Electrical What bulbs do I use to change halogen to white bulb?
hey all, not sure if this has bene discussed before but i cant find any in the past forum.
i am new and got a 2005 MCS conv with halogen headlight. i wan those xenon light but cant afford them now.
..so i wan to chnage the bulbs to the whiter ones..how do i know which one is suitable? i wan to car shops and there so amny types e,g 9oo4, 9003, 995, H4 etc
which one must i buy to fit in my headlight?
txhs os much again
txhs os much again
txhs os much again
txhs os much again
i dun know how ot do it...workshop will be expensive
So I've always used that Sylvania site to find sizes, and I just noticed that it has H9's listed for my 04 w/HID high beams, when I know it takes H7's. Strange.
Also, this place has every bulb size under the sun for cheap.
http://autolumination.com/
btw, anyone know how to take out the bulb? its seem that there a stainless steel ring thta is holding the bulb in place inside the housing? what do i have ot do ot get the bulb out? i tried twist and turning but did not work... anyone knows?
But pretty easy theres two lids covering your lights one round one square.
the round you twist off like a big bottlecap and the square one you unclasp the wire latches by pulling on them then wriggle out. The bulbs are tricky you gotta pull on one or two (if you got manual dexterity) of those metal prongs (stainless steel ring) holding bulb in place at the same time pull bulb out (at least half of it) then push on the other (3rd) prong holding bulb and pull other end of bulb out. A second person helps to push back on prongs holding bulb, but I did it by myself
I do it by getting one prong pulled back, then tilting the bulb as far as it'll go out that way, then doing the next prong, tiling the bulb a little more, and then when you do the last prong it sorta just pops out. The first time I did it it took forever but then I figured this little process out and I can change them in no time flat now.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
