E-Mini (2020+) Electric Mini Discussions
E-Mini Exclusion Time for Charging
Old Aug 18, 2023 | 06:53 PM
robertsteven's Avatar
robertsteven
Question Exclusion Time for Charging
I am charging with level 1 120VAC 10amp charging. It could take 30 hours to charge from empty. 2024 Mini Cooper SE.
I want my Mini to charge IMMEDIATELY every time it is plugged in, EXCEPT during the extremely high rates between 4pm and 9pm.
I never know when I will drive so a finish time is not possible. I never want "preconditioning" or anything of the sort.
I had a Prius Prime and I simple connected the charger to a smart outlet that would turn off during 4pm and 9pm. When power resumes, the car continued charging. I could also set a start time of 9pm in the car, because charging would be completed in 5 hours, not 30.
But oh no, not with the Mini. The power will stop at 4pm, but at 9pm when the power comes back on, the charger is goes into Error ! mode and will not resume until you remove the plug from the car, unplug the brick from the outlet and plug it all back in when the brick goes through an incredibly long testing process. This is incredibly stupid, for most states are adopting the Time of Use plans.
Does anyone have a work around for this? Or perhaps I am missing something in the menus.
Old Aug 23, 2023 | 06:33 AM
chrunck's Avatar
chrunck
You're more likely to get an answer at the forum below. There are a lot more SE owners on there.
InsideEVsForum
Old Aug 23, 2023 | 11:26 AM
robertsteven
InsideEVsForum
Thank you for the suggestion, however I looked there too. I think it is a secret, like trying to understand why Car Play works, and then doesn't. Or how the car decides what phone to connect to.
I did discover the charging answer myself: Buy a new charger brick. It works fine going off and on connected to a smart outlet, and will also work on 220 if I upgrade, plus you can select the output current amperage. And it remembers the selection when the power goes out. And was less than $150, keeping the Mini brick safely in the box. Time will tell if it lasts. It weighs soooo much less than the Mini brick. And should I drop the plug in connector side and break it, or run it over, or crimp the cord from the garage door opener, I won't be out $1000 at lease end. All good!
Old Aug 23, 2023 | 12:18 PM
chrunck's Avatar
chrunck
Ok cool, I wasn't sure if you were aware of the other forum, and I don't read all the threads there so if you posted I missed it.
JayGee
E-Mini (2020+)
Jul 7, 2021 05:10 PM
Patriot!
Jul 29, 2014 10:02 AM
MBlazed
Feb 11, 2014 10:39 AM
SoundMessage
Aug 10, 2012 09:57 PM
antsmini
Jul 31, 2003 10:29 PM
