Drivetrain Ready to dyno AGS
Old Sep 2, 2005 | 05:18 PM
  #601
SpiderX's Avatar
SpiderX
"East Coast has no love for the West Coast"
didn't some rapper say this on an awards show?
God I must be bored to tears to post that!
Old Sep 2, 2005 | 05:27 PM
  #602
minimc's Avatar
minimc
Originally Posted by MSFITOY
Ram this:smile:
LOL
Now that there's a BIG ol' gapin yaw ain't it Kudos for the dyno & dremel time Sid
A good labor day weekend all. I'm motorin outta here til Monday. Look forward to a good read when I get back. Everyone B safe
Old Sep 2, 2005 | 05:37 PM
  #603
maxmini's Avatar
maxmini
Originally Posted by jlm
actually, Maxmini used the term "ram air effect" in post 505;
jlm first commented about it in post 536
then Maxmini c made the "I don't see..." comment in post 542
etc.
since 505 precedes 536, this by Maxmini is slightly off-base:
"If you had posted the entire quote you would see that I was using the term only after you used the term " ram air effect " "
Now if you really do your homework you will see that is was posted first in thread 320 which is ... well you get the idea. Thanks for the support . I knew we could get over 15,000 views by dinner time .
Randy
M7 Tuning
601 posts and 15,029 views
Old Sep 2, 2005 | 05:59 PM
  #604
jlm's Avatar
jlm
It was my point to question the idea suggested by Max that the AGS may have been at a dis-advantage in the test since it was suggested by Max that the AGS relies on the ram air effect, an effect not present during the dyno test.
Frankly, I didn't and don't see that any of the intakes uses a ram air effect.
this seems like an area of interest on its own, but it looks like Max is distracted more by the post count. Spin on!
Old Sep 2, 2005 | 06:40 PM
  #605
Wenzor's Avatar
Wenzor
dodge questions, evade getting pinned down, misdirection, dodge questions evade getting pinned down, misdirection....maxmini's got skills that president Bush would envy.
Oh well. eventually Bush's approval ratings did fall....7 years later.
Old Sep 2, 2005 | 07:21 PM
  #606
J0kER's Avatar
J0kER
Da Da Damn!!
that looks pretty sick yo!! i like it, its really ready now......................:smile::smile: :smile: :smile: :smile:
no wonder U werent returnin' anybodies Pm's, looks like u were a little busy
Ram this:smile:
Old Sep 2, 2005 | 07:23 PM
  #607
J0kER's Avatar
J0kER
bored nahhh!! it just sounds to good to not post!
Old Sep 2, 2005 | 07:55 PM
  #608
silver-mini-s's Avatar
silver-mini-s
Just Finished doing mine! Thanks for the great Idea!
Old Sep 2, 2005 | 08:09 PM
  #609
MSFITOY's Avatar
MSFITOY
You're welcome...where's your gallery? I wanna see your PS Mini
0 tickets in 10 years
Old Sep 2, 2005 | 08:39 PM
  #610
ALTA2's Avatar
ALTA2
Manufacturer
Now i have to check this thread while i am at home
M7,
I have done the test you are asking us to perform with you. I didn't need a $750,000 test facility, just a $60K dyno and a couple of cars. Both cars, MINI and a B6S4 (just happened to be dynoing that day) had our FOAM filter and a famous pleated brand. Both had the same basic outside dimensions. Both filters were new and un-oiled (just to keep it more comparable do to the varience in oil that could be applied). On the 165WHP mini, both filters were very close, and ours showed a slight 1-2WHP gain (many runs were done with each). On the 290WHP Audi once again both showing similar numbers ours was slighlty ahead by 2WHP pretty consistantly. Now 1-2WHP who cares,thats not enough to feel on the road. This proves that both filters, using the actual measured surface area (length x width x hieght) flow basically the same.
When by the pleated manufactures claims their pleated filter acutally has 2 times the surface area as a similar size foam, it should have twice the amount of flow or potential to flow. I find it hard to belive do to them both producing the same HP.
Filters have let say "atomosphere" surrounding the filter that air can be drawn from. This doesn't get twice as big with a pleated vs foam in the same size.
We keep talking about making this filter bigger by 2 times because of the pleats, how about we take it and make it smaller to match the foam surface area?? Basically the pleated filter guys would say no way! A foam filter that is 5"x8" and a pleated that is 2.5"x8" should flow the same, right, no they don't because they both draw from the same size "atmosphere".
We already fight an up hill battle with customers about our foam filter vs. the famous pleated type, and that is why we go into great detail about this and that is why we stick up for them so much. We firmly belive the work the same in most condition and a little better when dirty.
