R56 R56 - Halogen to Bi-xenon
I've bought 2nd hand Bi-xenon headlights set for my R56.
Does anyone know what I should do for replacement of Halogen headlights?
I know it's quite complicated...anyway...really look forwards for the new outlook!
Not likely. The upgrade option to Xenons might be $500 at the time of ordering, but if you're thinking of P/N 63120422185, that's just the wiring harness. The cost in parts to get an OEM setup comes to around $2,000 for new headlamps, ballasts, the washers, etc., etc..
Best alternative is around $1000 for the Black Flame Customs setup. They build you a set of Bi-Xenon lights using aftermarket housings and Morimoto projectors. No washers or leveling, though, but still a MUCH better alternative than putting Xenon bulbs in a halogen housing.
Xenon Upgrade for MINI's with Halogen
For MINI's manufactured after 9/09, you can get this brand new and "somewhat" plug and play kit from MINI.
Instead of chrome or black, these are what I would call anthracite. They are same as the OEM ones using a little flipper for the bi-xenon. While you will see these advertised as "plug and play" they are not. The Xenon programing has to be activated otherwise once the car is started, the headlights will flicker like a strobe light.
They retail for $500.00 per side. While expensive, a viable solution if you wanted Xenons but your MINI didn't come that way from the factory. We fired up a 2010 with a set of these yesterday. They have the same factory cut off, and while they are 25watt, are very bright.
Sold individually. No additional parts required, and no instructions in the box.....I was not able to find any directions from MINI/BMW on these yet.
#63102347698
#63102347700
#63102347698
#63102347700
Yea, there is little info on these, there was a person who might had coding problems, but that was on a Euro set and not the US set. They might have just not coded it right.
They are called Titanium Gray, but from your pic gray raven they do look a little more anthracite.
Here is a link to the parts. 9/2009+
63102347698 & 63102347700 US set.
https://www.northamericanmotoring.co...-not-work.html
#63102347698
#63102347700
#63102347698
#63102347700
From the looks of your post you already have a set of OEM Xenon lights, Correct? Check the compatability of the wiring first and go from there. Like others said, even after they're installed you may have to get your car reprogrammed to recognize the option. You saved a chunk of change by having the OEM set to use in the conversion.
I had a local company near me do mine and they are fantastic. The visibility is 9.5/10. I paid $650 all together and they haven't done more than two MINIs. There's a thread on here by them somewhere. And a couple of pictures of my headlights on my car(I have halos too).
I just installed these headlights (#63102347698 #63102347700) yesterday and yes, re-programming was needed. Cost for programming at MINI dealer was very high and took long time as well(approx. 4HRs).
4 hours to reprogram a car for xenons?? So at MINI dealership rates of like $200 an hour....it cost $800 to program a car just for xenons?
That sounds awful and I'm throwing up a BS flag towards that dealership.
Most shops charge 1hr programming.
4hrs is insane.
We have them right here:
Xenon Headlight Titanium Gray 25 W - Left part # 63102347698
http://www.ecstuning.com/Search/SiteSearch/63102347698/
Xenon Headlight Titanium Gray 25 W - Right Part # 63102347700
http://www.ecstuning.com/Search/SiteSearch/63102347700/
Same amount of work. 200F for 5-7 min and slowly work the seal.
Does the plastic lens soften when baked for 5-7 mins or just the sealant that holds everything together? I've thought about Joey Modding mine (mine are halogens), but I'm a little nervous about damaging the lights. Also, to put them back together, do you just bake them again, or is there a need for new sealant?
These titanium headlamps shown above --- are they an exact duplicate of the factory OEM's? I'm hoping they are - they just look so simple in the above photos, that it has me questioning...
Do they come in a darker color? I would love the black internal housing.
Any help would be greatly appreciated!
