Drivetrain Oil Catch Can: M7 or ALTA???
Old Mar 30, 2007 | 09:49 AM
davisflyer's Avatar
davisflyer
Any recommendations out there? Ease of install, ease of draining, etc. Thanks
Old Mar 30, 2007 | 09:54 AM
xizor's Avatar
xizor
I'm not a fan of how the Alta directions instruct to connect the OCC, but if you only connect it to the PCV the silicone will collapse under pressure so you need a rigid insert inside. I got the Alta since it matches all my other silicone stuff
Old Mar 30, 2007 | 02:01 PM
Bahamabart's Avatar
Bahamabart
Location will be an influencing factor - Because the Alta is smaller you have more location options. I opted for the M7 but have buddies running the Alta.
which ever you can get a deal on
Old Mar 30, 2007 | 05:07 PM
ScottinBend's Avatar
ScottinBend
Go for both !
Best install option is the metal can for the pvc side and the silicone one for the low vacuum side.
Old Mar 30, 2007 | 07:34 PM
davisflyer's Avatar
davisflyer
So you need two?
Old Mar 30, 2007 | 07:53 PM
ScottinBend
Not necessary, but it does give you the most protection. I have the Alta hooked up as per their instructions and an Ebay aluminum one hooked up to the pcv line. I get about half a can of gunk every 4-6 months from the ebay can and just some watery liquid in the Alta in about the same time.
Old Mar 30, 2007 | 08:28 PM
ATCQL's Avatar
ATCQL
Call Chad at Detroit Tuned,he has a nice mod to help with the draning of the cc.Q
Old Mar 31, 2007 | 05:14 AM
72guy's Avatar
72guy
Another option albeit a bit $$$:
http://www.midwestpd.com/catalog/pro...roducts_id=518
Old Apr 1, 2007 | 06:27 AM
Bahamabart's Avatar
Bahamabart
So you need two?
You could install two or you could configure 1 OCC to collect from both engine sources. Here is my experience - facing the engine
1) The left source seems to produce more oil that a OCC can trap.
2) The right side seems to produce less oil but more water that an OCC can trap.
I tried the "dual source" routing into 1 can which various OCC vendors provide directions for install (M7 & Alta are two that I know of). It works but I found the single sided set-up (left side) with routing back via the vaccum tube to me more effective in collecting oil. This set-up leaves the right source as is. With this set-up I find
1) no oil in my IC or the boots
2) I collect about a tablespoon a month inside the OCC.
I would start with 1 can, read DarkMiniS sticky on OCC install and see what your results are. You can always add another can if you so chose.
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
Aug 21, 2015 12:59 PM
M7Speed
Aug 6, 2015 01:48 PM