By no means is your filter type bad, they are eqauls in flow when sized the same. All filter manufactures have worked toward that filter that flows like a bare tube. And with all the new technologies, and fibers used to make filters, most all types are nearly there. That is why there isn't a huge difference in flow when sized the same.
But our filter we use on our intake is bigger, and it is because we have the room to make it bigger, which in turn it should flow more. And i think this great test shows that.
In the end, it comes down to 3 main things that makes someone by this part. Price, Performance, Appearence. And everyone will be buying them based on there own order of importance. Someone that is concerned with appearce may go for the AGS because the SOUND, and how cool the carbon shield looks. Then there will be that person that is concerned about price and will go for the PILO intake, which still produces great gains over stock. The ALTA intake will fit that person that wants the performance, price is somewhat of a concern.
We all 3 (i know there are many more out there) hit different types of customers. There is always going to be that guy set on the AGS that we will never catch, and there is always going to be that PILO intake guy that you will never catch. All we can do is provide the most accurate info about our intake in hopes that it will attract that 2% buying market to us.
Threads like this helps everyone out. It shows ours make good power, it shows how different and inovative your is and it shows the PILO intake and how much HP per dollar you get. Once again, 3 different buying customers.
Thanks again for the hard work done here, and for the sprited conversations!
Old Sep 2, 2005 | 09:42 PM
  #611
maxmini's Avatar
maxmini
Jeff nice to hear back from you . Great post . I think that S&B is as interested in how both styles of filters stand up to a particle test which is why you need the sophisticated test equipment. They feel the flow will be similar but feel that the foam type lets a lot more " dirt ' thru which in turn will in time hurt the motor.This is their theory not mine but it is in part the reason we chose the pleated filter. They are still very interested in testing your filter against theirs with you or your representative present. I agree it is nice to have such a spirited discussion and this is a dusey 609 posts and 15,351 views you have to be kidding me
Randy
m7 tuning
Old Sep 2, 2005 | 10:09 PM
  #612
MINIAC's Avatar
MINIAC
How easy or hard the intake is to install might also factor into a person's decision on which one to buy
Old Sep 2, 2005 | 11:06 PM
  #613
Tüls's Avatar
Tüls
Turbius Maximus
Originally Posted by maxmini
Maby you can give us a better description than "ram air". The way ours works is the larger snoot opening is forcing air into the filter air which is contained within the heat sheild. The back of the sheild is open to a degree to give unused air a way out so as to not cause a bottleneck. The air path is not sealed so I do not think the term "Ram Air " truly applies. Your thoughts ?
Randy....thanks for your thoughts.....I appreciate that you read all that..I know it was lengthy...but I like many of us am very passionate about what we are all trying to achive in improving the Mini...
I have to say that AGS pretty much sums it up....I mean CAI is the only other thing....although I am sure if I was to sit around and come up with somethign I could..heh heh....anywho....thanks again....if anything smacks me over the head I'll be sure to let you know
Old Sep 3, 2005 | 03:29 AM
  #614
SpiderX's Avatar
SpiderX
Ram this:smile:
Sid,
is this the way your car has been or did you just do this and what improvements , if any did you feel?
Old Sep 3, 2005 | 06:04 AM
  #615
MSFITOY's Avatar
MSFITOY
Bob,
I took some good advice and went into the garage to chill I've had the M7 heat shield for some time but hadn't put it on due to custom work needed to integrate with the Alta TMIC. Once fitted, I open up the intake opening to match the heat shield as much as possible. I was long past the point of return since this hole was started. I also dremeled out the blocked portion of the Aero grill at the right side to allow as much air in as possible. No way to measure inprovements but I'll let you know how it feels after today's drive
Sid,
Old Sep 3, 2005 | 06:07 AM
  #616
andy@ross-tech.com's Avatar
andy@ross-tech.com
MSFITOY,
Have you had a chance to re-read and re-think this post you made?
https://www.northamericanmotoring.co...&postcount=492
I don't see where you (along with Kaelaria/Andy) get off demanding so much of anything with your condescending attitudes after we spent so much of our times trying to serve this community with honorable intentions. We DO have full time jobs and families to attend to. Your comments alluding dyno manipulation is simply offensive. If we wanted to sway the results towards AGS, why the hell are we even having this discussion...it wouldn't have even been close!
I'm waiting for an apology.
Old Sep 3, 2005 | 06:41 AM
  #617
ingsoc's Avatar
ingsoc
Originally Posted by andy@ross-tech.com
MSFITOY,
Andy, with all due respect, in light of the fact that you neither conceded that you might have come off as critical nor even considered changing or apologizing for any of your words, I can't see why he would then be expected to reconsider.
Old Sep 3, 2005 | 06:45 AM
  #618
andy@ross-tech.com
Have you been following this thread at all? I don't recall criticizing MSFITOY or his methods with this dyno tests. Rather, it is the M7 apologists like yourself who are putting down the testing methods and results. Re-read this entire thread and you'll see what I mean.
