Electrical oem xenon 25w retrofit kit??
Old May 26, 2022 | 09:22 PM
  #226
JWA's Avatar
JWA
Originally Posted by JWA
When I turn on the lights with the key in the accessory mode but the engine not started the lights look great. When I start the car and remain still, still great. However, when I put the car in gear after a couple seconds both lights begin to very subtly flicker.
In the end this thread helped me find the solution:
https://www.northamericanmotoring.co...ml#post4623298
I had to set PWM_AL to wert_01.
Old Jun 1, 2022 | 03:35 PM
  #227
sub3622's Avatar
sub3622
I would like to put this xenon 25w retrofit kit set in my US spec R56 but the one i would like to buy would be the black european version (part number 63102347956 &63102347957).if i could get my hands on a set, would it work?
Does anyone know if this euro version set would have something different than the US version other than the color? I imagine that the ballast are different from the US version, but i am not sure of it.
Old Jun 2, 2022 | 06:06 AM
  #228
Its the same thing, they just have a different cutoff pattern for the light, thats all (LHD version Euro) And if they are RHD the pattern is opposite of what you need.
Old Jun 2, 2022 | 12:08 PM
  #229
sub3622's Avatar
sub3622
Thank you for your answer ECS, very helpful info. Question for you: are you guys able to get those headlights and sell them?
Old Jun 2, 2022 | 12:36 PM
  #230
Hello,
I can reach out to my euro guys and see what they say.
Glad to help.
Old Jun 2, 2022 | 12:46 PM
  #231
sub3622's Avatar
sub3622
Hello,
Glad to help.
Great and thank you, i would really appreciate your help in this.
Old Jun 3, 2022 | 05:26 AM
  #232
63102347956 &6310234795 those are not coming up in the system, do you have another part number or its off a digits, it is 11 digits but the number are wrong.
Old Jun 3, 2022 | 01:07 PM
  #233
sub3622's Avatar
sub3622
Those are the numbers you ECS guys gave us at the beginning of this thread.
I looked up those numbers online and they came back correct but I don't think they are available on US systems.
Old Jun 6, 2022 | 05:53 AM
  #234
Opps sorry i will look them up again, i must have posted off a couple digits. Something is up.
Old Jun 6, 2022 | 06:23 AM
  #235
MVPeters's Avatar
MVPeters
Just for clarity, US, Canada & main-land European countries are all Left-Hand Drive - LHD.
Only the UK (& most Commonwealth countries) is RHD.
Old Jun 6, 2022 | 12:59 PM
  #236
sub3622's Avatar
sub3622
Thank you ECS for your help.
Old Jun 6, 2022 | 01:01 PM
  #237
sub3622's Avatar
sub3622
That is absolutely correct and thank you for reminding us.
Old Jun 7, 2022 | 09:21 AM
  #238
Checking with them again.
https://www.realoem.com/bmw/enUS/sho...diagId=03_2264
I got my numbers mixed up, seeing if we can get the black ones also.
These are EURO but LHD,
Old Jun 16, 2022 | 10:07 AM
  #239
david7268's Avatar
david7268
Hi everyone. I'm installing these lights on my early 2009 build R56. I am new to NCS Expert and have spent a couple of hours learning how to use it. I was able to get $522 into the VO for CAS and FRM, but I cannot for the life of me figure out where to do this step.
Changes headlight pinout
PWM_FL_BEI_BIXENON
wert_01
wert_01
Can someone walk me through it from start to finish please? I have very bad flickering and flashing of the headlights.
Old Jun 17, 2022 | 09:11 PM
  #240
david7268's Avatar
david7268
PWM_FL_BEI_BIXENON
wert_01
wert_01
Nevermind. I changed a couple of the pulse width modulation settings. The one above was change to wert_02 and another one was changed to wery_01 using BimmerCode and it worked.
Old Jun 21, 2023 | 08:16 PM
  #241
laforze's Avatar
laforze
Anyone local to the North County of SD or around the Redondo Beach area that can program these?
