Electrical Rear Fog Light Switch Plate and Toggle Switch Install
Old Jul 30, 2016 | 03:01 PM
  #126
rkw's Avatar
rkw
Originally Posted by Greg Davis
If I plug this toggle into the factory harness, could I then just use the appropriate wires
It doesn't work that way. None of the toggle switches are directly connected to the wiring harness. The toggle panel is connected to a digital bus. When you flip a switch, the panel sends a digital message on the bus. Various modules (mostly the footwell module) listen for messages on the bus and perform the actual functions.
Something you can do is install the toggle and program the rear fog lights. Then you have a working rear fog and you can use the rear fog wiring as the input to your relay.
Old Jul 31, 2016 | 12:46 PM
  #127
Greg Davis's Avatar
Greg Davis
So it has to be programmed to enable the toggle, even though I just wanted to use two wires coming from the toggle and then use all of my own wires to connect to the relay to control my new lights.
But from what you two say, it isn't that easy. So just to be sure:
1) I have to purchase the toggle and connect to factory harness.
2) Have RFL enabled via laptop, ect.
3) Then tap off of the appropriate wires of the RFL to activate my relay.
Is above correct? Also, if so, then what wires would I be looking for from the RFL to activate my relay? And does all of the above mean that my lights will only come on when my main lights are on? In other words, the toggle will only be active when the main lights are on.
Greg
Old Jul 31, 2016 | 01:37 PM
  #128
RB-MINI's Avatar
RB-MINI
The toggle is not a old school switch with wires, it connects to the circuit board of the toggle switch bank. The circuit board is controlled by a module(computer) that controls several things in the car. Once this module is told your car has RFL's, it will respond to the new toggle switch and activate the circuit. The wiring should be in the car already, but buried in a wiring harness. Therefore, the easiest place to tap into that will be the RFL connector at the back bumper. Unfortunately, this means you'll have to run your wiring all the way to the front.
If you are really familiar with tiny electronics, circuit boards, and modifying, you might be able to use the toggle the old school way and bypass the control module, but that'll probably take a lot of time and research.
By using the factory RFL option, the toggle will only work when the RFL's are available, so you'll probably have to have the parking lights on, if not the headlights. On my '05, the front fogs work with the parking lights or the low beam headlights, but not sure about the rear.
Old Jul 31, 2016 | 03:03 PM
  #129
rkw's Avatar
rkw
Expanding on RB-MINI's post... the toggles aren't traditional mechanical contact switches. They are merely plastic levers that press on capacitive pads on a circuit board. The electronics on the circuit board detects that a toggle has been pressed, and communicates the action to the car through a data bus (communications network). There is no such concept as "connect the toggle to the factory harness".
I can't find pictures of an R56 toggle panel taken apart, but here is a photo gallery for the R53 version: http://www.gbmini.net/G2/v/2005album...leSwitchPanel/. It should help you to understand why you can't simply connect wires to the toggle.
Therefore I suggested to make the rear fog work, if you are very determined to use the OEM toggle for your driving lights. Then use the rear fog to drive your relay. You would pick this up from the rear fog wiring harness at the rear bumper. If you don't want to run your wires all the way back there, the other end of the harness is at the footwell module, but you'll have to figure out where it is in the wiring bundle. I believe that fog lights will only turn on if your low beam headlights (not high beams) are on. Check your Owners Manual.
Old Aug 1, 2016 | 07:58 PM
  #130
Greg Davis's Avatar
Greg Davis
Thank you. Very informative and greatly appreciated!
Old Apr 20, 2018 | 10:38 AM
  #131
wtorres141's Avatar
wtorres141
Revising an older thread - 13 MCS Covertible
Originally Posted by TVPostSound
Oh, convertible?
There is a single fog switch on those which is dual purpose.
Up on up off for front, down on down off for rear.
If the switch cover has 2 light icons over the switch, then its already programmed.
If the cover only has 1 light over the switch, only programming is needed.
No new switch is required.
Assuming the rear fog lights are installed on the bumper.
To test if the rears work, the fronts MUST be on first.
Lift the switch up to turn on fronts, then push down to turn on rears.
If that works, lifting the switch up turns them both off.
At least this is how my neighbor's work.
Good luck
Revising this older thread... perhaps there is a newer thread, but i have not yet committed to the search.
My 2013 R57, has the no blanks, the front fogs are controllable... single up=on, next up =off... same for the down press, single down =on, next down =off.
The rear fogs do have bulbs, the white portion operates as reverse lights... the red portion does nothing.
is this also a programming option?
thanks in advance,
Old Apr 22, 2018 | 09:03 PM
  #132
MKLight's Avatar
MKLight
thanks in advance,
Hey! Yes. You will need to get a spare toggle switch and have the computer programmed. Once the toggle is there and it’s programmed, it will work perfectly.
