Drivetrain What mod next?
Old May 10, 2005 | 09:20 AM
spillman's Avatar
spillman
What mod next?
I just had the 19% pulley installed last weekend at the Dragon. Man... what a great difference from the stock pulley. Anyways, yesterday I was barely out run by my buddies Z28 camaro.
What mods would be the most intelligent/horsepower gain at my state of tune? All of my mods are posted below. I'm not concerned with cost... however I want to keep the factory supercharger and do not want to add a turbo.
I am considering going GIAC with injectors or the Webb head and cam. Any other ideas are welcomed.
Thanks in advance
Old May 10, 2005 | 02:31 PM
spillman's Avatar
spillman
Come guys... I know someone has an opinion on this. Help me out.
Old May 10, 2005 | 02:51 PM
pfunk's Avatar
pfunk
suspension & lighter rims&tires. Mini will never be really fast car on straight roads. Spend some money on springs, sway bar, control arms, camber plates, good sticky tires on light rims, you will not be disappointed.
Old May 10, 2005 | 03:16 PM
sfjames2's Avatar
sfjames2
I got it!!! Get rid of the Audio equipment!
ah my first love...the Camaro.
Seriously though, I think it's time to open up the Head some.
Old May 10, 2005 | 04:10 PM
SpiderX's Avatar
SpiderX
Thanks in advance
I did not see a sway bar on your list - that would be my next followed by springs and shocks then brakes.
I noticed on the Dragon that with my big brakes I was able to brake alot later than any body I followed.
I have the head and cam and it does make a difference but handling and stopping in places like the Dragon IMO matter more.
Old May 10, 2005 | 04:29 PM
vegasdan's Avatar
vegasdan
Larger intercooler, especially with the 19%.
2004 MCS, sport pkg, lapis leather, 15% pulley, densos, Alta intake, Milltec exhaust
Old May 10, 2005 | 06:05 PM
kenchan's Avatar
kenchan
If you prefer the factory height, i would do: rear swaybar & light wheels/tires
next. :smile:
Old May 10, 2005 | 06:17 PM
whovous's Avatar
whovous
Excuse me if these are too obvious, but when you replaced the pulley, did you replace the belt as well? I assume so. What about getting colder plugs? I've been told I need that for the 15% pulley I had installed at the Dragon, and it should be even more important for your 19.
Old May 10, 2005 | 06:35 PM
SpiderX's Avatar
SpiderX
I'm going to agree with the wheels and tires before brakes. I just take my wheels for granted
Old May 10, 2005 | 06:36 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Having power without traction is worthless. I vote for a Limited Slip Differential, Quaife preferably. That would be my first addition from where you are now. Followed by;
Short shift kit (many to choose from)
The lightest wheels you can afford (16"x7" generally, less rotational mass)
Non-run-flat tires (Goodyear, Falken, Goodrich etc 205/50-16, 215/45-16)
Larger rear anti-sway bar (H-sport 25.5mm tubular is very light and stiff)
Koni adjustable shocks
4-point harness (if you will be doing track days or Auto-X)
Edit:11May05
Larger throttle body (increrase air flow, the single largest bottleneck of the intake system)
Intercooler water spray system (improved cooling of the intake charge)
You never really said what you were aiming at for a final product, a race car or a poser.
Old May 10, 2005 | 06:56 PM
eVal's Avatar
eVal
Another vote for some very light wheels and good non-runflats. Makes a difference that you can really feel even if you can't see it on a dyno
Old May 10, 2005 | 08:07 PM
spillman's Avatar
spillman
WOW! Never seen such an imphasis on suspensions modifications.
I forgot to put my suspension mods on my sig. I have the H-sport rear sway bar and springs. I also have kosei k-1 racing wheels 16x7.5 with azenis on them. So I think I'm set in that department. Just looking for an extra 20-30hp.
Old May 10, 2005 | 09:02 PM
kyriian's Avatar
kyriian
you will be very hard pressed to get 20-30 hp at this point... on paper, a head, intercooler, with crank pulley should get you that power... but on the road would be quite a different story
intercooler to help cool your intake charge will benefit you alot... a to a benefits from good performance overall, w to a benefits from denser cooling agent, and it is not as impervious to heat.. but you still need to get that water cooled.. ultimate solution would be fmic, but very pricey
a new head would defenitely free up hp, but pricey...
crank pulley is the next known good thing... but reliability could suffer a bit especially considering you have a 19%....
injectors would help, but im still a but puzzled as to the benefits of bigger injectors... would it benefit a 15% pullied S as well?
Old May 10, 2005 | 10:00 PM
Turbogeo's Avatar
Turbogeo
Try a M7 hood scoop, now that you have a 19% pully your I/C will run hotter the scoop will help cool the I/C.
Old May 11, 2005 | 03:18 AM
SpiderX's Avatar
SpiderX
OK, no mattter where you are (I am) you (I) always want 20 -30 more hp.
Get a head/cam/TB/IC and a way to custom tune the system. I have proven it to myself that bolting stuff on and just loading in software is not the best way to go. I recommend with this amount of mods you need to dyno tune your car to get the most for your $. The "off the shelf" stuff works great for the basic mods but my experience shows that more mods the more the integration needs to be "tuned."
Old May 11, 2005 | 07:07 AM
Bahamabart's Avatar
Bahamabart
Nos
Big a*s bottle of NOS and then go look for that z28
Old May 11, 2005 | 07:18 AM
motorsports3's Avatar
motorsports3
Took the words from me. If all you are looking to do is out run a Z28 in a straitaway just grab a 75 shot
Old May 11, 2005 | 07:43 AM
Wraith1416's Avatar
Wraith1416
i know one person already posted it, but from a safety standpoint, i'd say a schroth 4-point harness. that harness saved my @$$ en route to the dragon. if your gonna go fast, you gotta have be safe when doing it. followed by the harness, suspension would be the next best step, wheels/tires followed by springs/sway bar/control arms, and then prolly the LSD
Old May 11, 2005 | 08:29 AM
spillman's Avatar
spillman
Thanks for all the suggestions.
As far as nitrous goes I am wanting to wait until I have pulled every last horsepower out of the motor witout the spray. Also I am wanting to have the motor bored and fitted with larger/stronger pistons before any laughing gas.
I believe I am going to go apexi and larger injectors for my next mod right now. Unless any of you can give me a reason why I would find larger gains with something else.
Any and all comments are welcome.
Old May 11, 2005 | 08:37 AM
SpiderX's Avatar
SpiderX
Good choice (IMO)
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
