Electrical V1 Hardwire - Need Some Help
Old May 29, 2009 | 01:09 PM
  #26
spinned's Avatar
spinned
So I am thinking about taking apart the remote switch/mute part and locating the face with the button on the plastic dash part behind the speedo. Does that dash part just pop off. Do any of you know were to pry on it so it won't break?
Old May 29, 2009 | 01:18 PM
  #27
toolazyforalogin's Avatar
toolazyforalogin
Originally Posted by SpinThis!
Bonehead: since the V1 comes with a blue plastic prong plug and has a complementary part that's intended to splice into existing wiring, you can't exactly insert the add a circuit onto the prong. Since you're plugging right into the fuse box, you don't need this part—just cut the v1 stock part off and crimp the Add-a-Circuit on. Is that what you're asking about? (I found this attached pic of the blue prongs.)
The V1 also comes with an inline fuse. Since you're using an add-a-circuit which is also fused, you could also cut that off too. I left mine in though since double-fusing shouldn't hurt anything and I actually found that the "split" point came in handy when running the wires. You might actually need the extra wire length too.
I thought you were calling someone a bonehead until I read further down.....
ask lacning he took it apart - you should check his gallery for pics actually - they're probably in there.
Old May 31, 2009 | 09:45 AM
  #28
bonehead04's Avatar
bonehead04
Originally Posted by BlimeyCabrio
In SpinThis's photo, there is a blue plug that plugs into a darker blue wire tap that Valentine provides... So the darker blue wire tap could be used to tap into the add-a-circuit red wire. It's kinda silly and much less clean than just cutting the light blue plug off and crimping that wire onto the add-a-circuit... but it would work.
Phew. Got my old hardwire removed from my BMW. Was having a very difficult time understanding your post until I saw the wires for myself. Okay, so my options are twofold:
1) Use the small dark blue wire tap and tap into the red add-a-circuit wire, and not use the blue crimping-area at the end of the add-a-circuit
2) Cut the light blue adapter from the red V1 wire, strip it, and crimp to the add-a-circuit via the blue crimping area (I call it an 'area' b/c I have no idea what it is)
Option 1 is not as clean, but does not involve any cutting. Option 2 is cleaner but involves modification (i.e. cutting the light blue adapter from the red V1 cord).
If this is correct, then I do like the cleaner install of option 2, but if I do end up cutting the light blue adapter and choose to hardwire to a different car, I just hosed myself unless it uses a similar setup, I resplice the adapter back on the red wire, or a I get another red wire/light blue adapter.
Is this an accurate summary?
Thanks.
Old May 31, 2009 | 02:08 PM
  #29
BlimeyCabrio's Avatar
BlimeyCabrio
All accurate, except the part about "hosing yourself" for the future. Lots of wire taps available out there, no problems pulling this out and using a different wire tap in the future (or, even better, just moving your add-a-circuit to the new car).
Old Sep 23, 2009 | 11:19 AM
  #30
wolos's Avatar
wolos
So after starting this thread (and project) over a year ago, I finally completed the remote display gauge pod. I used an Alta gauge pod and modified the V1 remote display with different colored LED's. Everything else inside the gauge pod is custom along with an extra RJ port so I can connect a mute button.
Old Sep 23, 2009 | 01:37 PM
  #31
toolazyforalogin
looks great. my only question is does the steering wheel block your view while driving?
either way good job!
Old Sep 24, 2009 | 06:36 AM
  #32
wolos's Avatar
wolos
The steering wheel doesn't block my view normally. It's only blocked when I have the wheel turned so far that one of the spokes blocks it or when my right hand is at 1 o'clock.
Now it's easy for me to see the arrows and colors using my peripheral vision compared to looking at the main unit above the mirror.
Old Sep 24, 2009 | 10:37 AM
  #33
bumbles44's Avatar
bumbles44
Okay, I'm a novice when it comes to auto-electrical mods -- when I was 17 I used to "splice" stuff into the fusebox of my '74 Camaro all the time (probably a fire hazard) but 25 yrs later, I know today's electronics are alot more complicated. So how many "add-a-circuits" can be added to the fusebox without disabling or damaging existing electronic components? I'm just thinking one for a V1, maybe another for my XM and another for my Garmin GPS?
Old Dec 2, 2010 | 06:50 PM
  #34
jasoncolorado's Avatar
jasoncolorado
Used these instructions tonight. Worked great! Thanks.
Old Dec 2, 2010 | 07:22 PM
  #35
Minidrivr's Avatar
Minidrivr
I used an add-a-circuit for a couple years without any issues but when I installed gauges a little while ago I used a wire harness that attaches to the cig lighter wiring. The harness plugs into the factory connector and has a connector for the cig lighter and bare wires for your accessories (also available with other options besides bare wires).
http://www.newministuff.com/new/shop...uctshow&id=472
I think this is cleaner since you're only using power from a circuit the car expects unknown loads.
Old Dec 3, 2010 | 05:41 AM
  #36
condor27596's Avatar
condor27596
http://s214.photobucket.com/albums/c...596/valentine/
The remote fits perfectly on our steering columns.
If you take off those silly suction cups and glue it in
you can get it up and over high enough that it is
very difficult to see from the outside.
I put a switch on the knee panel so that I can manually turn it off.
(normally comes on with the car but I wanted to retain that
ability for certain situations)
Old Dec 5, 2010 | 08:13 AM
  #37
jasoncolorado
I used silicone glue as well and it seems to be holding just fine. You can get it really high and it is hard to see from the outside. I like this setup much better than the suction cups.
Wohnson89
Jun 10, 2020 04:53 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
siriuszero
Sep 17, 2015 04:41 AM
caiken
Aug 30, 2015 05:34 PM
larrydata
20
Nov 16, 2008 12:01 PM