Old Jun 23, 2023 | 06:52 AM
  #242
Yoshimura 1's Avatar
Yoshimura 1
Okkkkkkkay......... that's awesome ......I'll be getting a retro kit shortly
Old Jun 26, 2023 | 08:18 PM
  #243
laforze's Avatar
laforze
How about anyone In LA or Orange County? I don't mind traveling. I'm also not asking to have this done free of charge.
Old Jun 29, 2023 | 10:30 PM
  #244
laforze's Avatar
laforze
Since this thread seems dead, I went to Mini of Escondido and was quoted $209 for the coding.
Old Jun 29, 2023 | 10:57 PM
  #245
david7268's Avatar
david7268
$209 doesn’t seem bad in my book. It was a pain in the *** getting inpa set up and then getting it to work for me. I had to do my own because there are no mini dealers for 200 miles from me. I would have gladly paid someone with a setup to do it for me, but I couldn’t find anyone near me either.
Old Jun 30, 2023 | 11:25 PM
  #246
laforze's Avatar
laforze
Not at all. I had it done today.
Old Mar 21, 2024 | 10:34 AM
  #247
jlegelis's Avatar
jlegelis
Just picked up the factory retrofit from ECS for my 2013 R56 to fix the tragic halogen units. I installed the units but they only work in accessory mode, so guess I need to do the configuration and coding. Does anyone know if this can be done with ISTA+, or is this NCSExpert only (I'm completely new to coding/configuration). Any pointers appreciated.
Originally Posted by ragingMINI
OK update on a pre-2009 install
Everything went perfect! After hooking them up, I poked around in NCSexpert for a while and ended up with this combo that didn't flicker and also didn't throw a bulb-out warning:
1. Added $522 VO for Xenons
2. FRM Module Changes:
Disables auto-leveling
AUTO_LWR_ENABLE
nicht_aktiv
Also disables auto-leveling
DYNAM_LWR_ENABLE
nicht_aktiv
PWM_FL_BEI_BIXENON
wert_01
wert_01
I still have no clue why MINI claims they only work on 2009+ vehicles. I'll post here if anything stops working or is giving me problems, but at the moment, I don't see any issues.
Old Mar 25, 2024 | 08:12 AM
  #248
maccoder's Avatar
maccoder
I have installed this kit on my 2013 R56S four years ago, so my memory may be failing me. As far as I remember everything worked fine out-of-the-box except the strobing on start. So if I remember correctly I did the programming as outlined in this post. I certainly don't remember any other issue with lights operation. Are you sure all connections have been done right?As for coding, I've been using NCSExpert, but looks like others have successfully used BimmerCode.
Old Jul 30, 2024 | 04:56 AM
  #249
Scissorfighter's Avatar
Scissorfighter
I love that this decade-old thread keeps on giving. I installed the 25w kit in my 2013 R56 yesterday, after gleaning most of the info I needed from this thread. They look great! I did have to code PWM_AL to wert_01 in order to fix strobing (which was super easy using BimmerCode and OBDLink CX, in under 10 minutes).
One thing I haven’t found an answer to is how to get rid of the headlight exclamation point error icon that appears in the console for ~30 seconds after starting the car. Any ideas? Thanks to all who contributed to this forum!
<UPDATE> Never mind, I figured it out! Had to set "Check Control Notification High/Low Beam" to "active" using Bimmercode. Now the warning icon is gone.
Old Jul 30, 2024 | 05:33 PM
  #250
Yoshimura 1
I'm so ready to install my lights .......I still need to do a few more things first......
techgearpro
Mar 7, 2020 01:37 PM
TVPostSound
Electrical
Jan 26, 2015 06:50 PM
quattro4
Jan 17, 2013 04:25 AM
AlbanyRocs
May 28, 2012 11:27 AM
macmanjpc
Electrical
Sep 14, 2008 10:39 PM
