Drivetrain New Larger Alta Intercooler!!!
Old Dec 15, 2005 | 02:15 PM
  #101
SpiderX's Avatar
SpiderX
Originally Posted by ALTA2
SpiderX,
The fan idea is something we could try but more like a last resort. I think the fans will flow enough air for cruising and idle, but above 50, i think the outside air will be going faster than the fans. But who knows something to test.
There is some funny stuff going on here.
after 50 it may work but I am thinking about the autoX application where you don't get to 50. there is no doubt that at some speed the fan will be a impediment....unless of course its a TURBOFAN....possibly with an afterburner....but I digress....again.
I am very interested in Andy's findings.......
Old Dec 15, 2005 | 02:29 PM
  #102
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by Bahamabart
So lets see if I have this right - If I put a big fat sweaty guy on top of my IC, I'll get more HP? .
Only if he's a criminal. Didn't Ingsoc say it cools by conviction? So put a big fat, sweaty convicted criminal on your IC and you will not only LOOK cooler, you'll BE cooler! You could do a baseline test with a non-criminal.
On topic - I did not see a horizontal TMIC at Laguna Seca yesterday, but hope I do next year.
Old Dec 15, 2005 | 02:55 PM
  #103
jlm's Avatar
jlm
reminds me of the train conductor, who, convicted of murder, could not be executed in the chair.
Old Dec 15, 2005 | 04:28 PM
  #104
ALTA2's Avatar
ALTA2
Manufacturer
SpiderX,
I don't know if 50 is where the fans may not blow fast enough, i just made up the number as an example. But you bring up one of the concerns we have with air flow through (or around for Will) the core. I think that the fans will surely help at some point but what is that speed? At an auto cross, with slow speeds i think both ICs will suffer some from the low air speed, but how much??
Maybe the fans will be an important part of the kit. In fact it would be very simple for us to make it an add on at at least. Maybe i will send Andy something next week after his findings.....
Old Dec 15, 2005 | 05:38 PM
  #105
Dr Obnxs's Avatar
Dr Obnxs
for some wild estimates...
If the scoop is 2" x 10", and all one assumes that about half the air is stalled by backpressure, then you're looking at about 360 CFM through the IC at 60 MPH.
If you use an axial fan like the often derided eRAM that does 1000 CFM at 1 psi as a sucker, the cross over between what it would do at a stand still and the speed needed to create more flow than that would be somewhere around 80-100 MPH. So the sucker would be good for low to not so low speeds, and you can use it at rest to prevent heat soak too!
All these are plus or minus several hundred percent!
Matt
Old Dec 15, 2005 | 05:40 PM
  #106
SpiderX's Avatar
SpiderX
SpiderX,
Thanks for taking my concerns seriously.....passive venting is a much better solution.......no moving parts and no maintenance......
Old Dec 15, 2005 | 07:35 PM
  #107
macncheese's Avatar
macncheese
You mean the train conductor that was so in debt that he resorted to murder?I remember that. He robbed and killed a guy over not one penny, not two pennies, not three pennies, not four pennies, not five pennies, not six pennies, not seven pennies, not eight pennies, not nine pennies, but TEN PENNIES for every dime he owed! Tragedy.
Cheese
Old Dec 16, 2005 | 12:04 AM
  #108
RECOOP's Avatar
RECOOP
Originally Posted by maxmini
No but I noticed that as well . I think recoop gave me that name for some reason. William to be exact
Randy,
What are talking about? If my memory serves me, I've called you either "Randy" or "Max". In tracing the basis for your post back to its origin, I believe that I referred to "Conehead" as "Bob S.", indicating his first name and the first letter of his last name.
Motor on...
Old Dec 16, 2005 | 12:27 AM
  #109
pyratio's Avatar
pyratio
Coordinator :: Hawaii MINI Motoring Club
MMMMMmmmm....big.....
--Beauty of an intercooler! Yes yes, less arguing, more testing!
--pyratio
blah,blah,blah, blah....Here is the proto diverter.
