Drivetrain I broke it :-(
Old Mar 7, 2007 | 05:35 AM
a610's Avatar
a610
I broke it :-(
Hello,
I am having some problems and I wanted to get some opinions please. My car is a 2006 MCS with 22k miles. I have a header, exhaust, intake, 17% pulley, Schrick cam, and alta diverter with m7 ram air scoop on the car. I then installed NGK iridium plugs 1 step colder and had the car dyno tuned, 12.5 AFR. All this was done at least 6 months and 10k miles ago. Two weeks ago I added JCW injectors, DT BPV, and VGS. These mods didn't provide the mid-range boost I was hoping for, but did provide a nice improvement at the top end. Driving to work on Monday, my car started to lose power and was running rough. I pulled over, turned the car off, and checked for anything grossly out the ordinary. I didn't find anything, so I started the car and drove to work at a slower pace, no problems. After work, I had a mechanic friend check the code and it said the No. 4 cylinder didn't fire. I checked the plug and wire and all looked good. After a test drive, first slow then faster, all seemed ok. Driving to work on Tuesday, I had the same issue. I turned off the car, restarted it, and drove at a normal pace without issue. After work is where things get interesting. As I got on the autobahn, I drove maybe 1 mile before I lost substantial power. I pulled over to find my number 2 spark plug sitting under the intercooler, threads intact, with part of the spark plug boot missing. I put a plug in it and drove VERY slowly home. The codes said No. 2 & 4 spark plugs didn't fire. I got gas at my usual place on Sunday, 93 US octane, what the car was tuned on. Any ideas? Thanks for your time.
Old Mar 7, 2007 | 06:08 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I know some people using Denso spark plugs sometimes have their plugs coming loose... It is recommanded to check them on a regular basis...
I have never had this problem with mine though.
Old Mar 7, 2007 | 06:14 AM
IQQIMINI's Avatar
IQQIMINI
Coordinator :: Mid-Ohio Motoring Club
Yep.
I turned the key one morning to hear a 'pop' and see smoke pouring out from under the bonnet. I opened to bonnet to see a spark plug laying on the IC.
Soft aluminium head, expands and contracts over time, loosening the plug. When there's only a thread holding it in, BOOM, out it comes.
I rethreaded mine and spent about $4 for the fix altogether. Now, I remove and rethread my plugs at every oil change.
As far as the fouling - my Densos lasted about 25k before they fouled all to heck.
Old Mar 7, 2007 | 06:39 AM
a610's Avatar
a610
I forgot to mention, the tip(center electrode?) is missing from the spark plug.
Old Mar 7, 2007 | 01:11 PM
herbie hind's Avatar
herbie hind
well hopefully the electrode got pumped out with the plug . i've seen some denso posts on here ; enough to keep me with ngk 's . i too check the torque every oil change-but i check um cold !!!! 20 ft, lbs. .
Old Mar 7, 2007 | 01:24 PM
Orca's Avatar
Orca
this is valuable info...Thanks for the heads up!
Old Mar 7, 2007 | 03:46 PM
SayGoodbye's Avatar
SayGoodbye
I've been using 24 lbs via Fireballed! Racing FWIW.
Old Mar 7, 2007 | 03:52 PM
herbie hind
you're doing 24 lbs.? for how many miles now ?
Old Mar 7, 2007 | 04:02 PM
SayGoodbye's Avatar
SayGoodbye
Since the end of January...daily driver...about 30+ miles per day plus a 350 mile fun run.
Old Mar 8, 2007 | 03:48 PM
herbie hind
mine's a daily too . i do about 25000 a year . 75000 and on the original brakes!! i'll try bumping it up a bit as i use anti seize as well .
Old Mar 8, 2007 | 05:36 PM
SayGoodbye's Avatar
SayGoodbye
lol...my brakes went at 40k
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Doc Pain
Mar 10, 2021 04:50 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Giants9595
Sep 29, 2015 10:49 PM
MCSNY
Sep 29, 2015 10:17 AM
