Electrical oem xenon 25w retrofit kit??
Old Jan 3, 2014 | 09:31 AM
  #26
r34king's Avatar
r34king
The tsb from mini doesn't say anything about coding. Its just plug and play
Old Jan 3, 2014 | 09:49 AM
  #27
Can you post up the TSB , there has been very little info on these? See post #20 in this thread with the link.
Old Jan 3, 2014 | 08:31 PM
  #28
Aikmanson's Avatar
Aikmanson
More info would be great. On WMW it mentions a straight plug and play, the link from ECS mentions a re-code.
Very curious, the lights are the only thing I dislike on my MINI.
Old Jan 4, 2014 | 07:49 AM
  #29
bmx045's Avatar
bmx045
soooo tempting. this kit looks simply like oem headlights. we do know that the harness plug from halogen car plugs right in to the oem hid headlights, so i dont know whats different with this "plug and play" kit. if its a coding that can be done through ncs expert i might just do that and find oem headlights second-hand
Old Jan 4, 2014 | 07:57 AM
  #30
bmx045's Avatar
bmx045
cheapest oem HID headlight assembly i can find are $349 each on rockauto.com. but they don't come with the washer arm, so, would still need to buy those.
Old Jan 5, 2014 | 10:58 AM
  #31
MrRaD's Avatar
MrRaD
sewell parts shows no coding needed
http://http://mini.sewellparts.com/a...2012/6704.html
Old Jan 9, 2014 | 03:25 AM
  #32
r34king's Avatar
r34king
Sorry for the late response. BMW seems to have taken down the tsb and the install instructions. Iv seen it before. It just says plug and play. I've also verified with a set in house that they are plug and play. Unfortunately I didn't take any pictures. If we have another set I'll get some pictures for you guys
Old Jan 9, 2014 | 07:11 PM
  #33
Aikmanson's Avatar
Aikmanson
What year car? Programming required?
Old Jan 9, 2014 | 07:58 PM
  #34
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've had 2 people install them and they were just plug and play.
Old Jan 10, 2014 | 03:25 AM
  #35
r34king's Avatar
r34king
2011+ I believe is what they are for. I'm not sure about any older years. I'll see if we have some at the shop and do some testing
Old Jan 10, 2014 | 04:55 AM
  #36
We have a thread running here on the programming issue. From what some people are posting, looks like they plug and play, but have a strobe effect on start up, which might require coding. In general the headlights are for 9/2009+ production.
https://www.northamericanmotoring.co...ml#post3864765
Old Jan 10, 2014 | 05:50 AM
  #37
Aikmanson's Avatar
Aikmanson
Some people say programming is required, some say it works without. I believe both parties, I'm just curious if the year of the car has something to do with it. Also, are all of these test cars fit with stock halogens, or xenons from factory? Information like this will help give us an idea of what is going on.
So if you have tried these, what year was the car, and what lights does your car have stock (assuming halogens, but you never know)
Old Jan 14, 2014 | 07:46 AM
  #38
got-m1ni's Avatar
got-m1ni
Has anyone purchased these and had them installed yet? I'm interested in feedback of the lighting and output vs. the stock halogens and if there's any comparison to the stock xenons (35W) vs. these retrofit (25W) (pics?)
My dealer advised cost is $500 per headlight + $365 labor and about 2.5 hrs of labor time with programming required.
Old Jan 15, 2014 | 03:09 AM
  #39
LFCMCS's Avatar
LFCMCS
Old Jan 15, 2014 | 06:30 AM
  #40
OwenRW's Avatar
OwenRW
Has anyone tried these on a pre-2009 car yet?
What is the difference between say a 2007 and 2009 model which would render these incompatible?
Old Jan 15, 2014 | 08:12 AM
  #41
yetti96's Avatar
yetti96
Electronics have changed a bit. I did a D2S retrofit with stuff from theretrofitsource.com and had no issues on my '09 R56. When I traded in and got a '10 R55, the lights worked just fine. But, after the re-check or hot check of voltage the car would tell my I occasionally had a headlight out (after about 30 minutes driving) and none of the lights were out. I had this coded out at MOTD last year and forgot about it but yeah, my 2009 and 2010 were different with regards to headlights and the wiring/programming of the car.
Old Jan 18, 2014 | 10:40 AM
  #42
MiniC9999's Avatar
MiniC9999
I have an 09 with a 8-08 build date, I'm assuming I'd be out of luck getting these to be plug and play? Also, anyone have any pics after with the retrofit installed?
Old Jan 18, 2014 | 11:51 AM
  #43
LFCMCS's Avatar
LFCMCS
This is what I got as a response for installation on my 2011 MCS: "There is a dealer coding that is required or else the lights will pulsate. Here at our dealership we charge one hour in labor to complete the programming. Check with your local MINI Dealer and they can quote you a price for the programming". This is from a Flow MINI Raleigh. Based on the description, I thought the LCI 2011+ vehicles did not require coding.
Old Jan 18, 2014 | 03:43 PM
  #44
a2oc's Avatar
a2oc
What about the pre LCI cars, do they have no chance at all to fit those lovely xenons? I got a 12/2008 car and asked the dealer about that and they give me a $3.5k quote to do it in the traditional way, 35w xenons (not 25w), washer, wiring, self leveling, etc......
Old Jan 18, 2014 | 05:38 PM
  #45
got-m1ni's Avatar
got-m1ni
I will try to post some pics.
Old Jan 22, 2014 | 05:07 PM
  #46
LFCMCS's Avatar
LFCMCS
Got some feedback from the dealer. Apparently they have installed them on LCI cars and they all needed to be coded. They are not compatible with pre-LCI cars.
Old Jan 22, 2014 | 05:15 PM
  #47
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Yeah they work great until the MINI is started up. Then they flicker like a strobe light.
Old Jan 23, 2014 | 06:06 PM
  #48
got-m1ni's Avatar
got-m1ni
Not sure if the cut off is suppose to be this short?
Is this normal?
Old Jan 23, 2014 | 06:09 PM
  #49
got-m1ni's Avatar
got-m1ni
Also, feels like they are aimed a bit low...never had xenons, anyone can tell me if normal? The same "handle" in the top picture is not very evident as in the bottom with the xenons on.
Sorry for the large sizes.
Old Jan 23, 2014 | 06:24 PM
  #50
bmx045's Avatar
bmx045
You need to level them. There's DIY threads all over google on how to.