Old Dec 16, 2005 | 04:11 AM
  #110
jlm's Avatar
jlm
it's that he was a bad conductor
Old Dec 16, 2005 | 05:26 AM
  #111
norm03s's Avatar
norm03s
Alta , the way over the top solution would be to isolate the IC and Insulate it. At the scoop end cut out the metal protruding into the intake path. Make a different scoop trim to catch the flow and direct it into the IC. At the rear of the IC attach a duct that turns up and seals to a vent in the bonnet. This would of course require cutting up the bonnet which wouldn’t be popular. Or a replacement bonnet with this designed into it.
I have other thoughts on the matter of the fan operation and configuration with my Y idea.
Old Dec 16, 2005 | 05:32 AM
  #112
SpiderX's Avatar
SpiderX
If this demonstrated nice gains I would go for it/ depending on cost of course
Old Dec 16, 2005 | 06:35 AM
  #113
obehave's Avatar
obehave
Ignore filters??
Anybody know if there are ignore filters on this site?
Some of the posts here are like a freak show. I don't want to read them but I do anyway and then hate myself for wasting the time.
Thread Spam. It pretends it's meaty.............. but it isn't.
Old Dec 16, 2005 | 07:08 AM
  #114
eMINI's Avatar
eMINI
Gleaned from another thread...
Originally Posted by YuccaPatrol
If there are particular people that you do not care to hear from, you can place them on your ignore list. Just click on their profile and select them to be added to your ignore list. . .
You'll feel a great sense of satisfaction when you make them go *poof* and erase them from your NAM experience!
I've used it and found it to be quite effective.
Old Dec 16, 2005 | 08:27 AM
  #115
OldRick's Avatar
OldRick
Unfortunately, the Ignore function cannot be used for anyone who is a moderator of any forum...
Old Dec 16, 2005 | 08:40 AM
  #116
Bahamabart's Avatar
Bahamabart
Originally Posted by andy@ross-tech.com
Or better yet, the Bahamas!
Your welcome to come to the bahamas, there is no better place to test heat soak AND I have plenty of room however driving over here would change the test for you would now be testing a WATER to AIR IC . I know you have been wanting to test one but unfortunaely ALTA has not given anythought whatsoever to seaweed or fish entering the scoop.
But go for it pop the sunroof and get yourself a good snorkel.
Old Dec 16, 2005 | 09:10 AM
  #117
obehave's Avatar
obehave
Thank you
Old Dec 16, 2005 | 01:31 PM
  #118
ALTA2's Avatar
ALTA2
Manufacturer
Fans may be a intergral part of the IC in the end, but we will have to see. Cutting the hood is not for everyone, and the cost of a new hood os very expensive, turning an $800 IC into a $1800 really quick. But one could be made to look pretty cool! We should get some good info back on monday!
Old Dec 16, 2005 | 06:00 PM
  #119
Wake|MCS's Avatar
Wake|MCS
Sounds good, can't wait to see the numbers. If you need a stock MCS (other than an intake, and your pulley in my back seat) in hot weather (Miami, Florida), send the intercooler my way
Old Dec 17, 2005 | 01:35 PM
  #120
Bahamabart's Avatar
Bahamabart
Miami would be a good testing ground, land of heat soak. While Andy will test & analize the crap out of it; winter weather is a factor.
On another note the more I look at this puppy (it is beautiful), I suspect that at high speeds it will out perform the aftermarket flat mounted IC units and guess that at lower speeds the flat mounts will perform better. So theres my guess which you can all hang me by later.
Old Dec 17, 2005 | 03:22 PM
  #121
andy@ross-tech.com's Avatar
andy@ross-tech.com
I am awaiting a couple pieces of test equipment that I lent out, so data unfortunately not be available on Monday. The good news is that I have a bunch of time off before the end of the year, so I'll have time to do lots to testing. Tomorrow I should at least have a chance to install the IC and make sure it fits correctly, etc.
Old Dec 17, 2005 | 04:32 PM
  #122
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
thought better of it. (edited for base humor)
Old Dec 17, 2005 | 04:34 PM
  #123
///ACS330Ci's Avatar
///ACS330Ci
Originally Posted by Veni_Vidi_Vici
I hope this is just a typo!
LOL
Old Dec 18, 2005 | 01:38 PM
  #124
andy@ross-tech.com
I love base humor ... what did I miss?
The IC is installed and my hood closes (barely), so I'm off for a test drive.
Old Dec 18, 2005 | 03:19 PM
  #125
///ACS330Ci
Initial inpressions?
