Drivetrain Motor mounts?
Originally Posted by gandini
And Yankee enginuity can't spell. "Their" -- don't you mean "There"?
And don't give me that crap about "well, you figured out my meaning, so I don't need no steenkin grammah..." It's the lingua franca. Use it, and the better you use it, the more people will listen to what you have to say.
I'll stick with my JDM "bling" NRG damper, thanks. Mine is a street car first and foremost, so those "little vibrations", some of which are not at idle (my mid-2k resonance, for example), are actually a factor in my decision making.
cheers,
cheers,
While you're at it, it's "ingenuity"
wow, way (to,too,Two) bitter. Why are you pissed, because you found some cheap crap for resale for a buck or two. And people out here in NAM are trying (to,too,two) be innovative? Anyway, just showing a different option. And in regards for the personal attacks, they are not needed!!!Also I dont plan on offering a group buy on anything I make for myself. Most of the products for sale (by,Buy,bye) most companies started out grassroots. But seeing that I already have a motorsports business, It is far from backyard.
Originally Posted by PARTSMAN109
Purely bling? please.
Half of the damper is hidden, so how can it be bling?
I'll bet you the pink slip to your car that a group buy list for your backyard mounts won't be HALF as long as the one me and Shoe have going. Take your "yankee enginuity" somewhere else.
Originally Posted by lambspeed
Good one, another insult
Sorry but my post was not directed at you Obehave
Partsman, tell me all the flaws
It was a joke. That's why I did the smiley thing.
Not intended as an insult. Humor check maybe, insult no.
Before this gets out of hand gentlemen. If I harped on anyone (Partsman109)for selling what you are selling, my apologies. I was just trying to stir the pot for creative things, not insults. My notions were to simply get people understanding that adding something more may not be the answer. Is the dampner add on a good idea, yes. But judging by the oil all over your frame rail and my torn upper mount, A better solution must be made. Most people may not benefit from changing all kinds of mounts and brackets.
Fabricating the mount was a must for me since the rubber in the factory one was toast(so bad it put a dent in my hood from the intercooler diverter) So yes their(there) maybe flaws. It works though.
I have friends with a 800+ horsepower Evo and a elastomer dampner as in the one you are offering is the only thing to keep torque controlled. So it does work. www.turbotrix.com
some pictures of the engine with that dampner are on the site
Can we all just get along?
I applaud you for fabbing a replacement for the factory setup as we all know it may not be up to par when making more power than stock.
My little dose of LITHIUM
Let's get something cleared up: it's a damper, isn't it? What's this dampener, or dampner thing? In Australia, damper is a variant of unleavened bread, a dampener is something that when sat on makes your bum all wet, and a dampner is a made up word.
So what is it?
cheers,
So what is it?
cheers,
put in a search for dampner on google and see what comes up. Second I believe via PMs that all is well here on this thread. Can we get back to the first post in this thread and figure out what can be done about the factory engine mount and what would also called the upper torque dampner?
Gandini Your 2k resonance may be your exhaust. I have a Borla w/OBX and the factory cat and it vibrates @ 900 rpm and smooth till redline.
Is this better then(than) bashing each other over spelling?
Also damper, dampener, and dampner all come up w/ the same relative meaning. I think everyone here(hear) has made mistakes.
ingsoc: that links redirects to the word dashpot, and on that page the only spelling is damper. Thanks for clearing that up. (yes spelling is important)
lambspeed: You may be very right about the exhaust! The damper may not be the cause of the resonance, but simply exacerbating it. I'll keep the damper and learn to live with the vibration.
cheers,
cheers,
cheers,
cheers,
Engine dampers vs stiffer bushings
HotRodPilot,
This thread has wandered a bit.
There was a thoughtful previous post about making modifications to the engine bushings that stabilized engine rocking movement but added vibration to the passenger compartment. That post describes the bushing modifications. The bushing solution is complicated by the fact that early cars had a stabilizer rod system with bushings on the passenger side of the engine, and later model cars don't have that stabilizer rod, but rely on a new motor mount style of construction. So, the bushing modifications on later model cars are limited to modification of the driver's side a.k.a. transmission motor mount bushings. My experience is that installing stiffer bushings on the transmission end adds little or no improvement in stability and introduces a lot of vibration, same as previously posted in this thread.
The "damper" is entirely different from the "bushing" approach to stabilizing engine rocking movements. The "damper" is an aftermarket piece that is constructed like a shock absorber that slows down and limits engine rocking movement. A "dashpot" is the same as a "damper" which is the same as a "shock absorber". The real key to effective damper action is to solidly mount the damper to the chassis. Not an easy task.
So, it is considered desireable to limit engine rocking motion. Early cars get good engine control by replacing the stock rubber bushings with stiffer aftermarket bushing in the passenger side control rod system. Later cars can get some improvement in engine movement control by installing a "damper".
Actually your question had long been answered in this thread. The lack of response is probably because people feel that you aren't taking in the information already presented. Read carefully.
Regards,
John Petrich in Seattle
Regards,
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
