Mini Cooper Engine Mount Motor Mount Application Guide
Old Sep 1, 2015 | 01:34 PM
Mini Mania's Avatar
The factory original upper engine mount (passenger side of engine) is a hydraulic unit that tends to fail over time. If you see a black mess under the upper engine mount, the fluid has leaked out and it has failed.
The factory original engine mounts uses rubber in order to isolate the Noise Vibration and Harshness (NVH) from the cabin. The upgraded engine mounts uses harder compound than rubber in order to limit engine movement allowing more immediate transfer of power to the axles for improved acceleration. These harder compounds also transmit more NMH into the cabin requiring a tradeoff between comfort vs. performance. Select the replacement based on your priorities.
http://www.minimania.com/Mini_Cooper...lication_Guide
Old Jan 2, 2019 | 09:21 AM
jjcsnlynn's Avatar
jjcsnlynn
Nobody is parting out an R56?
andrewjg1994
Jan 29, 2021 07:45 PM
tr3y003
Oct 22, 2015 10:48 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
joelcseymour
Aug 7, 2015 12:43 PM
M7Speed
Aug 6, 2015 01:48 PM
