatar
maaii
Hi Dylan Vanspeybrouck
I had some cables of UJ retrofit kit.
Due to “COVID-19” I can't ship this cable to your country from Taiwan.
Sorry.
Old May 11, 2020 | 12:43 PM
  #39
anjing82's Avatar
anjing82
where are you based?
looks really complicated to do?
I’ve bought the kit today and got the lights this morning off eBay
a
Old May 17, 2020 | 07:45 AM
  #40
Hanss70's Avatar
Hanss70
I also installed the UJ taillights with help from Maaii. I could not have done it without his help. He made the wiring kit and a perfect install guide. Thanks again Maaii.
Old May 18, 2020 | 08:38 AM
  #41
Looks good.
These looks like the black line US union jacks :
Tail Light Union Jack F54 LCI Black Line - Left 63217487795
https://www.ecstuning.com/Search/Sit...h/63217487795/
Tail Light Union Jack F54 LCI Black Line - Right 63217487796
https://www.ecstuning.com/Search/Sit...h/63217487796/
Old May 18, 2020 | 09:36 AM
  #42
zagman's Avatar
zagman
Do these include the correct wiring harness? Or will we need to order it from one of the people on this thread? I am excited to see them State side!
Old May 18, 2020 | 10:00 AM
  #43
LCI cars plug and play 2020+
Pre LCI cars they will need the wire adapter in this thread.
Old May 22, 2020 | 05:24 PM
  #44
msudawg's Avatar
msudawg
Deleted
Old May 22, 2020 | 05:26 PM
  #45
msudawg's Avatar
msudawg
Deleted
Old May 23, 2020 | 12:32 AM
  #46
msudawg's Avatar
msudawg
Proper tool to remove pins for F54 UJ tail light retrofit
I received the black line lights today and have the harness, but could not remove the pins all the way out of the harness at the A-pillar. For those that have done this, is there a tool or certain method to easily and safely remove the pins for the first part of the modification? Any help would be greatly appreciated.
Old May 24, 2020 | 01:00 PM
  #47
msudawg's Avatar
msudawg
Looking for some help. I have just installed the Union Jack taillights (was able to eventually remove the pins) on my 2016 Clubman S and everything is working fine (brake lights, bumper lights (door open), reverse lights, and L/R turn signals. All look good. I do get the following error messages on start up and shut off.
Left brake/tail lamp malfunction
Right brake/tail lamp malfunction
Beyond the error codes, everything else seems to be working fine. Would someone who has also done the same retrofit be willing to help me clear the two error codes?
I would specifically like to discuss the coding steps you completed/did not complete as provided by the author.
I am SOOOO close to having this process completed, so Any help to clear these error codes would be very much appreciated.
Thank you in advance!
Best!!
Old May 24, 2020 | 05:51 PM
  #48
msudawg's Avatar
msudawg
Quick update: I was able to clear the codes using Bimmercode. Thanks to The MINI Vlog for the answer. His YouTube channel is definitely with a look, like and subscribe. You can watch the video here on his F56:
Thanks to sambir and Hanss70 for responding to the call. I appreciate your friendliness. Thanks to maaii for coming up with a nice LCI upgrade to the Union Jack.
Old May 24, 2020 | 07:29 PM
  #49
maaii's Avatar
maaii
Congratulations, You can post your car of LCI taillight on this thread. It's very beautiful.
Old Jun 19, 2020 | 03:05 PM
  #50
ouzbek39's Avatar
ouzbek39
hello i would like to do the change, do you sell cables? thank you
