Drivetrain Sound is addictive I know. But who makes the quietist pulley or is there such a thing
Old Jun 21, 2005 | 07:10 AM
Drsms22's Avatar
Drsms22
Sound is addictive I know. But who makes the quietist pulley or is there such a thing?
Old Jun 21, 2005 | 07:15 AM
mdsbrain's Avatar
mdsbrain
Well if you take your Pilo Intake off and put the stock airbox on it will quiet down alot.
Old Jun 21, 2005 | 07:17 AM
xsmini's Avatar
xsmini
I don't believe the pulley makes a difference in sound. What makes the addicting sound is the intake. Addictive = Alta, M7 VGS, HAI, and some other of the "more open" design. Some of the less addictive (quiter) would be the JCW, and perhaps the Dinan. Hope that helps.
Nik
mikem53's Avatar
mikem53
The SC whine is from the roots type blower itself. The pulley itself should not be heard over the whine of the SC.
Old Jun 21, 2005 | 09:18 AM
markbradford's Avatar
markbradford
Any reduction in sound due to the pulley would be accompanied by a similar reduction in boost.
Old Jun 21, 2005 | 10:34 AM
kenchan's Avatar
kenchan
I guess the answer is no there is no such thing...
Old Jun 21, 2005 | 11:09 AM
MyPocketRocket's Avatar
MyPocketRocket
work very well in water too!
Old Jun 21, 2005 | 11:55 AM
MancUnited1's Avatar
MancUnited1
Those are the scariest looking earplugs(?) i have ever seen....
Old Jun 21, 2005 | 01:24 PM
bodinski's Avatar
bodinski
In a nutshell, the pulley itself won't make noise (although a gatorback belt will whine on one). The pulley will cause a higher-pitched blower whine, which is accentuated by an intake such as you have. Putting the stock intake back on (like mds said) will greatly reduce the whine-effect.
Cheers - Bodinski
Old Jun 21, 2005 | 01:34 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Who has 3 ears?
Old Jun 21, 2005 | 03:07 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Originally Posted by golden_child
Who has 3 ears?
Mike Tyson and Evander Holyfield!
Old Jun 21, 2005 | 03:26 PM
tattman23
^^ LMFlippinAO! ^^
Not many people are aware of this but Tyson has been mostly DEAF, for quite some time. The story goes that shortly before the infamous Tyson/Holyfield match, Tyson's therapist actually told him that "he really should consider taking a YEAR off".
Thanks, I'm here all week,
Tatt
Old Jun 21, 2005 | 03:43 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
The quietest pulley would be the stock pulley with the stock airbox, but that is too boreing. Enjoy the music while you can , In '07 it will be gone and replaced with a turbo charger and a blow-off valve.
Old Jun 21, 2005 | 04:49 PM
whovous's Avatar
whovous
The pulley is my only mod, and it is definitely louder/more high pitched.
Old Jun 21, 2005 | 05:16 PM
Ryephile's Avatar
Ryephile
In my experience, it's not the pulley per se, but the belt you use. With a 19%, I've found the only acceptable belt to run is the Goodyear Gatorback. Ironically, despite Goodyear's claims if it being "the quiet belt" it's toothed-style design, while facilitating tigher radii, also creates a distinct "whining" noise so common with actual toothed belts used on big roots blowers (6-71 and bigger)
HTH,
Ryan
Old Jun 21, 2005 | 05:54 PM
Greatbear's Avatar
Greatbear
Generally the pulley itself will not increase the noise. As some have said, using a Gatorback segmented belt might cause a slight increase in belt/pulley noise, but the bulk of the increased noise comes from the overall increase in boost as well as the raised pitch of the sound from the blower. You now have the blower working harder, creating more boost throughout the engine rpm which increases the intensity of the blower whine, plus it is now at a higher average frequency which makes it that much more noticeable.
I knew this going in, so when I added my pulley I also installed the JCW intake which keeps the noise level attenuated during normal driving but opens up to let the scream happen during 'spirited driving'.
Old Jun 21, 2005 | 07:23 PM
Drsms22's Avatar
Drsms22
I love blower whine and muffler roar as much as the next guy but....
I love blower whine and muffler roar as much as the next guy but....why have a nice stereo system.?If the fun sounds are competing with the stereo system and you love music (and if you have a hearing deficit and wear hearing aides and can't hear the music well anyhow as is my problem) then you shouldn't have to choose between performance and music....and who wants a slower MINI than is affordable?
Old Jun 22, 2005 | 04:06 AM
mdsbrain's Avatar
mdsbrain
hmm we need a balance between the engine's music and the stereos then. When I drive I only noticed the engine over the stereo on hard acceleration so I have my balance
Old Jun 22, 2005 | 04:54 AM
aokdoug's Avatar
aokdoug
put the gator-back on this week-end
sound difference not that much.
Old Jun 22, 2005 | 09:13 AM
camelpilot's Avatar
camelpilot
wtf.... isnt it the Supercharger that makes the noise? It makes the noise as a result of the added air going through it. So adding both an air intake and smaller pulley will increase the sound. Remove the air-intake and you still have the sound, because of the pulley. Remove both (back to stock) and you lose the whine.
Put it this way, you cant have the smaller pulley and not have the sound.
Old Jun 22, 2005 | 04:37 PM
vegasdan's Avatar
vegasdan
The SC whine is there no matter if you have a reduction pulley or not. You will hear the whine sooner in the rev band with a reduction pulley, or in other words, you will hear it more often than with a stock pulley. The whine is amplified with a CAI to one degree or another depending on the brand. Solution, roll your windows up, turn the AC on full and crank up the stereo or just listen to that wonderful sound.
Teh
Aug 22, 2022 04:37 AM
blackie
Jan 18, 2017 09:56 PM
David.R53
Sep 1, 2015 06:49 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
