Drivetrain M7 Oil Catch Can Install Question
Old May 5, 2005 | 12:32 PM
Smooth is Quik's Avatar
Smooth is Quik
I just got the M7 Oil Catch Can this week and first glimps of the product looks impressive. As Iwas going through the box I noticed that NO written instructions were included, but instead, 2 seperate sheets of paper with a picture diagram of how it's supposed to be after its installed . I have recently installed an Alta kit on a friends so I'm familiar with how Alta had theirs installed. I'm assuming(hate using that term)that it installs the same way but I'm not sure where to install the can itself. Can someone kindly fill in the blank on where it goes and how to mount it CORRECTLY.
Old May 5, 2005 | 12:40 PM
M7's Avatar
M7
Call us now if you like at 562 608 8123 and we can discuss your options.
Randy
M7 Tuning
Old May 5, 2005 | 01:30 PM
Rick-Anderson's Avatar
Rick-Anderson
Whp needs words when you have pictures. I know, you actually READ the girly magazines Enjoy the catch can.
Old May 5, 2005 | 01:34 PM
mburchill36's Avatar
mburchill36
M7 -
Is it normal that this ships without written (i.e., step-by-step) instructions? ...or did it just get packed for shipping incorrectly?
- - m
Old May 5, 2005 | 01:40 PM
Smooth is Quik
Called
Talked to Randy on the phone and nailed down a good spot for the can. Now it's time to get busy!
Old May 5, 2005 | 01:42 PM
tennis_man's Avatar
tennis_man
They ship the can with a diagram only, no written intructions. But it is not a complicated piece of equipment so you are left up to your own devices on where to install it.
Old May 5, 2005 | 03:22 PM
maxmini's Avatar
maxmini
Originally Posted by mburchill36
M7 -
- - m
As tennis Man noted we ship the OCC with a multi color diagram. With over 5 different monting locations that I can think of off the top of my head prividing written instruction for all of them would have been more confusing than helpfull. If anyone has questions our tec line is open 7 days a week.
Randy
M7 Tuning
Old May 5, 2005 | 06:43 PM
Rick-Anderson
Some Photos May Help
This may make it easy.
Here is an overview of the system as it is installed in my 2004:
You can see the connections at the T-piece. Also note the two holes that go through the shield with grommets on the far left:
Here is the mounting position:
…Although it can also be mounted on the lug on the shield here:
Old May 5, 2005 | 08:11 PM
maxmini's Avatar
maxmini
Rick...... Thank you for the detailed description for the mounting of the M7 oil- catch can
As I was sitting on the flight from Hawaii to LA. I suddenly had an urge to write
an amazing install manual for the OCC. this will have images
and suggestions galore for placements of the can and more......
Expect to see it on our website in the very near future. Mean while, call us on
our techline for a personal touch to your problems
peter
Team M7
562-608-8123
Old May 5, 2005 | 09:56 PM
tradiuz's Avatar
tradiuz
MTH Specialist
That spot is unusable if you have a factory alarm! (As the siren housing goes there)
Old May 5, 2005 | 10:02 PM
Rick-Anderson
Which is why I pointed out an alternate spot in the last photo.
Old May 6, 2005 | 06:14 AM
mburchill36
Rick -
With the OCC behind the shield, how difficult is it to get it out and empty it? Does the OCC have a sight-glass or some other device that shows you the level of it's contents? Can't tell from your images.
BTW, Thanks for posting them!! I'm interested in putting one of these in, but I'm not exactly the world's greatest mechanic... guess I drive 'em - and don't usually wrench 'em.
- - m
Old May 6, 2005 | 06:40 AM
Smooth is Quik
Does anybody know what the protrusion point is used for? Where exactly does the alarm siren mount at? I'm contemplating removing the protrusion point and mounting the new can there. Any issues with this? BTW, I have a Jan 05 build date so the motor mounts are different, so is the way you can mount the catch can. The pictures above show you can mount the can with the supplied bracket at the top of it. Mine has two areas on the side of the can only.
Old May 6, 2005 | 06:46 AM
MyPocketRocket's Avatar
MyPocketRocket
If you use that position you will block the space to get to the oil filter...eh?
Old May 6, 2005 | 07:09 AM
minichrist's Avatar
minichrist
I've got the Alta, but I did use the (outside) mount method on that shield. Dirlled one hole, nut/bolt using the supplied but bent bracket. It does block access to the oil filter, but it's easy enough to remove (and see the level). Besides, I'd probably be removing anyhow to empty it during an oil change.
Props go to RandyWebb for the trick heat wrap.
Old May 6, 2005 | 07:42 AM
Rick-Anderson
Rick -
- - m
It's fairly easy to get to - just remove the nut on top of the bracket (I'll probably switch to a wing nut in the future.) You can see the sight glass in this photo, just to the right of the can.
Old May 8, 2005 | 09:36 AM
Smooth is Quik
Bottom Line!
After great debate, here is where I mounted my M7 OCC yesterday. I dremeled off the post protruding off the back shield and mounted the OCC as high as I could for possible heat damage and easy oil change purposes. Not included in the kit was the hardware to mount the mounting bracket to the car. I did rotate the top lid to accommidate the direction of the tubing but that was the only chage I made from what was delivered.
Old May 8, 2005 | 02:45 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
After disbelieving that Todd and I knew which way up the intercooler goes, of course. We put it back on, and Mark insisted it was upside down and made us remove and flip it. It wouldn't re-install, so I showed him how it looks on my car (the way we originally had it) and put back on for the 3rd time.
If you don't want my help, I won't help any more.
Old May 8, 2005 | 03:06 PM
uae mini's Avatar
uae mini
Why don't we use a Greddy catch can if they are all the same?
Alkaidovich
Jan 30, 2021 01:35 AM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
M7Speed
Aug 6, 2015 01:48 PM
