Drivetrain Will this be a better place to mount my venom Nitrous jet?
Old Oct 16, 2006 | 06:49 AM
fozworth's Avatar
fozworth
Hi i have a M7 venom nitrous system fitted to my cooper s,and wonderd if it would be better to mount the jet centraly in the manafold so it gives an even spray to all pistons rather than mounting it where they sudjust which is on the side of the main ,is it intake or out take that connects to the intercooler..
The problem with doing it this way (and im not an expert) would seem that it would feed 50% of the nos to the 1st cylender then less to the 2nd and even less to the 3rd and well ,you get where im going ,it just seems that the heat wont be evenly dispersed.So can anyone help before i decide where to place the jet.
Old Oct 16, 2006 | 07:15 AM
Soul Coughing's Avatar
Soul Coughing
i'm sure all cylinders would get equal amounts, i mean, the engine is ingesting air into every cylinder without the nitrous, so what would be different with it.
the only thing i could see would be insufficient fuel...
Old Oct 16, 2006 | 07:32 AM
ScottinBend's Avatar
ScottinBend
Remember that the engine is only going to have one cylinder at a time open to the intake, so having it at the end of the manifold should be just fine. And it is also under pressure from the SC.
Old Oct 16, 2006 | 08:05 AM
fozworth's Avatar
fozworth
okcheers guys,will mount it stock style then
Old Oct 16, 2006 | 03:22 PM
herbie hind's Avatar
herbie hind
they don'y make a wet system to fit the cooper s ?
Old Oct 16, 2006 | 04:43 PM
fozworth's Avatar
fozworth
dont think so ,but ive been speaking to M7 and they have told me to mount it in the stock place as per instructions and they say it should be fine as they have extensivly tested it in that position .so im sticking with that
Old Oct 16, 2006 | 05:33 PM
herbie hind
cool... don't forget the chute . and discount tire direct. LOL.
Old Oct 16, 2006 | 06:32 PM
Johan's Avatar
Johan
The elbow before the intake manifold after the IC is the best spot you can mount your nozzle. You want the nitrous to atomize as much as possible with the air so it will hit all 4 cylinders equally. If done correctly you can drill this hole without taking off the horn either.
YES you can get a Wet kit that's fairly simple to install. For more info send me a PM.
One more thing NOS is just a Nitrous company brand name...you have Venom not NOS. It kills me when people are like "NAWS" Cheers -- Johan
Old Oct 18, 2006 | 03:31 AM
fozworth's Avatar
fozworth
sorry dude didnt realize i had put the word NOS down only nitrous but at least you new what i was on about.So regarding fitting
Old Oct 18, 2006 | 03:41 AM
fozworth's Avatar
fozworth
As i was saying with fitting do i just need to take the intercooler off and can i then get something in the elbow to stop sworf going into the engine.
Old Oct 18, 2006 | 06:46 AM
Johan's Avatar
Johan
Yes, it is CRUTIAL that no little metal shavings enter the intake manifold, that can lead to catistrophic failure. Get an oily rag and stuff in there(new oil, it will help hold onto the metal shavings). IF you really want to go to the extreme also use a little vacume cleaner, like the one for a computer. Take your time and do it right and you won't have any problems. Good luck and whatever you do have FUN -- Johan
Jan 2, 2019 09:21 AM
khumpert
Nov 30, 2015 11:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
Super Coop
Aug 17, 2015 05:09 PM
M7Speed
Aug 6, 2015 01:48 PM
