Electrical Radar Detector Fuse Add-in
Old Jun 29, 2006 | 09:13 PM
Adnuo's Avatar
Adnuo
I just recently got my Cobra radar detector hooked up to my MINI the same as I've hooked it up to every other car I've owned, by using an add-a-circuit and adding it into the cabin fusebox. However, I've encountered a very strange problem -- it seems that on the MINI, when everything is turned off and the key is removed from the ignition, the power is cut from everything after the fusebox, meaning that my radar detector stays on when everything else turns off. I've tried many different fuses, everything from the radio to the windshield wipers and I can't get it to turn off with the key.
Anyone encountered a problem like this, and hopefully found a solution?
EDIT: Shoot, I just realized the Electronics forum includes radar detectors :s. Sorry guys! Hopefully someone sees the thread here.
Old Jun 29, 2006 | 09:26 PM
qwertmonkey's Avatar
qwertmonkey
I am sure someone here will have an answer as hundreds of people have done this.
There has to be a way...
Old Jun 30, 2006 | 06:35 AM
jwardell's Avatar
jwardell
You must have just tapped an always-on fuse.
I have a guide here on how to do it:
http://www.jwardell.com/mini/fusetap.html
Old Jun 30, 2006 | 09:23 AM
Adnuo's Avatar
Adnuo
Awesome jwardell, thanks a ton! I must have just tried fuses that were all always-on, what luck :/. Works fine now!
Old Jul 1, 2006 | 06:21 AM
Jersey_Bill's Avatar
Jersey_Bill
Man I love this site...
I was going to do my first add-a-fuse today for a Sirius aftermarket unit and sat down to do an hour of searching for several questions. This thread just answered all of them...
Thanks !
Bill
Old Jul 3, 2006 | 10:16 AM
jwardell's Avatar
jwardell
Glad it helped.. Do you have an 05 or 06? I'm not sure if they changed the fuse layout or not.
Old Jul 3, 2006 | 08:40 PM
Jersey_Bill
'06 Cabrio - the fuse box layout is different from some I have studied in the Bentley manual and other places but the advice still worked well and I got my aftermarket Sirius wired up in 30 minutes or less, including running the antenna back to the roll bar area (works great there in a cloth top !!)
Bill
Old Jul 3, 2006 | 09:33 PM
Motor On's Avatar
Motor On
I managed to find a switched 10A fuse just below the halfway point on the right of an 05 hardtop. Which model Cobra, mine had (no longer use it, soon upgrading to V1) an auto off so even if I tapped an always on it would automatically cut the power after 30min of no RPMs.
PsychoRallye
21
Feb 17, 2019 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
mni928
Nov 9, 2015 07:38 PM
Chefben63075
Oct 1, 2015 12:04 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
