Drivetrain Official ALTA Q&A thread!
Old Feb 13, 2006 | 02:44 PM
  #426
TUFFMINI's Avatar
TUFFMINI
Silicone hose!
Is the silicone hose used for the Cooper S automatic? I have not found anywhere that tell me it is not, Until i purchased the hose, and the Alta intake. the paper works states the hose is not needed.
Did i waste fifty smakers for a tube that i cannot use?
Old Feb 13, 2006 | 02:52 PM
  #427
ALTA2's Avatar
ALTA2
Manufacturer
TEST data on ALTA intake
Just a test for our site. This is something we may post on our site and hopefully other intake vendors will give similar numbers for their own intakes. The test is to see if others understand this and if it is relevent.
ALTA box volume-
303.75cu-in
Plus OEM base volume-
224cu-in
Plus top of box/seal to hood volume-
62cu-in
Totals-
589.75cu-in of area for our filter to suck air from, plus the 38.75sq-in opening to the cowl.(with unlimited air volume)
Alta Filter (foam only) Volume
147.2cu-in
Base volume
18.3cu-in
Space for filter to suck from total box cu-in minus filter total volume
424.25 cu-in
Using-
Alta Filter Surface area-
122.46sq-in
To suck from.
Why does this info matter? It shows the available space for the filter to suck air from. A smaller box would start to act like a restrictor, and loose power.
Please comment on this data, as we will use the NAM opinions in regards to posting this to our site.
Old Mar 19, 2006 | 03:32 PM
  #428
skuzy's Avatar
skuzy
alta -
installed ur s/shifter - and love it.
But need to know something with the adjustable height - when i lower it to the lowest height of the shifter, the gear stick forces the gear box lid off from underneath the car - is this meant to be right?
driving without the lid on is allowing a ton of heat in, and im not 100% if this is right so i heightened the gear stick for now - until i hear from u.
thanks
Old Mar 19, 2006 | 06:50 PM
  #429
polizei's Avatar
polizei
I have a question:
Why is the air intake $260! That seems like a lot of money for an intake. I though most were ~$150? Guess I was wrong...
Oh, and do you guys make different colored filter's? I would love to have a blue filter with a blue hose.
Old Mar 20, 2006 | 03:32 PM
  #430
ALTA2's Avatar
ALTA2
Manufacturer
skuzy,
That is correct. But there is more to it than just that. Did you get instructions? There are 3 settings to the SS.
1-no modifications (0-15% shorter)
2-Slight lid modifications (0-20%)
3-lid removal (0-50% shorter)
When you remove the lid, there really isn't anything exposed that will get hurt. What i mean is that there is still the large aluminum heat shield above the exhaust which protects it from the heat and amazingly enough DIRT!
This is something many customers call about. They are worried about dirt getting up there. But i have pulled that shield off of cars with 30K miles on them and they are very clean up there. I hope that makes you feel better and not worry about anything.
polizei,
Good question and one we get quite often. Lets compare others out there first. Most all intakes do not include a larger intake hose that goes from the throttle body to the air box. We have proven this hose alone is worth 6WHP. That is one of the items that adds cost over others.
You might be thinking well there is still the filter and box which is the same basic thing. Well that is also not exactly correct. Our air box is very different from others in that it goes around the ECU box and to the firewall. Not just around the front to hold the intake tube and filter. Secondly our intake is designed around removing the plastic wall between the filter and the area below the window cowl. This gives you nice fresh air from that vent in front of the window.
The foam filter is an item very different from the rest out there. Most everyone uses a K&N style filter, which works very well when new and clean. In fact performance of an equaly sized filter is the same when new and clean. But when dirty the foam will out clean and out flow hands down. Look at the world of off road racing. Foam filters are everywhere!
We offer our intake minus the silicone intake hose for $199.99. Yes it is a little more expensive, but it is also a little better. And for $260, the intake you buy will out perform all other intakes out there!
Old Mar 21, 2006 | 09:20 AM
  #431
polizei's Avatar
polizei
Sweet! Thanks for summing that up for me. The Alta CAI will probably be my first mod when I get a MINI.
Thanks!
-Cody
Old Mar 21, 2006 | 09:37 AM
  #432
DrkSlvrS's Avatar
DrkSlvrS
CAI C.A.R.B. Approved
Just to keep this subject alive ...
I know that you said "...towards the begining of summer..." we should hear something about the CAI being approved by the Air Resources Board - is there any news on the first full day of spring?
T
Old Mar 21, 2006 | 01:58 PM
  #433
skuzy's Avatar
skuzy
thanks alta - i trust no dirt will get in there.. but will the heat affect any of the wiring etc ? the gear stick, and leather boot gets quiet hot.
Anyone else with an alta s/shift care to comment?
