Drivetrain Restting the ECU
Old Jan 21, 2007 | 04:14 AM
harhoosh's Avatar
harhoosh
Restting the ECU
How can i rest my car ecu after installing the Headers ?
Do I have to remove the bettery for 1 or 2 mins and thats it ?
Old Jan 21, 2007 | 04:39 AM
NMgokart's Avatar
NMgokart
Just disconnect the negative battery terminal, wait a few minutes, and hook it up. You'll need to reset your clock afterwards.
Finally got the header on? Cool!
Old Jan 21, 2007 | 06:37 AM
robino's Avatar
robino
so will resetting the ecu make certain adjustments based on what new things it feels/finds? Such as the header in this case, are you saying it 'adjusts' to the new modifications?
Old Jan 21, 2007 | 06:51 AM
NMgokart's Avatar
NMgokart
^^ From what I've read, yes. The ECU is adaptive and will re-learn over time; this just speeds up the process. I'm certainly open to correction if this is incorrect. I don't know how this would affect software upgrades (JCW, MTH, GIAC), so i'd wait for some of the more knowledgable to chime in before attempting it.
Did you decide on an upgrade yet? Curious to see how your mods all tie together. You certainly have done your homework!
Old Jan 21, 2007 | 07:12 AM
harhoosh's Avatar
harhoosh
just i have to remove the Negative tirmenal and wait few seconds and thats it ? without doing and adjusting anything ?.. it well Automatically synchronzie it ?
Old Jan 21, 2007 | 07:24 AM
robino's Avatar
robino
i'm curious if this indeed works, on another thread(under the bonnet) it mentions going through the Speedo settings to re-set the ecu...the battery option does seem easier
typically, it's disconnect the neg. step on the brake a few secs to drain the system well, wait 5 minutes and connect the neg back.
I'm also curious what happens to the existing TUNE when this is done, example being, if i have a JCW re-flash on my ecu, then i change my battery let's say, would this bring me back to the stock ECU tune, erasing the JCW re-flash?
Old Jan 21, 2007 | 07:46 AM
TampaMCS's Avatar
TampaMCS
the tune stays the same, the only thing that gets cleared out is the adaptive functions. This has more to do with part throttle acceleration. WOT doesnt get changed. This is also reffered to as the cluster reset.
Old Jan 21, 2007 | 09:21 AM
harhoosh's Avatar
harhoosh
Im confuse now.. If you are in my place..
u install Megan Headers On ur JCW.. what you are doing ??
cuz people saying the battery and sum no.. wut to do ??
Old Jan 21, 2007 | 09:25 AM
TampaMCS's Avatar
TampaMCS
You can reset the ecu, it will help adapt to the changes you made, but the overall tune will not change.
In order to take advantage of this change you need to go with aftermarket ECU tuning.
Old Jan 22, 2007 | 12:35 AM
harhoosh's Avatar
harhoosh
wut is the purpose of doing all this ?
Let us to say if the headers will gives me 10HPs .. and i didnt rest my ECU. wut will happen .. it will not gives me all the HP or wut ??
I need to know wuts the purpose of this..
I own JCW 03 so i think the ECU is upgraded right ??
Old Feb 19, 2007 | 05:20 PM
Maxicooper's Avatar
Maxicooper
Disconnected the battery yesterday to reset the ECU after some mod. Not sure of any improvement other than slightly better trottle response and gas mileage.
Old Feb 19, 2007 | 05:44 PM
jgf's Avatar
jgf
Reset Ecu disconnect neg terminal for 3 min. If you don't want lose clock etc setting, can buy @ part's store a connector that plug's into your cigarrette lighter, other end plugs into 9 volt battery. Are you resetting as you have new free flow cat? If you just put header, CAI ECU will relearn itself. As you mod more expect more Cel flashes usually 4026 ( mix lean or rich). Easy to rectify with 0-2 elect simulator.
Old Feb 19, 2007 | 05:59 PM
Maxicooper's Avatar
Maxicooper
New injectors, pulley, plugs, intake and exhaust.
I disconnected them for a cup of coffee.
I lost clock and computer data (average mileage, speed, etc.) but not the radio setting.
Old Feb 20, 2007 | 01:28 PM
batrugger's Avatar
batrugger
The reset with the speedo is a lot easier:
Hold in your odometer reset button and at the same time turn your key so that the radio comes on
Release the odometer button and then press it repeatedly until it shows the #19
Stop at 19 and the display will go back and forth between "test" and "off"
Push the button when it is on off and the press it repeatedly until you get to #21
It will display an option to reset. Press the button and your displays will go blank and your guages will flutter and then the displays will come back on
Turn off the key and then your done.
Takes less than 60 seconds and you don't need to to unhook the battery or reset your clock
vulkandino
Oct 31, 2015 08:29 PM
dutchhome
Sep 30, 2015 07:17 AM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
Sep 25, 2015 12:32 PM
