Drivetrain Jcw Injectors With Dinan Stage 5 Software
Old Sep 1, 2005 | 05:52 PM
d6-mcs's Avatar
d6-mcs
i was wondering if i got jcw injectors if i they would work with my dinan stage 5 software...the software is design for the boost kit..so they must move the fuel ratio...i just dont know if they changed anything on the injectors....because most of the time you need a chip or a ecu upgrade to tell the injectors to open up more...if anyone could help me out on this that would be awesome..
thanks
BATES
Old Sep 1, 2005 | 06:30 PM
d6-mcs's Avatar
d6-mcs
anyone...
BATES
Old Sep 1, 2005 | 06:34 PM
MINIAC's Avatar
MINIAC
Why not ask Dinan?
Old Sep 3, 2005 | 01:42 AM
d6-mcs's Avatar
d6-mcs
its dinan????
Old Sep 6, 2005 | 09:14 PM
d6-mcs's Avatar
d6-mcs
Old Sep 7, 2005 | 10:02 AM
DSO72's Avatar
DSO72
From my understanding installing, larger injectors would not work. With the pulley upgrade you also get a fuel regulator. The regulator combined with the software change act as if you installed bigger injectors. Dinan uses the factory injectors with modified software. By stabilizing the fuel rate (volume)and incresing the time that the injectors stays open allows for an increase in fuel. I think it is a different way of increaseing the fuel rate without changing the injectors.
Old Sep 7, 2005 | 08:04 PM
d6-mcs's Avatar
d6-mcs
well the only problem is that i am not running there boost kit...which includes the regulator and fuel pump....
BATES
Old Sep 8, 2005 | 07:59 AM
blasman1's Avatar
blasman1
I have the JCW Injectors
I don't know if they make a difference as far as power is concerned, but they don't seem to cause any problems. I have the boost kit, DINAN stage 5 software, JCW injectors, throttle body, and CAI.
Old Sep 10, 2005 | 03:07 PM
d6-mcs's Avatar
d6-mcs
cool at least someone else has somewhat info i needed to know..thank you....did the injectors help at all..
BATES
Old Sep 12, 2005 | 09:16 AM
blasman1's Avatar
blasman1
I would say barely noticeable normally, but just a bit more oomph when approaching the 7300 RPM redline...
BATES
Old Sep 12, 2005 | 12:57 PM
Minirox's Avatar
Minirox
I have the dinan TB and stage 5 software. Alta 17%, M7 400 injectors,Piper-X CAI and one ball exhaust. The car runs great. Gas milage improved. No issues to date.
iggi
18
Feb 9, 2026 01:00 AM
Teh
Aug 22, 2022 04:37 AM
minimofo
Apr 4, 2016 07:36 PM
cmanlu
R58 :: Coupé Talk (2012+)
Aug 25, 2015 07:35 AM