Old Sep 3, 2005 | 07:17 AM
  #619
ingsoc's Avatar
ingsoc
I completely disagree with your appraisal. We may be critiquing and chiming in for the betterment of our understanding, but I at least have never claimed that they were at all wrong. I happen to be a big supporter of numbers and constructive interpretations/criticisms. That is what breeds progress. I just make it a point to fall short of implicating ANYONE. The thing is, how could they possibly know which way is right when no information existed? That is how I see it.
Now, I will not speak for anyone, but I think that the offense caused has been by people who are trying to de-rail the natural progress of data analysis. These guys put their time in so we could discuss. Yet, people come on and take jabs or go off topic or whatever, just to prevent analysis from being digested. That is what makes things seem like they border on time wasted. Surely, though, there is much to appreciate in the analysis if we keep this to the issue at hand, man...the intakes...
Read: Let's leave him alone/not bother anyone about things which are not the topic of the thread...
Old Sep 3, 2005 | 07:54 AM
  #620
jlm's Avatar
jlm
I'll agree to this: the dyno testing was done fairly well, the results were useable within the margin of error (1% is generous...that would be 1.5 hp). The point was to get some numbers, not more speculation.
on the other hand, extrapolating to road conditions is totally speculative and where most of the BS comes in: it is tempting for a low dyno performer to claim road condtions would show different (better) results, but again, that is speculation.
Old Sep 3, 2005 | 08:06 AM
  #621
andy@ross-tech.com
Today:
Yesterday:
Simple Andy: it was choked of air at the top end when it is breathing the hardest. It would otherwise have kept in stride or higher. The AGS was, unlike the others, located in a small corner of the engine compartment where air normally is in abundance at speed, but where air couldn't get with the fan provided. The other two intakes had their tops open to the surrouding environment and therefore directly benefit from an essentially infinite air supply- this planet of ours.
Maybe the fan blew cooler air more efficiently over the inlet to the conventional location than to the AGS location. The AGS still did quite well, and I've yet to see most of you realize this. To tie while under suboptimal conditions is pretty freaking nice.
Also yesterday:
Feeling a little clever today Andy? What makes you presuppose that dynos were done under these conditions in the first place? M7 has said repeatedly these aren't the right conditions.
Old Sep 3, 2005 | 08:44 AM
  #622
jlm's Avatar
jlm
If you go back over the heap, Maxmini implied that the dyno conditons were perhaps negatively skewed as far as the performance of the AGS, which he stated would benefit from its ram air like effect under road conditions, a situation not provided by the dyno.
that is an example of a speculation, not a measured condition. not entirely un-reasoncble, but not to be confused with the measured results either. It also piqued my interest in how much ram air effect might be there for the AGS and whether it is there for any of the intakes.
Tuls added some clarity, but what I saw from Maxmini was a diversion. Any wonder why M7 gets the scrutiny?
Old Sep 3, 2005 | 09:26 AM
  #623
Eric_Rowland's Avatar
Eric_Rowland
Who question the testing?
Don't want to get/keep things off track, but we have to set the record straight here:
Post 414 by ingsoc:
"Also, on those runs, the AGS reached 101 mph [power peak] 0.03 secs FASTER. I can only therefore figure that the dyno guy lifted his foot, because the AGS was ahead all the way til ~101 mph. The AGS was stopped at 104, but the ALTA continued [to redline, 105]. Maybe the AGS is faster up top, too, but he just lifted and made them even???"
Post 619 by ingsoc:
"We may be critiquing and chiming in for the betterment of our understanding, but I at least have never claimed that they were at all wrong. I happen to be a big supporter of numbers and constructive interpretations/criticisms. That is what breeds progress. I just make it a point to fall short of implicating ANYONE."
edit: editorial - Andy is always posing questions, but in this thread I've only seen Kaelaria with repeat smartass 'I told you so' posts.
Old Sep 3, 2005 | 10:00 AM
  #624
andy@ross-tech.com
It's fascinating to watch the pattern of certain tuners.
1) New product is hyped, claimed to do lots of amazing things.
2) Product is questioned by community.
3) Tuner either supplies irrelevant data or refuses to post any data at all.
4) Product is questioned by community.
5) Tuner states that happy customers will have to supply data.
6) Product is questioned by community.
7) Happy customers test product and it fails to live up to expectations.
8) Product is questioned by community.
9) Tuner claims faulty testing method/setup, or that the benefits are "unmeasurable".
Old Sep 3, 2005 | 10:15 AM
  #625
Eric_Rowland
Oops, spoke too soon.
Well, he hasn't made any disparaging remarks about Sid/MSFITOY, or the testing procedures, IIRC.
