Drivetrain Best procedure for cleaning the intercooler
Old Jun 27, 2006 | 07:05 AM
Yucca Patrol's Avatar
Yucca Patrol
I'll be cleaning my intercooler this weekend. I've read a few threads concerning this but I haven't figured out the best solvent to use?
Some have said to use denatured alcohol, others have said to use the aerosol intake cleaner. I suspect that it doesn't really matter as long as you use a clean solvent and let it evaporate before reinstalling.
I'm leaning toward the alcohol since I can buy a gallon of it and have plenty available for use.
Anyone have any particularly good tips for an intercooler cleaning procedure?
Old Jun 27, 2006 | 07:29 AM
norm03s's Avatar
norm03s
I used gasoline, then mixed 2cycle oil with it so it wasn't wasted for the chain saw and weed eater.
Gas works great.
obehave's Avatar
obehave
I use SuperClean( I cut it 2:1 for this) for the removal and then flush with brake fluid cleaner. I have on occasions just let a hose run water through it for a couple minutes instead of the brake cleaner.
Like you said, let it evaporate well. My leaf blower fits nicely
Never had any issues and I've done this maybe 7-8 times over the years. 2 different ICs.
Old Jun 27, 2006 | 07:34 AM
Johan's Avatar
Johan
Originally Posted by obehave
I use SuperClean( I cut it 2:1 for this) for the removal and then flush with brake fluid.
Ok...Please tell me this is a typo....Brake Cleaner I can see...carb cleaner I can see...Brake Fluid???? -- Johan
Old Jun 27, 2006 | 07:38 AM
petecrosby's Avatar
petecrosby
I used........nothing.
Because, after 72,000 miles and virtually zero oil usage, mine was clean as a
whistle and dry as a bone.
Old Jun 27, 2006 | 07:39 AM
phase IV's Avatar
phase IV
I use SuperClean( I cut it 2:1 for this) for the removal...
probably gonna need to use more Superclean and maybe some brake cleaner after the...
Old Jun 27, 2006 | 07:42 AM
SalemMINIDriver's Avatar
SalemMINIDriver
This must be. Any residual brake fluid residue would do much more damage than any amount of oil. As mentioned, gasoline is as good a degreaser as you are likely to find, but BE CAREFUL.
Old Jun 27, 2006 | 08:01 AM
obehave's Avatar
obehave
D'oh!
Thanks. edited to make sense
Old Jun 27, 2006 | 08:03 AM
obehave's Avatar
obehave
See post # 8
Old Jun 27, 2006 | 08:05 AM
obehave's Avatar
obehave
Ok Ok.. geez leave out 1 little word
See post # 8
Old Jun 27, 2006 | 08:13 AM
Johan's Avatar
Johan
See post # 8
see what happens when you have a reputation Don't worry I knew what you meant -- Johan
Thanks for the spelling lesson on vacuum...I tried to txt it in my phone the yesterday and it wouldn't work...then I remember there's two "U"s...
Sorry to get back on topic I use the cheap on sale Carb cleaner or Brake cleaner until there's no more Oil left. Then I hit it with the air compressor to dry things off. Cheers -- Johan
Old Jun 27, 2006 | 08:24 AM
Hammer's Avatar
Hammer
I'm too lazy to look it up: any step-by-step on removing the IC for cleaning?
Old Jun 27, 2006 | 09:10 AM
obehave's Avatar
obehave
Oh geez.. I have a reputation
Old Jun 27, 2006 | 09:26 AM
fishbulb's Avatar
fishbulb
I have used Simple green followed by a generous water flush afterwards on other intercoolers. took out all sorts of gunk & grime.
gave ti pleanty of time to dry after cleaning.
-jac
Old Jun 27, 2006 | 10:38 AM
JCampos's Avatar
JCampos
I stuck a latex glove over one end with a rubber band holding it on... dumped some acetone in the other end... stuck another glove on it, and shook it back and forth a few times gently. Then I let it sit for a bit on its side with the acetone in it, dumped out the dirty crap, and repeated once more.
I let it dry for about 20-30 minutes before stickin it back on there.
Old Jun 27, 2006 | 02:24 PM
Yucca Patrol
Thanks everyone. Sounds like there are lots of ways to skin this cat, but it boils down to adding a decent solvent of my choice and swishing it around until it comes out clean.
Great tip for using the latex glove. I'll bring a few home from the lab.
Old Jun 27, 2006 | 06:09 PM
ScottinBend's Avatar
ScottinBend
That is exactly what I did! Kind of anyway........lol. I just used a piece of 6mil visqueen instead of the glove.
Old Jun 27, 2006 | 07:11 PM
JCampos's Avatar
JCampos
Great minds......
Old Jun 30, 2006 | 08:04 PM
Yucca Patrol
I also wanted to add that I will also be cleaning the outside of the intercooler with the foaming condenser coil cleaner used on home air conditioning units.
This was suggested my my local independent MINI mechanic.
Old Jun 30, 2006 | 08:14 PM
obehave's Avatar
obehave
Nice tip
Old Jul 1, 2006 | 12:02 AM
MINIclo's Avatar
MINIclo
7th Gear Gal
How often is the intercooler supposed to be cleaned? Is it based on mileage or type of driving or what? Thanks.
Old Jul 1, 2006 | 10:47 AM
ScottinBend
I guess it depends on whether or not you have a catch can and what kind of driving you do. My experience has been that with my catch-can I don't have to clean the inside of my IC at all. I have had my OCC for over 2 years and have checked the IC 3 times since with no discernable oil build up at all. This is with a very nice mix of around town, spirited, and highway miles.
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
LAcooper
Sep 22, 2015 10:03 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
