Drivetrain Does the UUC Exhaust do the 05 MCS tailpipe burble?
Old Jun 17, 2005 | 07:46 PM
tifosi360's Avatar
tifosi360
I am think in of getting the UUC exhaust; however, I don't think i want to lose the exhaust burble that they introduced on the 05 MCS? Anyone with the UUC out there?
Thanks!
Old Jun 17, 2005 | 08:13 PM
resipsamcs's Avatar
resipsamcs
I have a 2003 MCS, put the UUC on during the summer of '03, definite burble and a good bit louder than stock. It is a good looking, good sounding, good feeling exhaust. Several vendors sell UUC products. Dealing directly with UUC on any potential issues can be challenging and time-consuming, as I discovered, but the company eventually made good in my situation (first exhaust unit developed a crack on a weld seam, attempted fix as suggested by UUC did not hold for long, promised a replacement that took many months and much effort before actually getting the replacement. UUC did throw in a shift **** for the troubles, however, and I like it as well).
Len
Old Jun 17, 2005 | 08:19 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
UUC does burble when you let your foot off the throttle just a bit.
Old Jun 18, 2005 | 02:31 AM
apexer's Avatar
apexer
I know this doesn't answer your question about the UUC but, if you want GREAT Burble... go Magnaflow
Old Jun 18, 2005 | 08:44 AM
C4's Avatar
C4
Keep the stock '05 MCS exhaust. Great popping, burbling, much better flowing system than previous years.
Probably I am in the minority of people here that think the stock exhaust is more than enough for the car.
Old Jun 18, 2005 | 09:42 AM
Tüls's Avatar
Tüls
Turbius Maximus
The burble is GREAT on the UUC on my 04....makes other mini owners jelous...LOL...
Old Jun 18, 2005 | 12:36 PM
SteelKite's Avatar
SteelKite
Magnaflow
Old Jun 18, 2005 | 01:41 PM
kaelaria's Avatar
kaelaria
The '05 burble is caused by the ECU pulling ignition timing to ~-30deg. on sharp off throttle movement.
Old Jun 18, 2005 | 04:32 PM
eVal's Avatar
eVal
Thanks!
As previously stated, it does not seem to be the exhaust causing the popping in the first place, so changing it should not effect it (aside from volume depending on how loue/soft that exhaust is). Someone we know did not like the 'burble' on the 05,got a Dinan exhaust thinking the popping was caused by the stock exhaust, and in the end the popping is more noticable then ever since the Dinan exhaust is louder.
Old Jun 21, 2005 | 04:25 PM
MeeneeBoy's Avatar
MeeneeBoy
Originally Posted by eVal
... Someone we know did not like the 'burble' on the 05,got a Dinan exhaust thinking the popping was caused by the stock exhaust, and in the end the popping is more noticable then ever since the Dinan exhaust is louder.
In contrast, I like the 05's burbling pop pop sound. If I go for JCW, Dinan or others tunning mod, will I loose the poping burble sound?
S
Old Jun 21, 2005 | 05:46 PM
ripley's Avatar
ripley
Bottom line.......put any exhaust you want on an 05 and it will still do it's thing. As stated above, it's not the exhaust doing it, it's the ECU. I have a Miltek. Still pops away.
Old Jun 21, 2005 | 06:15 PM
CooperSAZ's Avatar
CooperSAZ
S
No, you will not lose the popping, burble sound. I have a Milltek as well, it's great!!!!
Old Jun 21, 2005 | 06:57 PM
kaelaria's Avatar
kaelaria
I'm narrowing down my choices and Miltek is at the top of the heap! I need to see a dyno fo stock '05 to Miltek though, I'm not spending that kind of cash for 3-4 HP!
Old Jun 21, 2005 | 07:20 PM
ripley's Avatar
ripley
kaelaria, I understand your issue. And trust me, the Milltek isn't going to make a significant difference in performance like a pulley does. But in addition to the performance you do get, you also get the look and the sound. For me, when I put it all together, the price was worth it. But to each his own.
ripley.
Old Jun 21, 2005 | 07:22 PM
kaelaria's Avatar
kaelaria
Well, I like the stock sound, and A set of tips for the look is about $500 cheaper
Old Jun 22, 2005 | 09:29 AM
CooperSAZ's Avatar
CooperSAZ
I have a dyno sheet on my '05 MCS with a Milltek and Rogue CAI. Mind you it was raining (humidity).... I do not have any stock numbers unfortunately...
http://www.geocities.com/tankboy1274/Dyno_Results.pdf
Old Jun 22, 2005 | 09:35 AM
kaelaria's Avatar
kaelaria
Yeah I've seen sheets with the Milltek but no stock to Milltek comparison which is the only thing that matters.
Philipangoo
Sep 16, 2015 11:54 AM
imanexcellentdriver
Aug 31, 2015 08:08 PM
cmanlu
R58 :: Coupé Talk (2012+)
Aug 25, 2015 07:35 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
massmini03
Aug 12, 2015 11:19 AM
