Drivetrain Borla Agressive Installation problem
Old Jan 28, 2006 | 01:44 PM
hembrey's Avatar
hembrey
I recently installed a Borla Agressive on my '05 MCS. The rear hangers use the stock locations and stock bushings. When I installed it, the hangers hold the new exhaust system tight up against the heat shield and it buzzez and sounds horrible all of the time.
Any thoughts?
Old Jan 28, 2006 | 02:18 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Space the hangers down from the mounts with a few washers, that should help.
Randy
Old Jan 28, 2006 | 02:21 PM
BLIZZ's Avatar
BLIZZ
I just installed the exact same system on my 04 MCS. No problems at all.
What heat shield are you having trouble with?
Make sure when installing the clamps onto the pipes to think about the direction the clamp will face when pipe is installed. You need to be able to get to the clamp bolt to tighten but also watch for clearance from clamp/bolt to heat shields. Make sure to possition all piping before tightening any clamps. I found quite a bit of movement in the pipes, both rotatinal & in/out movement. Also don't forget to check how t/pipes are centered in bumper opening.- It realy helps to have a second person & a lift as I had.-- also make sure the heat shield isn't out of possition.
Old Jan 28, 2006 | 02:56 PM
hembrey's Avatar
hembrey
Both ideas helped considerably. I just spent $3 at the hardware store and 20 mins on my back on the cold wet garage floor (rainging and 40 in Chi town today), and all is well!! Thanks fellow motorers!!
Old Jan 28, 2006 | 03:41 PM
BLIZZ's Avatar
BLIZZ
Good luck my freind... and yeah, its raining in Springfield Mo. as well.
Old Jan 28, 2006 | 06:29 PM
armandCooperS04's Avatar
armandCooperS04
Borla exhaust
Can I ask you guys were you bought your exhaust sytems. I am trying to find the best price,thanks.
Old Jan 28, 2006 | 06:42 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Webb Motorsports!
Old Jan 28, 2006 | 08:59 PM
pooch1's Avatar
pooch1
Originally Posted by RandyBMC
Webb Motorsports!
Randy I still want to get that 2 % crank pulley done.
squawSkiBum
Oct 2, 2015 09:21 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
