Drivetrain Direct Air Scoop for the Intake
Old Jul 24, 2006 | 08:42 PM
  #101
ingsoc's Avatar
ingsoc
Originally Posted by obehave
I'm so misunderstood
Aww, take heart! You could always own a boring econo-box! . I'm sure I speak for all of when I say, "I appreciate ya!"
Old Jul 25, 2006 | 05:56 AM
  #102
obehave's Avatar
obehave
I have a Grand Caravan so I've got boring in spades
Old Jul 25, 2006 | 07:55 AM
  #103
Bahamabart's Avatar
Bahamabart
what about something like this ?
http://www.sailorsams.com/mall/cowl_..._engine_ss.asp
some where over the CAI box ?
Pretty easy to install - 3" hole in the hood and then a 3" hole on the CAI box top.
Old Jul 25, 2006 | 08:14 AM
  #104
obehave's Avatar
obehave
That might be a winner.
You would just need to deflect water from the filter. This isn't as big an issue as some might think. Direct puddling may be an issue but some water drops on a filter are nothing. It's an oil soaked filter so it'll shed water and ingesting a bit of water mist isn't going to hurt a thing. Think free water injection
I'm all for putting a hole in your hood.
Old Jul 25, 2006 | 08:18 AM
  #105
Partsman's Avatar
Partsman
Legion_of_Doom
That looks pretty good. The pic is deceiving, looks a lot bigger than 3".
Old Jul 25, 2006 | 08:19 AM
  #106
MSFITOY's Avatar
MSFITOY
It appears to me that you guys have taken over "Bob's Mission"
Old Jul 25, 2006 | 08:55 AM
  #107
SpiderX's Avatar
SpiderX
They can have it..... I'll just use the best idea..... this is lke having an r&d team I could never afford
Old Jul 25, 2006 | 09:04 AM
  #108
Partsman's Avatar
Partsman
Legion_of_Doom
I see how it is now.
If we can all benefit from this brainstorming thread, then it's all good.
Old Jul 25, 2006 | 09:20 AM
  #109
SpiderX's Avatar
SpiderX
exactly
Old Jul 25, 2006 | 09:33 AM
  #110
Partsman's Avatar
Partsman
Legion_of_Doom
My question is about the scoop/vent that Bahamabart posted...
which way would be more effective? facing front? facing rear?
Facing rear would look kinda cool, like the old GTO's with hood mounted tach.
Old Jul 25, 2006 | 09:36 AM
  #111
Peter@M7Tuning's Avatar
Peter@M7Tuning
This is very rough, but it illustrates the idea, I think, for the ram scoop.
Old Jul 25, 2006 | 10:08 AM
  #112
Partsman's Avatar
Partsman
Legion_of_Doom
Will, are you saying that the curvature is important because it shouldn't be as "hard" as your illustration shows?
Old Jul 25, 2006 | 10:10 AM
  #113
obehave's Avatar
obehave
Pro to type... pro to type.... pro to type......
Maybe this will do
Old Jul 25, 2006 | 10:16 AM
  #114
Peter@M7Tuning
Not exactly. It needs to be experimented with for a variety of reasons. First, you are going to have that lower section behave like the top of a wing. The curvature and angle of a wing is very important. Too shallow a curve, and you will have separation. Too steep and you have separation. So you can't have a change of angle more than 10 degrees over a length. of course, that length depends on speed, so I'd say figure out the best curvature for 70 MPH, and it should have a good amount of coverage for average speeds. Obvioulsy change it for a race car, etc.
But it NEEDS to curve. If it's flat, the air will not turn correctly when it hits the rear of the intake, and you'll get a lot of backpressure. But if you use that surface to draw the air into turning, then you'll get it turning and spinning before it hits the curved back wall, and it will ram 180 degrees back and through the filter.
Old Jul 25, 2006 | 10:22 AM
  #115
SpiderX's Avatar
SpiderX
Maybe this will do
Uh.........Uh........Uh......what were we talking about: cool:
Old Jul 25, 2006 | 10:34 AM
  #116
Chappy's Avatar
Chappy
Maybe this will do
Great topic and discussion, but I WANT ONE OF THESE TOO!
Old Jul 25, 2006 | 11:07 AM
  #117
Partsman's Avatar
Partsman
Legion_of_Doom
Do you have a starting point? maybe something we can build on?
Old Jul 25, 2006 | 12:53 PM
  #118
Bahamabart's Avatar
Bahamabart
We are bored.
1) Spidey posted "ags going on tomorrow". I did not know that Bob was latin for his tomorrow is a true manana!!
2) My IC unit arrives tomorrow as well as my vents but I can't get to them until Friday.
3) the vent post - hasn't moved. No pressure but I was hoping to do the vents this weekend and need YOUR expertise. Need to see those holes in your hood first.
So its like being in a holding pattern. BORED BORED BORED - its not easy living in the tropics - just anothet shitty day in paradise.
Old Jul 25, 2006 | 12:58 PM
  #119
MSFITOY's Avatar
MSFITOY
We are bored.
Yea...I'm gettin upset with Harbor Freight...their tracking sucs! I had to call twice and I think their CS is in New Zealand...they told me my saw has been shipped and that's all...their site says my order never got accepted...so we'll see:impatient
  #120
Bahamabart's Avatar
Bahamabart
I would but it would be much better accepted if MSFITOY did it . I'm a big fan of his work so I'm willing to buy the part as MY contribution.
Old Jul 25, 2006 | 02:59 PM
  #121
obehave's Avatar
obehave
So noble.
And they say chivalry is dead.
Old Jul 26, 2006 | 06:59 AM
  #122
lambspeed's Avatar
lambspeed
From a plan or top view, do the side walls also have to be curved or can they stay flat for ease of fabrication. Also will the water trap as you describe also change the flow going into the filter? Finally is better to fab as large as a box as possible (volume)
Old Jul 26, 2006 | 07:04 AM
  #123
Peter@M7Tuning
Side walls can be flat. If possible, filet the corners to avoid sharp corners, they'll trap flow. The water trap at the bottom is like a cup, and it doesn't need to be as large as I've shown it. It's mostly there to catch the water that will be running down the back wall. You'd make a few small holes, maybe 1/8th inch, maybe 4 of them, and probably use a hose to drain the water all the way out the bottom. Volume of the chamber is good, the more you have, the better it'll be at pressurizing.
Old Jul 26, 2006 | 07:25 AM
  #124
Partsman's Avatar
Partsman
Legion_of_Doom
EDIT: man i thought this thread was dead, i post a reply,
and you guys are already into it.
I'm really thinking about trying this...
and modify the insides for a smoother air path.
Do you guys think it will be high enough to grab some air?
The website says the height is 3.25"
Old Jul 26, 2006 | 07:38 AM
  #125
Peter@M7Tuning
3.25 inches is plenty high, and there are ways you can make it better. But how wide is it?
