Drivetrain Sparks after 3000 miles
Old Aug 30, 2006 | 04:35 AM
etalj's Avatar
etalj
Hi
My spark plug gaps seem to be fine, but the ring and two spacers around Spark plug #1 are caked in carbon, and so is the white section. #2 is also covered in carbon, but to a slightly lesser degree, with a little bit of carbon on the white part as well. #3 has no carbon deposits on the white bit, the two spacers, or the ring. #4 is even cleaner.
The threads on #1 and #2 have carbon deposits, #3 has a bit less, and #4 has much less....
Pictures attached.... (they are Denso IK22s BTW)
What does this mean?
check this thread for pics....
http://www.mini2.com/forum/engine-dr...does-mean.html
Old Aug 30, 2006 | 07:38 AM
stevecars60's Avatar
stevecars60
Originally Posted by etalj
Hi
1 & 2 are leaking, 3 leaks but not as bad. They look pretty rich but I can't realy tell from the pics ( pretty dark ). The plug color should be grey to medium grey brown. The leaking can cause a bad burn & give you the black color. You could clean them, reinstall & check them in another K or so. Realy, from the pics it looks like the only problem was loose plugs.
How well was the engine running?
obehave's Avatar
obehave
Any time I've ever seen that it has been caused by :
Improper sparkplug seating
Improper boot seating allowing tip to nut arcing
Old Aug 30, 2006 | 07:48 AM
Dr Obnxs's Avatar
Dr Obnxs
Torque em down...
make sure the wires are on good, and drive the snot out of it. Then check again. Our cars run rich, no matter what you do.
Matt
Old Aug 30, 2006 | 08:59 AM
etalj's Avatar
etalj
I don't wanna overtighten them though, surely?
I torqued them down a lot harder than usual, the car seemed to have a bit more power, but same driveability.....
how much is 20ft-lbs of torque approximately? i once heard a quarter turn past hand tight.....
BTW, do i clean them with carb cleaner or similar?
thanks for the help guys....
Old Aug 30, 2006 | 09:11 AM
stevecars60
"how much is 20ft-lbs of torque approximately? i once heard a quarter turn past hand tight....." and a little.... ( only a little )
Old Aug 30, 2006 | 09:14 AM
etalj's Avatar
etalj
so 90 deg with a 12 inch long ratchet? I tried that, it felt like i was gonna break it!
Old Aug 30, 2006 | 10:01 AM
caminifan's Avatar
caminifan
If you can't afford a torque wrench, you shouldn't be guessing...
Seriously, a quarter turn past hand tight will result in a wide range of actual torque values. Hand tight for someone with not a lot of strength in their forearms might approximate to 8 ft/lbs. A quarter turn on a 6 inch ratchet might get you to 12 ft/lbs. A quarter turn on the same low strength forearm tightening with a 12 inch ratchet might get you to 30 ft/lbs. If you don't want to roll the dice on stripping the threads, get a torque wrench.
Old Aug 30, 2006 | 10:15 AM
obehave's Avatar
obehave
Ya see??? This is why they made torque wrenches.
Yes I've heard the contact + 1/4 turn thing too(it's been around forever and really relates best to crush washer designed plugs). What wasn't mentioned was since this was a used plug it will make a HUGE difference in how far you rotate the plug to meet the torque spec.
Old Aug 30, 2006 | 11:08 AM
Dr Obnxs's Avatar
Dr Obnxs
I use 18-20
and the metal feels soft. I'd never do it without a torque wrench...
Go spend the $, you will be much better off.
Matt
Old Aug 30, 2006 | 12:36 PM
Johan's Avatar
Johan
You guys are almost right. Crush the washers on the plug, then 1/4 turn. Here's a quote from Randy Webb
"If you have replaced the spark plugs in your head (or if anyone else has), please check that the torque spec is 18-20 ft/lbs.
We have had a couple of cars seemingly loosen up, and the result can be BAD.
All you need to do is use a deep 16mm socket on an extension, loosen the plugs a bit, then tighten until you feel the crush washer crush, then take it another 1/4 turn.
I've seen this on a set of Bosch, Accell, and Denso plugs now - so I have been checking all of them lately. There is an issue for whatever reason of them loosening. Check every 5000-10000 miles to be sure they are torqued. "
But I agree with Matt, either buy a torque wrench if you like to work on your mini a lot. It will be usefull if later projects. If not, I'm sure somone in your local Mini club has a Torqe wrench they're willing to let you borrow. -- Johan
Old Aug 30, 2006 | 01:11 PM
stevecars60
Past tight and a little & only a little. I can get close to 60# with an 8" wrench, let alone a 12". Torque wrenches are pretty cheap insurance.
Old Aug 30, 2006 | 01:57 PM
herbie hind's Avatar
herbie hind
please get a torque wrench . and only torque them in a cold head. the aluminum threads dont like being run in and out while hot i've heard. and since minis are prone to pissing plugs out the heads and caution is well heeded by me .don't forget the anti seize on the threads too .
Old Aug 30, 2006 | 04:32 PM
etalj's Avatar
etalj
yeh i only work when the head is cold too...i've heard the same....
I will get a torque wrench
thanks guys
Old Aug 30, 2006 | 04:43 PM
Dr Obnxs's Avatar
Dr Obnxs
The reason to do it cold..
is the Al expands more than steel as it gets hot, so your torque to 20 when the head is hot, and the thing cools and it's like torqing to much more. Especially since you'd be putting in cold plugs.
Matt
Old Aug 30, 2006 | 08:31 PM
etalj's Avatar
etalj
makes sense
Old Aug 30, 2006 | 08:38 PM
skuzy's Avatar
skuzy
wats teh effect of over torquing the plugs
Old Aug 30, 2006 | 08:46 PM
Dr Obnxs's Avatar
Dr Obnxs
Depends...
screwed up threads most likely.....
Matt
Old Aug 30, 2006 | 09:08 PM
caminifan's Avatar
caminifan
Worst case you have to use a thread insert (like Heli Coil or a similar product). Absolute worst case is you buy a new head if things are too screwed up....
Old Aug 30, 2006 | 09:24 PM
COR BLMY's Avatar
COR BLMY
a t wrench is necessary
My local parts store will even loan tools including t wrench.
A plug color and carbon check to be done corretly must be done after a spirited run and, you need to shut off the engine and coast to a stop then check.
any other method will give inaccurate readings.
I have been doing plug checks on 2 and 4 stroke race bike and most reciently for formula BMW
If you take good photos I would be happy to read
Old Aug 31, 2006 | 04:07 AM
stevecars60
Still a valuable art Been doing it for over 40 years...
maniacalmorgan
38
Sep 29, 2015 04:56 AM
David.R53
Sep 1, 2015 06:49 PM
imanexcellentdriver
Aug 31, 2015 08:08 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
maniacalmorgan
Aug 19, 2015 08:44 AM
