Electrical countryman after battery problem no turn signals and no front window,whats wrong?
Old May 25, 2015 | 12:34 PM
arielmoura's Avatar
arielmoura
I have a 2011 countryman s , after replaced a bad battery the turn signals don't work and the front windows too, and a red car in a lift appear in red, whats wrong and what is the solution, thanks
Old May 25, 2015 | 12:49 PM
buzzsaw's Avatar
buzzsaw
Are all connections tight including grounds?
Old May 25, 2015 | 01:16 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Codes? If you don't have an obd code reader you should get one.
Old May 25, 2015 | 01:30 PM
BoCRon's Avatar
BoCRon
Did you replace it yourself?
We just did the battery on our '11 Countryman. We took it to a local certified MINI place (not a dealership). I'm glad we did, it ended up being a pain plus apparently you have to register the battery and do some coding.
Annette
Old May 25, 2015 | 02:50 PM
mikey_t's Avatar
mikey_t
Annette
What she said!
arielmoura's Avatar
arielmoura
all connections are tight an d also the lights are on all the time, just outside I can't turn the lights off, and no light in the cluster, somebody told me is some kind of safe mode
Old May 27, 2015 | 09:29 AM
mikey_t's Avatar
mikey_t
Re-read post#3.....
Old Aug 15, 2015 | 09:01 PM
Garo Shant's Avatar
Garo Shant
Coding. What codes? i have the same problem in my 2011 Countryman S.
NYXF56JCW
Nov 17, 2024 05:06 AM
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
dyeLucky
Aug 7, 2015 07:10 AM
nismo4life
Aug 5, 2015 08:31 AM
