Drivetrain Engine Damper from Sales@shoe-in.net
Old Jul 25, 2006 | 07:06 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Has anyone besides me recently purchased a engine damper,
and are wondering (like me) how to install the dog-on thing.
Package came without any instructions.
Any help would be appreciated.
Old Jul 25, 2006 | 07:11 PM
pure&simple's Avatar
pure&simple
Check the group buy thread for directions: https://www.northamericanmotoring.co...ad.php?t=71325
Old Jul 25, 2006 | 09:07 PM
polizei's Avatar
polizei
It might be better to post his SN rather than his e-mail address....
The instructions are both listed in the thread and in his sig. Reading is your friend.
-Cody
Old Jul 26, 2006 | 07:25 AM
pberry51mini
No Fear Gear
-Cody
Hey thanks, I still haven't learned to read that well, but my typing is pretty good so far.
Somehow my searches for this thread came back with no results.
No slight upon the seller, but my package did not arrive with the instructions - guess it wasn't necessary since they were obviously readily available on the original thread.
Thanks again guys.
Old Jul 26, 2006 | 08:57 AM
polizei's Avatar
polizei
Good luck installing your damper on your 02'. Let me know if it fits.
Mine didn't fit on my 03'
-Cody
Old Jul 26, 2006 | 09:09 AM
OctaneGuy's Avatar
OctaneGuy
Hmmm, you bought it from Shoes Group Buy didn't you?
Click on Forums on left, and click Vendor Group Buy. It's a huge thread at the top, can't believe you couldn't find it.
Anyways, I got mine yesterday, and lost my bell washer during installation. I read the instructions, and had it on my laptop, and I still screwed up.
Oh well, the damper is once again removed from my MINI until I find a replacement part. I will give it a go again next week.
Support has been excellent from Shoe so I'm not worried.
Richard
Thanks again guys.
Old Jul 26, 2006 | 09:49 AM
PrplPplEtr's Avatar
PrplPplEtr
for those (like me) who repeatedly dropped (or worse, lost) the bell washer, here's a tip. the instructions recommend you attach the block end first, then the frame. i reversed it. put the bolt into the heim joint, put the bell washer on top, then insert the bolt into the bottom of the frame location using a finger to keep it in place in the damper. once you attach the nut on top, then go attach the block end. worked better for me. see this post for more details: https://www.northamericanmotoring.co...&postcount=449
Old Jul 26, 2006 | 04:24 PM
pberry51mini
No Fear Gear
-Cody
Yeah, it appears there is a brace in the way so I'm planning on doing a little dremeling on the sheetmetal brace to clear the main body tube of the damper so it will fit. If I'm successful this evening I'll let you know.
Old Jul 26, 2006 | 05:00 PM
Soul Coughing's Avatar
Soul Coughing
yeah please let me know, ive done a bit of dremeling, but havent yet drilled the new hole. I've gotten the thing to fit through though... so i guess we will see show lots of pics!!
Old Jul 26, 2006 | 05:05 PM
Dr Obnxs's Avatar
Dr Obnxs
There are pics...
in the group buy thead...
1) Its a vertical cut, and a horizontal cut. You'll end up with a little triangle of metal.
2) Put some newspaper over the front of the motor. It will be a pain, but it will keep the grit out of the belt system, and the altenator will attract all the filings, because it's slightly magnetic.
3) If you do a new hole, keep it less than an inch closer in. If you do a full inch or farther, it will be too close.
4) You may need to dremel out access for the 17 mm wrench to get to the head of the bolt. Others have used needle nose pliers.
Good luck!
Matt
Old Jul 26, 2006 | 06:53 PM
pberry51mini
No Fear Gear
Well, mine didn't fit on my 2002 either, sooooo,did some cutting and shaping and grinding and was able to fit it into the right space - problem remains that it is just too far to reach back into the sheetmetal to get the little bell washer and the bolt all in there - much less any wrench to hold the bolt while it is being tightened from above. I don't see a solution to this unless someone comes up with a plan to build a bracket for the 02 and 03 guys.
I've seen the Texas one now but I don't want to give up on this damper we have yet.
Let me know if something comes up y'all.
Old Jul 26, 2006 | 06:56 PM
pberry51mini
No Fear Gear
Good luck!
Matt
Yes, that's what I did, and made it look rather stock looking with some artwork and careful grinding.
Still - very hard to get it all back in there to tighten.
When my wife gets back I'll take a picture of what cut out and ground. Perhaps tommorrow.
Old Jul 27, 2006 | 05:19 AM
dickdavid's Avatar
dickdavid
FOR YOU 02 GUYS:
If you don't want to cut into your sheet metal to get your damper installed, you may want to check out this thread from TX:
http://www.metroplexmini.org/forum/s...ad.php?t=15738
These guys have a few extra 02-04 bracket still available. You can also PM scobib on this forum.
