Drivetrain Free HP
Old Nov 22, 2005 | 09:35 AM
Sara_JCW's Avatar
Sara_JCW
Free HP
is there N e way to get free HP out of a JCW or a copper s
Old Nov 22, 2005 | 09:53 AM
neilgj's Avatar
neilgj
U n joker r 1. U need 2 talk 2 him
Old Nov 22, 2005 | 10:13 AM
goaljnky's Avatar
goaljnky
N e ? Do you mean North East?
Old Nov 22, 2005 | 10:14 AM
Wagnbat's Avatar
Wagnbat
s33k Joker.
kkthxbai!
Old Nov 22, 2005 | 10:21 AM
xsmini's Avatar
xsmini
^^ you guys are rough this morning
Free HP, not to my knowledge. Best bang for the buck would be sc reduction, hai, lighter wheel/ tire combo etc...
Nik
Old Nov 22, 2005 | 10:38 AM
agile_moments's Avatar
agile_moments
ahhh too many laughs.
Old Nov 22, 2005 | 10:50 AM
Eric_Rowland's Avatar
Eric_Rowland
Ooh, is this like 'Talk like a Pirate day'?
N e won nos u kn knot gt n e thng R thn eh dg n a coohhpr
But if you travel downhill, you get free power!
Old Nov 22, 2005 | 10:52 AM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
strip the interior, remove a/c, remove alternator, and pull the filter off the intake...
car may not last long though...
dan
Old Nov 22, 2005 | 11:20 AM
Sara_JCW's Avatar
Sara_JCW
well here is some stuff i have done to my car ok
alta 15% reduction pulley
alta short shifter
alta intake system with silicone
H-sport springs
H-sport adjustable control arms
H-sport 22mm rear sway bar
Koni Adjustable Shocks
Drilled Brembo Rotor
green stuff brake pads
i think that it.... now i need to dyno it
Old Nov 22, 2005 | 11:24 AM
Wagnbat's Avatar
Wagnbat
ROFLCOPTER!
Old Nov 22, 2005 | 11:25 AM
Sara_JCW's Avatar
Sara_JCW
that funny
Old Nov 22, 2005 | 11:41 AM
Dr Obnxs's Avatar
Dr Obnxs
So for power, you've only really done two things...
alta short shifter
H-sport springs
The pully and the intake. Cheap exhaust mod is the "one-ball", not free, but cheap. Next power stuff isn't free at all, but will do something to create more power.
ECU tune (lots out there, none free). There's lots of power here.
Then you get exotic.
Lighter rotational mass (doesn't create any more HP, but lets you use what you have better) via crank pully or flywheel.
Head work. (no where near free).
You also may want cooler plugs too.
For cost benenfit (and this does need updating) you can look here.
Matt
Old Nov 22, 2005 | 11:47 AM
Bahamabart's Avatar
Bahamabart
I got some free HP for ya but it will cost ya!
Old Nov 22, 2005 | 01:24 PM
ingsoc's Avatar
ingsoc
that funny
I'd say that's half-way towards English.... . I kid, I kid. Anyways, removing sprung weight nets no "free power"- just perceived power . Sprung weight and drivetrain weight reduction can theoretically gain you back some power lost to the ground, but not hugely without big investment! With pulley, you should get colder plugs. But, is your car JCW or not [I noticed the sig]?? If it is, it should have colder plugs, I thought? And yeah, the head would probably be the only other thing to do, but again: do you have a JCW? The head can be SIGNIFICANTLY improved, but that will cost lotsa $$$.
Old Nov 22, 2005 | 01:40 PM
chows4us's Avatar
chows4us
Why?
Old Nov 22, 2005 | 01:44 PM
Sara_JCW's Avatar
Sara_JCW
yes it is a jcw....and just to see how much hp it put out
Old Nov 22, 2005 | 02:43 PM
armandCooperS04's Avatar
armandCooperS04
Your car looks great!
Old Nov 22, 2005 | 05:06 PM
k-huevo's Avatar
k-huevo
You don’t have to go the extreme and strip the interior but; taking out the rear seats and seat belt hardware will remove almost fifty pounds. Removing those items will improve acceleration and gas mileage by a little.
Sara, you have some great pictures on the LSMC site, you should add some to the gallery here.
Old Nov 22, 2005 | 09:11 PM
supersand's Avatar
supersand
Drive when the air is cold... Totally free
Old Nov 23, 2005 | 03:45 AM
mdsbrain's Avatar
mdsbrain
Is free HP like that thing you rolled off the dealer lot with
Old Nov 23, 2005 | 05:38 AM
Soul Coughing's Avatar
Soul Coughing
i just got back from dropping my sister off at school and the temperature is around 26 degrees. The car absolutely flew! i couldnt keep the tires from spinning in 1st and it felt so much faster! how i love the colder weather
Old Nov 23, 2005 | 08:43 AM
chows4us's Avatar
chows4us
Sara ... these jokers are being a bit mean to you
Bottom line ... nothing is free
Old Nov 23, 2005 | 09:10 AM
Morris9982's Avatar
Morris9982
If you already have the JCW engine kit (and I think you do) then there isn't a lot you can do for low bucks.
You already have a 15% (approximately) pulley. Most on here do not suggest going to the 19%. You already have a more open exhaust and intake as well as a reworked cylinder head, larger fuel injectors, and colder plugs.
There is a lot of debate as to how much the JCW helps versus aftermarket stuff, but anything you add at this point would not make as much difference as it would on a regular S without the JCW kit.
I think the only thing you might want to consider would be an aftermarket intake, such as the Alta unit. It may help some over the JCW box. If nothing else, it will add some nice sounds that will at least make you think it's faster.
Have fun no matter what you do.
Old Nov 23, 2005 | 09:21 AM
10851CS's Avatar
10851CS
We're all looking for free (or at least cheap) horsepower
Old Nov 23, 2005 | 09:36 AM
TonyB's Avatar
TonyB
Agreed. Even more so... you can actually get paid to increase hp! For the 3 or so hp "gained" by removing the rear seats, I made 300 bucks as I sold them to some fella in NY. I guess I've sold-off many things now, but in reality, nothing ever is truly free as cost is often times much more than the mighty dollar. Time, effort, energy, etc are often always paid in any endeavor... I'd rather max these out though, as opposed to the credit card .
