Drivetrain Resetting ECU.. Should I or Should I not.?
Old Aug 5, 2005 | 09:31 PM
sprp85's Avatar
sprp85
Hello all..
a member who is too busy motoring everywhere
in his 2.8 weeks old mcs with 2002 miles.
Well. guess what.
I've been reading on some posts regarding ECU resets.
talking about 'learning' the way I drive.
The main reason of me wanting to reset my ECU is that I've learned how to drive manual on my new mini with lots of stalls during my 'first-time'.
Should I go ahead and reset, then drive it like there will be no tomorrow?
god.. I love Mini. Made me crazy.
Old Aug 6, 2005 | 12:42 AM
jggonzalez's Avatar
jggonzalez
I've heard similar comments about the Mini "learning" how you drive. One person even told me to ignore the break-in period and drive at WOT from day 1 so my car will perform better. (Of course, this person doesn't own a Mini!) I was thinking of following the break-in guidelines and then resetting my ECU. My method should give the same performance after 1.5K miles, right?
Old Aug 6, 2005 | 04:42 AM
Tarzan's Avatar
Tarzan
remember and forget
The computer continues learning and revising, so as your driving improves, it will keep up.
Old Aug 6, 2005 | 05:47 AM
hugh's Avatar
hugh
Novice Question
Newbie here checked Owners Manual index and could not find ECU.
Anyone?
hs
Old Aug 6, 2005 | 07:11 AM
kenchan's Avatar
kenchan
as above, the ECU will continue to adapt to your driving so no need to reset unless you are specifically having problems with the program.
kenchan's Avatar
kenchan
You have to buy the separate performance option or it doesn't come with one....
Anyone?
hs
Old Aug 6, 2005 | 08:52 AM
Dr Obnxs's Avatar
Dr Obnxs
reset away!
It's an ADAPTIVE system, no harm in resetting. It will start "learning" all over again. If you drive about the same way, it will end up in about the same tune. If you change driving styles, it can acclerate lerning the new driving style...
Matt
Old Aug 6, 2005 | 09:17 AM
kaelaria's Avatar
kaelaria
Exactly. If you reset, it just goes back to exactly where it is now. Resetting for performance is pointless.
Old Aug 6, 2005 | 12:56 PM
Koopah's Avatar
Koopah
I always reset after an ECU version upgrade to clear out the old A/F mapping and let the new code redevelop the new settings. Yes, I could just let time go by and eventually it will get to the same newly adjusted place, but this is America, damn it, and I want things to happen right away!
Theo
Old Aug 6, 2005 | 03:59 PM
Dr Obnxs's Avatar
Dr Obnxs
I've been thinking, and it's possible
that the programming is so gastly in the adaptive areas that it COULD end up in a different local operating state, but that would be truley sad, as it would indicate total incompitance in motor programming..... But it is possible.
In english, it's possible the motor could learn a bad habit that can only be removed by a reset and a different "learning curve" by the motor....
Matt
Old Aug 6, 2005 | 04:14 PM
kaelaria's Avatar
kaelaria
I have flashed back to back stock, standard and tuner MTH files - and it is immediately felt. There is no need to flash for performance - and Franz confirmed it to me. The adaptive properties are very minor, and take a couple tanks of fuel to be felt anyway. Any immediate changes you feel are not due to a reset.
Old Aug 10, 2005 | 10:55 AM
LeeL's Avatar
LeeL
Well, lets say the dealer resets the ECU, I am assuming that it is best to drive normally or maybe slightly more aggressively than normal at first?
Old Aug 10, 2005 | 11:40 AM
bambam's Avatar
bambam
I brought my Mini in to have the doorlocks reprogramed and when I got it back it seems way smoother. Do you think they reset the computer also?
Old Aug 10, 2005 | 12:51 PM
ingsoc's Avatar
ingsoc
I disagree. I installed a throttle body and tons of other stuff this past weekend, and within 50 miles [read: the same tank!], my car developed the usual throttle body-related flat spot from 2-3k rpm. It was not there on the shake down run immediately after install . That's right: from no flat spot to instantly recognizable flat spot. In 50 miles.
Old Aug 10, 2005 | 01:27 PM
kaelaria's Avatar
kaelaria
OK I'll re-phrase - they take a couple tanks to *fully* be felt.
Old Aug 11, 2005 | 08:35 AM
aminicooper's Avatar
aminicooper
Anyone else notice that after resetting the ECU, the odometer mileage is lower than before resetting? After resetting, I dropped 3 miles on the odo. Another 15 miles later I reset again and dropped 1 mile. The service interval still remained the same.
Old Aug 11, 2005 | 08:37 AM
kaelaria's Avatar
kaelaria
Can't say I ever looked...but next time I'll take a notice.
Old Aug 11, 2005 | 10:50 AM
bomboasy's Avatar
bomboasy
aminicooper, did not notice that, I will look. I have done many resets after making modifications. Never had any problems. If the milage drop is true, I might have a 0 miles '03 Mini by the end of the weekend
Bomboasy
Old Aug 11, 2005 | 11:04 AM
aminicooper
Yea I went to write down my trip computer miles, and I also wrote down the mileage. After I went to reset I noticed the mileage was different. Went to get gas and reset again just to see if it was a fluke. It went down a mile.
The first time I did it to lose 3 miles, I was in the "test" feature a while looking around. The second time I was in and out. Maybe it's time-based, or maybe I'm just crazy. Either way, I lost 4 miles. After one restart and drive, it hasn't recorrected. Not concerned.
Bomboasy
Old Aug 11, 2005 | 01:09 PM
LeeL's Avatar
LeeL
Don't forget to fill out your odometer statement properly if you ever sell.
Old Aug 11, 2005 | 02:27 PM
eMINI's Avatar
eMINI
PsychoRallye
21
Feb 17, 2019 06:08 AM
Rohdeandschwarz
Nov 5, 2015 07:58 AM
donniedarko
Sep 29, 2015 01:16 PM
simo711
Sep 29, 2015 11:53 AM
atlantaorange
Sep 16, 2015 12:43 PM
