Electrical More lights and buttons: Stealth radar detector Smartcord install
Old Jan 2, 2008 | 09:53 AM
lacning74's Avatar
lacning74
Here's better pictures of my hack-job install of an Escort Smartcord for my 9500i detector. Since the mini lacks many empty spaces on the dash, the handbrake console offers many opportunities for new switches, buttons, and lights. The rounded surface is a pain though. Plenty of fun for my Dremel.
Here's the result:
The trim ring around the shifter easily pops off. You can see the Smartcord circuit board with the button, red, and green led:
To remove or loosen the entire handbrake console, there are torx screws in the bottom of the three cupholders. If I ever sell my car, I did find out that the handbrake console part that I drilled into for the button and lights costs around $70 to replace.
For comparison, here's the original non-hardwire version of the Smartcord adapter that came with my detector (great for traveling):
Thanks agranger for the inspiration. His location is more functional since the LED lights are at better eye level, but I never use my detector in dark or silent mode anyway. Also, the space behind the driver dash trim is tighter in the R56, though.
I plan to use the front area of the handbrake cubby for another switch in the future. Stay tuned.
Old Jan 4, 2008 | 02:19 PM
lacning74's Avatar
lacning74
Doh! This mute button kit would have been easier and cheaper. They have it for the other radar detector brands as well.
Old Apr 1, 2008 | 09:17 AM
lacning74's Avatar
lacning74
I couldn't stop tinkering. The button was too recessed with my old install using the original hardwire Smartcord.
I got the mute button hardwire kit with red LED I mentioned earlier. I used the existing holes I had drilled and added a SPST switch.
The green led switch is for my laser parking sensor that unfortunately has a side-effect of jamming LIDAR.
Old Apr 14, 2008 | 12:40 PM
lacning74's Avatar
lacning74
Just a pic of my current Escort 9500i radar detector location. Sorry for the quality. It's visor clipped to the headliner along with some velcro on top to stabalize it. I passed the hardwire along the headliner to the passenger A-pillar down to the fusebox.
Before my rear view mirror car cam, it was more medial up against that bump of the headliner just to the left of the original RVM without touching it. I liked that snug fit better, but now I got no room there.
Old Apr 14, 2008 | 04:48 PM
jw34's Avatar
jw34
So where's the DVD player?
Old Mar 18, 2009 | 11:50 AM
fishbert's Avatar
fishbert
I'm looking at either a 9500i (or ix) or a 8500 X50... and I'd like to get a similar mounting setup against the headliner near the rearview mirror.
Now, the only substantive difference between the 9500 and 8500 appears to be GPS trickery, and Escort says you need a clear shot of the sky for their GPS to work. Does that mean I might as well just get the cheaper 8500 X50? Or does the 9500-series GPS still work (to a lesser degree, maybe?) with the less-ideal headliner mounting location?
Old Dec 7, 2011 | 08:07 AM
Brad Bedell's Avatar
Brad Bedell
I have the 9500ci in my car. Mounted the GPS antenna under the front cowel. It's a little less sensitive there than mounted externally, but usually only a problem when I'm between big buildings or a road that is cut below ground level.
You really don't want to shield any antenna by a 'roof' and mount it in the headliner. It *might* work. However, even my hand held Garmin units like line of sight to the sky better than being covered by the roof.
Old Dec 7, 2011 | 09:43 AM
selder's Avatar
selder
A risen zombie!!!
Fishbert was asking about the IX, which is indeed normally mounted against the headliner.
Old Dec 7, 2011 | 09:49 AM
Brad Bedell
oh yes it is. Sorry about that. Clearly, I'm using the search function.
Old Dec 7, 2011 | 11:29 PM
fishbert's Avatar
fishbert
As an update, I did get the 9500ix, and have been quite happy with it installed against the headliner. Just a couple months ago I finally got around to wiring up a silence button in the center console, actually.
Old Dec 8, 2011 | 09:04 AM
Brad Bedell
Does the is unit work well? My ci *built in unit* works better than my year old V1 in our environment. Wife uses the V1 and I usually get signal around 100 yards earlier than she does in the few tests that we've performed.
I'm considering the ix for her, she can't justify needing/wanting another ci, but the false signals drive her nuts.
Alkaidovich
Jan 30, 2021 01:35 AM
squawSkiBum
Oct 2, 2015 09:21 AM