Best regards,
MK
Old Apr 23, 2018 | 06:42 AM
  #133
wtorres141's Avatar
wtorres141
Best regards,
MK
Thanks for the reply, however my convertible is not missing any toggles the toggle bank:
1. Driver window
2. All windows up
3. Door locks
4. Front Fogs
5. Passenger window
was hoping it would work as @TVPostSound mentioned above.
Old May 21, 2018 | 08:45 AM
  #134
Graspieper's Avatar
Graspieper
1. Driver window
2. All windows up
3. Door locks
4. Front Fogs
5. Passenger window
Greetings from the Netherlands,
Did you already figure it out, what the solution is for your convertible mini?
Or does anyone else knows the code for activate the dual toggle?
I have imported a US mini cooper 2014 R57 and here in the Netherlands working rear foglight are required.
I'll already done it with a 2011 R56 and it was no problem,
Any help w'll be fine
Thanks in advance,
JL
Old May 21, 2018 | 09:11 AM
  #135
TVPostSound's Avatar
TVPostSound
1. Driver window
2. All windows up
3. Door locks
4. Front Fogs
5. Passenger window
Convertible?
You should be able to just program the rear fogs.
Old Oct 24, 2018 | 02:35 PM
  #136
Nui's Avatar
Nui
Thanks everyone! Just did it with the 'hook' as I couldn't get the other tools to work. Off for programing. Hopefully I did the orientation right.
Old Feb 27, 2019 | 04:45 PM
  #137
r55forme's Avatar
r55forme
Hi everyone,
I just purchased a 2014 Clubman S and it does not have the rear fog light option. I opened the tail light up, there's a bulb and socket in there, and my wiring harness has 5 wires coming into both the right and left side tail lights (but it looks like there is a slot for a 6th). It was dark out so I didn't think to take a picture, but I wanted to check and confirm that I have the wiring necessary to go from the rear to the footwell module before I take on the task of adding the toggle and trying to reprogram it. Thanks!
Old Nov 29, 2019 | 02:56 PM
  #138
Pepper09's Avatar
Pepper09
From: Near Asheville NC in the beautiful Blue Ridge Mountains!
Working half way
Working on my ‘09 chili pepper. Back in the summer I got the lenses that had the light sockets and even bulbs on eBay from a seller in England. I put them in and thought my car looked better even though I couldn’t turn them on. A couple of weeks ago, a center console I had been watching, again on eBay from a seller in Lithuania was offered at $30 plus $35 shipping. It had been at $115 plus $35 shipping, so needless to say I jumped on it!
I installed it today and when I hit the rear fog switch I was surprised to see the dash indicator come on. I went and checked, and sure enough, the left rear fog light was on!!! I thought maybe the other bulb was bad so I swapped the bulbs and still only have the left light!
Anybody else had this happen? Is this still a programming issue or is it in the wiring?
Old Nov 29, 2019 | 04:15 PM
  #139
MKLight's Avatar
MKLight
For the R56S, that would be a coding issue. When I had my 2013 R56S coded, we had the same issue. I’m not sure what he did, but was able to get it working perfectly. Yours will be that way soon, too. 👍
Old Feb 7, 2021 | 08:54 AM
  #140
Native Texan's Avatar
Native Texan
Alliance Member
Excellent write up with pictures. Saved me a ton of time. THANKS
Old Jun 22, 2025 | 11:06 PM
  #141
ashald's Avatar
ashald
Hi there! Reviving the thread! 😊
I've got an R57 S Convertible 2013 and need to make rear fog lights working. I used Bimmercode to enable rears fogs as welcome lights and they come up in unlock, which I suppose means they're wired and working.
But now I have 2 problems:
1. My switch panel is full (driver window, rear quarter windows, lock, front fog, passenger window) - I'm wondering if the "front fog" can act as a a double switch both for front and rear fog lights? I think someone mentioned it above, and I saw a Mini video showing that rear fogs can be activated by pulling the switch down after front fogs were activated. Hopig someone can confirm it indeed works like that?
2. Coding... Did anyone do it on your own? If so, could you advise on how to do it for an R57? Is it possible via Bimmercode? Or do I need NcsExpert or something else? Or is it best to find a local shoo that can do that? I'm in NYC, and both the dealer and my mechanics (MINHS) refuse to do it so I'd need to find someone who's experience with this kind of things.
Thanks!
big_iz
Nov 14, 2017 02:41 PM
JimRoberts12
May 5, 2009 02:14 PM
EBMCS03
38
Jul 22, 2008 07:54 AM
davinci27
Apr 8, 2008 07:29 PM
shack01
Aug 8, 2005 10:17 AM