Here's a pic of their 02-04 bracket:
and one of the 05-06 brackets installed:
Old Jul 27, 2006 | 09:25 AM
Dr Obnxs's Avatar
Dr Obnxs
You are re-inventing the wheel...
Look here for photos of a successful install on an O2.
Also, this thread is asking questions that have been answered in the original "Engine/Motor Mount Group Buy" thread. This doubling up really makes it harder for guys like me who want to help out, I'm having to post the same info into two threads....
Matt
Old Jul 27, 2006 | 09:57 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Matt: The problem comes from the fact that mounting an engine damper on our cars, regardless of the year, requires some fabrication or modification, with few exceptions. The damper sold in the group buy is basically a generic eurethane damper like the one sold last year, by NRG (the one I have) and many others in the JDM crowd. So, in one sense, this discussion belongs here as it refers to mounting hardware and installation issues for most engine dampers. The other view is that it should be merged with the Vendor thread, but that pretty much excludes people like me posting, as I don't have that particular damper. As a person close to the moderators, I suppose you can make that call. I'd like to see it stay here, but become more inclusive of all engine damper mounts.
cheers,
Old Jul 27, 2006 | 10:11 AM
Dr Obnxs's Avatar
Dr Obnxs
I'd sign on to that, but...
this thread is titled "Engine Damper from Sales@Shoe-in.net!
Matt
Old Jul 27, 2006 | 10:15 AM
DrPhilGandini
Exactly! What an unfortunate title, as by that title it should be in the Vendor forum, but as it stands now the contents of the posts refer to a much more general issue of mounting engine dampers.
I can see that a thread entitled "Alta CAI install" should be separate from one titled "Typhoon CAI install" since these are different products, but honestly, especially seeing the photo of the Shoe-In damper disassembled, that damper is identical to my NRG except for the etching on the body and the grease nipples on the heim joints.
cheers,
Old Jul 27, 2006 | 10:21 AM
pberry51mini
No Fear Gear
I agree, I'm also getting more out of this than just the group buy thing.
Can I change the title of this thread since I started it?
Old Jul 27, 2006 | 10:29 AM
pberry51mini
No Fear Gear
Matt
It's amazing, I made the same cuts with my dremel and a cut-off wheel last night - like minds?
Getting the bolt back up in the sheet metal bracket has been the challenge now.
This morning I put a very little drop of Gorrilla-glue on the bolt to slightly hold it to the non-adjustable end of the damper.
I also put a VERY SMALL drop on the beveled washer on the other side. This will hopefully allow me to get this bolted end back into the original hole without once again dropping the bolt or the washer. (done several times)
I do plan on opening the front hole (as pictured in Dr.O's install) to get a wrench in there to allow tightening of the bolt once I get the nut on the top.
This will leave the adjustable end to attach to the engine, and allow future adjustments if necessary.
I should be finished this afternoon, I'll let you know how it goes.
Dr Obnxs's Avatar
Dr Obnxs
Sure!
PM the moderator.....
Matt
Old Jul 27, 2006 | 10:32 AM
OctaneGuy's Avatar
OctaneGuy
You can change it but it only only change the title in the first post of the thread. It will still appear everywhere else as the original title.
I like this thread. The Vendor Group Buy thread makes it VERY hard for me, a vendor to post. Actually, I'm restricted from posting even though I don't sell engine dampeners, that's why NAM allows me to temporarily use an alternate non vendor account.
But switching back and forth is a pain in the ****.
Richard
Old Jul 27, 2006 | 05:54 PM
polizei's Avatar
polizei
Originally Posted by dickdavid
FOR YOU 02 GUYS:
Did you talk to Scobib personally? I've been talking to him to see if the dampers would work, and to see if he would sell us the brackets and he said no. He told me he was NOT selling just the brackets (as of NOW). He said he might consider it, but as of now he is not.
-Cody
Old Jul 27, 2006 | 06:20 PM
dickdavid's Avatar
dickdavid
-Cody
Doh! Sorry for the confusion. When I said brackets, I meant their complete damper system. It's more expensive, but, IMO, better designed and will keep some of you from cutting into your metal.
Old Jul 28, 2006 | 06:40 AM
pberry51mini
No Fear Gear
This morning I put a very little drop of Gorilla-glue on the bolt to slightly hold it to the non-adjustable end of the damper.
Well, it all worked perfectly and I was able to install the damper in my '02 in the original hole intended by securing the bolt and special washer using a very small amount of Gorrilla Glue.
Now that it is installed I have to agree, the transitions between shifts are much smoother and the engine doesn't seem to be beating it self up as I rev through the gears.
Try it out, the glue helps get things started much easier.
bobbiemartin
Jan 20, 2016 05:28 PM
Emnotek
Aug 13, 2015 05:47 PM
M7Speed
R61 :: Paceman Talk
Aug 10, 2015 01:01 PM
M7Speed
Aug 10, 2015 01:00 PM
joelcseymour
Aug 7, 2015 12:43 PM