Old Mar 21, 2006 | 02:03 PM
  #434
ALTA2's Avatar
ALTA2
Manufacturer
DrkSlvrS,
When we get back from the LV meet this weekend, a lot of the focus is being put on gettting that all going. Also the Auto intake parts will be shipping end of next week so we can make sure to get all versions of the intake done at the same time.
Skuzy,
It shouldn't there have been people using our SS for 3 years with no issues. That big aluminum heat shield works very well for keeping the heat and dirt out of that area. I have never noticed anything getting too hot around the shifter.
Old Mar 21, 2006 | 02:26 PM
  #435
skuzy's Avatar
skuzy
OK Thanks for the answers
Old Mar 21, 2006 | 11:44 PM
  #436
DrkSlvrS's Avatar
DrkSlvrS
Thanks for the reply ...
SEE YOU IN VEGAS!!!!!!!
Old Mar 27, 2006 | 10:49 AM
  #437
ALTA2's Avatar
ALTA2
Manufacturer
Sorry i didn't make it to Vegas. John and Adam were there handing out catalogs, and chatting with everyone. Just spent the first couple of hours looking at all the pics, and cars. That is sure a lot of Minis!
Vegas next year i think will be even bigger! Fun things to come!
Old Apr 3, 2006 | 03:59 PM
  #438
DuckWerks's Avatar
DuckWerks
Control Arms,
Just a question re: Alta Control Arms.
Does the inner part of the heim joint supposed to swivel/rotate?
They look like they would but seemed to be in a fixed position. On each control arm, one end is fixed symmetrically, while there other end seems to be in an angle. Pardon my ignorance.
Old Apr 11, 2006 | 04:13 PM
  #439
ALTA2's Avatar
ALTA2
Manufacturer
Sorry for the slow reply we have been swamped the last week!
DuckWerks,
Yes, that is basically a ball pressed into a socket. (that is not how they get in there though) So they spin and rotate in all directions. doing this without flex is how they do this differently than urethane or rubber. Hope that helps!
Old Apr 11, 2006 | 04:37 PM
  #440
mistro's Avatar
mistro
Hi is it possible to modify the alta 19mm sway bar to accept grease fittings to alow for periodic lubrication? Is it something you sell?
Old Apr 11, 2006 | 09:30 PM
  #441
matma92ser's Avatar
matma92ser
Jeff - Can you give us the latest news on your header?
Old Apr 12, 2006 | 03:30 PM
  #442
ALTA2's Avatar
ALTA2
Manufacturer
mistro,
You could modify them or purchase an Energy Suspension part that has the fittings already in them. This is something you will eventually see on our bars. the Energy Suspension part number is 9.5156.
matma92ser,
The headers are shipping! Finally!
Old Apr 12, 2006 | 03:47 PM
  #443
mistro's Avatar
mistro
Thank you Alta2 and thank you Adam at Alta
Old Apr 12, 2006 | 04:44 PM
  #444
mistro's Avatar
mistro
Alta 2 is this what you are talking about?
http://cgi.ebay.com/ebaymotors/Unive...QQcmdZViewItem
I assume I want Graphite impregnated self lubricating bushings as opposed to non self lubricating. TIA Michael
Old Apr 12, 2006 | 05:08 PM
  #445
ALTA2's Avatar
ALTA2
Manufacturer
You got it, but the graphite stuff is custom, and not a part number you can buy. If we offer this in the future, they will be like our other bushings, that are custom made from Energy suspension.
Old Apr 14, 2006 | 10:31 AM
  #446
Larry Clemens's Avatar
Larry Clemens
Two Questions: (1) Is there a black CAI box top available for purchase yet? (2) What date will the CAI CARB stickers be available? I heard by summer.
Old Apr 14, 2006 | 11:29 AM
  #447
kseckel99's Avatar
kseckel99
CAI sound
I had an Alta CAI installed 2 weeks ago by WayMotors (wonderful job I might add), and was wondering what the sound is I hear. Sounds like a sucking (?) sound if I put my foot into it. I know the whine sound, but this is a 'psssst' sound? Very short and if I remember right happens after I let off gas to shift.
Thanks,
Old Apr 16, 2006 | 09:10 PM
  #448
Petrich's Avatar
Petrich
Adjusting Alta sway bar end links
Jeff,
How do you recommend that we adjust our Alta sway bar endlinks when the suspension has been lowered about 1" ?
Understand that lowering the suspension reduces the distance from the sway bar to the strut endlink mounting ear. Do I shorten the Alta endlink compared to the stock endlink an amount equal to the amount that the car is lowered?
Regards,
John Petrich in Seattle
Old Apr 18, 2006 | 01:34 PM
  #449
ebock's Avatar
ebock
CAI with JCW
I know this has probably been asked a million times (but I have been unable to put the right search terms together to find it). Is it worth replacing the updated JCW (05) Air Box with a CAI?
Ed
Old Apr 18, 2006 | 04:32 PM
  #450
Larry Clemens
Alta - message sent again.
